Question about Toshiba REGZA 55SV685D 55 in. LCD TV
Screen doesn't fit all the foxtel picture in it
Can't get a picture on our free to air TV set it keeps coming up no signal, we have a picture and sound on foxtel
you may find that the aerial inside your home was disconnected and used to wire up Foxtel in the roof, some technicians do that,
meaning all your Tv Outs on the wall would now be connected to Foxtel now instead of the aerial
if you can gain access to the junction of where all the Cable Coax wiring is in the roof make sure they haven't used the tv aerial cables for Foxtel ....just go check where your Aerial comes in and see it is still connected to the junction and not pulled out and a foxtel is going into it instead of the aerial
Apr 26, 2017 | Televison & Video
My Samsung TV has only a faint picture and full sound.
My LED TV has sound, but no picture. - Tom's Guide
www.tomsguide.com/answers/id-2771720/led-sound-picture.html
Dec 28, 2015 - The RCA TVs generally only have a 1 year limited warranty so that ... LG LEDLG LED TV has no picture (black screen) but still has sound TV has ... I Have SAMSUNG UA46 F6400 LED 3D TV I want TO CONNECT MY ... SolvedSamsung ledTV no picture solution; Sony vizio led tv has faint picture solution ...
TV Has Sound But No Picture Troubleshooting Guide ...
? 2:30
https://www.youtube.com/watch?v=ysHfaQKI45M
Aug 31, 2012 - Uploaded by Repair.com
Here are some steps to ease you through TV picture loss-from prevention ... But now when I turn on the tv there only sound nopicture. ... had sound etc. with very very faint picture if you look very closely (which I was). .... How To Fix Samsung LCD TV -Samsung TV Repair (Blank Screen) - Duration: 9:21.
Samsung LCD TV No Picture but has Sound - Electronics ' DSLReports ...
www.dslreports.com > ... > Electronics
DSLReports
Jan 26, 2016 | Samsung Televison & Video
Can anyone identify this PC Wallpaper
that's probably that your wallpaper isn't fit with your monitor resolution,for example,if your wallpaper size is 1280x1024 but your screen resolution (size) is 1024x768,it doesn't fit your screen and the wallpaper will only show half or even less
to check your current resolution,click
Start->Control Panel->click Appearance and Personalization->Click "adjust screen resolution" on the Display categories
you can see your current resolution and also you can set your resolution
To check the picture resolution,right click on the picture,select properties,click the Summary tab,and it doesn't show the resolution, click Advanced on the Summary tab
But I suggest you to download the wallpaper with a fit size instead of changing the screen resolution,because too high resolution will make your screen goes black
geez,i'm so sorry for my poor english
please rate this solution if it's work and let me know if you still has a problem.and thanks for using Fixya!
Aug 28, 2012 | Toshiba Computers & Internet
Picture doesn't fit screen
what is brand and model number of set and what signal source?
Mar 13, 2012 | Televison & Video
Picture doesn't fit the screen
what is the brand and model number of the set?
Our Hitachi 1080 Alis is zoomed in when watching Foxtel but is okay on TV and RGB. Can you please tell me how to fix? Thanks, Giselle
in not sure what foxtel is but if it is some sort cable provider some have there own picture size settings. it may be accessible through the picture settings on the cablebox if not you will have to ask the provider to help you go through the service mode to change the picture size. just knowing all other inputs are showing okay would lead me to suspect whatever plugged into the source. one more thing to verify is to plug in a dvd player or game console and see if that is zoomed in. if its not then your "foxtel" is to blame.
Apr 08, 2011 | Hitachi Televison & Video
Hello, We have a new bravia w series lcd tv. We have connected it to our dvd and foxtel digital box. We can get dvd and foxtel sound but no foxtel picture. I believe that the connections to the foxtel and...
Hi Michelle,
Does the Foxtel have a slot in the back marked HDMI Out? If so, this is the best possible connection to the Bravia. However you would need to pick up the HDMI cable (like bestbuy) It is a video & sound all in one. Do the 6 cords end in RCA jacks, and are they color coded?
Read Ya,
Z
Dec 31, 2009 | Insignia IS-PDVD10 Portable DVD Player
While watching television the screen just went black. We allowed it to cool down over night and still no picture or sound. The Foxtel information does come up at the bottom of the screen, but no...
I was going to inquire if Foxtel is your cable provider but have established that already. Judging from a description of their service, you have a convertor associated with Foxtel.
See if you can call up your TV menu (for doing initial setup). If it shows up your set is probably OK with only the tuner a potential suspect and these are quite reliable in comparison to some of the other subassemblies in our sets, then I would contact your cable provider as it seems the cable box has expired.
If you have any other video source such as a camcorder with video output or a DVD or VCR, try those.
Jun 06, 2009 | LG 22" Widescreen Flat Panel LCD Monitor
CT-F683 TV fault
Press setup on your foxtel remote, go to systems settings, and look for "TV Type" menu, you can change settings there, your TV is a 4.3 (square) not widescreen. Its not a telly problem your just giving it the wrong signal.
Feb 17, 2008 | Televison & Video
Buzzing and lines with Foxtel
I had this exact same problem, which was continuous pink bands or lines that rolled upwards, as well as a continuous hum or buzz. This problem was isolated to Foxtel; it didn't happen with the DVD. Differently, this problem happened immediately I changed from my really old TV to a new LCD TV. I experimented with the leads (Scart or otherwise) too without change. So I got Foxtel to come and have a look and the guy brought with him what he called an "isolator" which was a small box-shaped thing (about 3inches by 2 inches) that he added to the cable's its exterior connection point. Immediate and complete solution - no more lines or buzz!
Nov 04, 2007 | LG 42PX5D 42 in. Plasma HDTV
Toshiba REGZA 55SV685D 55 in. LCD TV Logo
22 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
