Question about Exercise & Fitness
Urs and srs diagrams - Exercise & Fitness
My SRS light blinks constantly. I need a wiring diagram for the power seats for a 05 Nissan Frontier LE
If the SRS light is blinking that means there's a trouble code stored in the computer. Get the code read and then you'll know what's causing the problem. Best place for wiring diagrams is
http://www.wilsonautoelectric.com/TSBDatabase
Jul 02, 2017 | 2005 Nissan Frontier
Srs light on whats the problem
not much specifics - system is disabled b/c of a malfunction.
chk ur warranty - these systems usually carry a longer commitment from the mfg.
Mar 03, 2015 | Cars & Trucks
No power til i reach about 30mph,srs check engine
OIL CHANGE TUNE UP N CHANGE ALL UR FILTERS (AIR/FUEL/N OIL)
Mar 12, 2014 | Mitsubishi Eclipse Cars & Trucks
I need the Airbag Wiring Diagram for a 1995 Honda Accord
helm has a great factory service manual selection, also you can probably get lucky and find one in a google search or maybe even on here. search "1995 accord service manual" i remember seeing them free for download or pdf view online. I know i seen alot more for earlier and later accords than my '99 when i was searching yesterday. good luck
Apr 19, 2013 | Honda Accord Cars & Trucks
Srs don't turn off
srs means something wrong with ur air bags. check the harness for voltage and ohms.but usaly it is the modulare that controls it.
Apr 09, 2013 | Car Audio & Video
Merc a 140 passengers seat wiring
I am sorry but we have no wiring diagrams. The SRS system should never be touched unless you know the proper procedures or it may go off on you, a very unpleasant thing.
Sep 06, 2012 | Cars & Trucks
An SRS icon is showing on my tecno t9 phone! what does it mean? please!.
Open ur mussic player, slide to settings click, go to audio set up, click then in SRS setting, choose close. That should solve the problem.Henry Malm.maldavix@yahoo.com
Jan 20, 2011 | Cell Phones
What does the red light with SRS in the light stand for?
SRS stands for "SUPPLIMENTAL RESTAINT SYSTEM" and that is the airbags. right now your system has developed a fault and has been disabled by the control module which is called the "airbag diagnostic monitor"
May 27, 2010 | 1994 Honda Civic
SRS light
Here's a quick check list for most common cost of SRS / Air bag problem.
Dirty contacts on driver and passenger seat belt buckles
Dirty contacts on seat belt connectors (under seats)
Dirty contacts on driver and passenger sides weight sensors (under seat)
Seat covers
Weight on passenger seat
(Example: grocery package trigger SRS / Air Bag light on the way home.)
I recommend you to pass an vacuum over the contacts and use CRC electronic parts cleaner to rule out connectivity problem.
I DO NOT recommend disconnecting the negative battery connector to clean the code(s).
Without the code(s) the dealer will takes "BILLABLE" time to reproduce the problem.
Please rate my answer if it is useful to you.
Cheers,
Mustgo
Aug 19, 2009 | 2000 Acura TL
Seat belt problem
if ur seatbelts are defective, it wont cost u anything. take it back to the dealer and tell them u want to have ur srs light looked at and trouble codes pulled. the seatbelts are lifetime warranty as long as the vehicle hasnt been in an accident
Apr 05, 2009 | 2008 Honda Civic
Exercise & Fitness Logo
69 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
