Question about Crate Music
My Crate G600XL will not give me any distortion. The knobs don't seem to do anything on either side, there isn't even a way to turn down the volume on it, i have to turn down my guitar in order to practice at home. how do i fix this??
4 Suggested Answers
Kree8iv
  • 192 Answers
SOURCE: Not getting enough distortion(esp ltd ax-260)
It's not your pickups. It would be nearly impossible to loosen a wire inside of your guitar by having even heavier than your amp head drop on it. It is most likely your volume pot. The post, if hit hard enough, can virtually distroy your pots. Another possibility could be your jack, al though considering where it's located on your guitar, it would be very hard to damage it by having something drop onto it.
There is little else that could be the problem. Hopefully you didn't damage your guitar too badly. If the guitar was in front of me, it would be a relatively easy diagnosis.
Fortunately, volume and tone pots are inexpensive, and if you're handy with a soldering iron (or you have a friend that is) it is an easy install with four to six solder points, depending on your configuration. I don't want to assume it's a stock setup, but when you take off the rear electronics cover, you will immediately see what configuration you have.
If you have possibly damaged the pickup bobbins (assuming you have the stock humbuckers in your guitar), you would be able to see the damage, It would either look damaged,or work correctly. As you know bobbuns are simply wound wire, and that's not easy to damage. Plus your strings provide a minimal amount of protection, unless your amp head slammed it very hard. Start by replacing the volume pot. Cheapest parts first. There is no way to test the pot with anything like a potentiometer, because there is virtually no voltage that passes through the pot. Additionally, unless you have active pickups, your pickups cannot be either. If you do have to replace your electronics, you can find a large variety and even upgrade your parts by searching eBay. The good thing is that you havce a guitar, and guitar parts are abundant, relatively cheap, and most people change out electronics just to achieve a different sound.
If you are so inclined, most good guitar shops will diagnose your problem for cheap and apply the cost of the diagnosis to the cost of the repair. Good luck, and I hope I have given you some information to work with.
Thank you for using FixYa
Posted on Jul 19, 2009
  • 5603 Answers
SOURCE: Dirty high switch on a Crate practice amp
NEVER use switch cleaner such as DeOxit on pots !!!!!
I have used CRC226 available at Home Depot electrical dept.
I SUSPECT that the resistance element in that pot is cracked. This is common if the knob sustained a hit. Replacing the pot is the only cure if the element is cracked.
Reviewing the schematic, ALL audio passes through the wiper on the HIGH tone pots. If the wiper is intermittent, so will be the sound.
If your unit is solid state amp, the pot looks like a 10K ohm LINEAR taper.
If you have a tube type, then the pot is a 250K ohm LINEAR.
Note that the other tone pots in the units are AUDIO tapers, but the high is a linear taper.
Get repair parts from either DigiKey.com or Mouser.com
Posted on Mar 23, 2010
  • 5603 Answers
SOURCE: jvm 410h squeals with feedback
Test if it does it with the guitar cable unplugged from the amp. If it does, then it is time for servicing... If not, then you have a system grounding problem and the guitar cable is "leaking" signal into the amp. This can happen even if guitar is NOT connected.
Posted on Mar 14, 2011
My crate amp makes a static sound when i turn controls and the cord input port makes noise when moving it around
Most likely a loose connection. Try to tighten the knobs and the cord port to the crate. You need to do this from the inside. These tend to loosen with use and anything that is connected with them will also loosen, like the electrical connections. Good luck!
Feb 20, 2016 | Crate Music
I have a crate vtx200s has very little volume everything else works whats the deal?
Hi, you hadnt mentioned how long you've had the amp, or how new it is, so I'm going to assume it's new to you. The Crate VTX200 has 3 channels, each with its own volume level. Let's check the simple things first:
1. Check to make sure you're adjusting the same volume knob volume knob to the same channel. The active channel will be lit with a green light.
2. Check the cables from the "Speaker Out" jacks on the amp (if you are using them). Are they plugged in all the way, or are they damaged?
3. Are you playing through a preset that you may have accidentally made "low", and may not be aware of or are stuck in it?
If none of these answers helps, there might be a problem with the input buffer in the circuit or possibly within the damping circuit of the speakers. I'd advise having the amp serviced to confirm an internal electrical problem also. If you don't have a manual for the amp, one can be found here:
http://www.manualguru.com/crate-amplifiers/vtx200/users-manual
Jan 22, 2016 | Crate Music
Crate GLX-212 combo. cant change DSP. repair??
The last knob on the right should give 16 different effects, are you saying the knob doesn't work at all? Is it turning smoothly? Do you hear any clicks as you turn it? Is anything plugged into the dsp socket on the back where the footswitch would go?
Mar 13, 2013 | Music
My amp becomes distorted when I turn my keyboard up. Both the Master Volume and the CH1 volume knobs are in the middle(12 o'clock). How do I keep my amp from distorting?
You left off the one bit of info we need... however, make sure the volume control on the keyboard is around the halfway point... If it is way down, turn it up and reduce the channel volume knob some. Make sure the cable from the keyboard is an instrument rated interconnect and not one intended for speaker (usually marked as such). Make sure the keyboard AND this amp are powered from the SAME receptacle... even if you have to run an extension cord. Listen with headphones on your keyboard to make sure the sound is clean there.
Sep 01, 2011 | Roland Elektronische Musikinstrumente...
I have a crate fxt 120. I 'll be playing in the #2 overdrive channel and it will automatically fail and go to a clean sound. Although it is not entirely clean. It sounds like 2 sounds combined. A loud...
A possible problem MIGHT be marginal switch contacts on the external foot controller cable. If you are not using the foot pedal, these contacts must maintain contact to keep the same channel selected.
Sep 15, 2010 | Crate Music
Mar 23, 2010 | Crate Music
Crate Flexwave 120h (Half Stack) volume issues
Perhaps you have a bad capacitor on your volume control?
You can get an ESR meter and test your exposed isolation caps for leakage? The have to be removed so unplug the unit if you are gonna do any work inside the cabinet.
Also, try a shorter or higher quality guitar cable. This will cut impedance between the pickups and the amp.
Good luck and be careful!
Mar 08, 2010 | Crate FlexWave FW15 Guitar Amp Combo, 15...
Crate flexwave 120 head sound cuts out
You have a broken solder joint. You'll have to disassemble the amp enough to get at the soldered side of the circuit board that the controls are mounted to and touch up any suspect solder joints. Just be sure to resolder only the joints that were originally soldered or need to be soldered. Hope this helps.
Jun 07, 2009 | Crate FlexWave FW15 Guitar Amp Combo, 15...
MG100HDFX Amp - crunch setting seems too loud
There are 2 channels, Which means there are 2 sets of knobs ... One for clean and one for crunch. Start out with a low master volume and set up the crunch, Then the clen and switch between the 2 and make adjustments until they match volume wise ... Then turn the master up.
May 12, 2009 | Marshall MG100HDFX 100-Watt Amplifier Head
Alesis SR-16 distorted sounds
The distorted and low volume output plus noise is usually caused by using the wrong power supply adapter. The Alesis SR-16 takes a 9V "A/C" supply not "DC". The A/C supply provides a negative voltage swing which wouldn't exist with a DC supply. So check and make sure you have 9V A/C output supply not DC.
Nov 18, 2008 | Alesis Sr 16 Stereo Drum Machine
Music Logo
47 people viewed this question
Top Crate Music Experts
rjivaro
Michial Gueffroy
Ben Armstrong
Are you a Crate Music Expert? Answer questions, earn points and help others
