Question about Garden
I cant find a drive belt for a quality pro lawn tractor 169003
gisvc
  • 40 Answers
SOURCE: drive belt slips on lawn tractor, cannot see an adjustment.
hi,
i would check with the owners manual to see if it shows an adjustment for the belt drive. most mowers today are equipped with a self adjusting arm witha pulley tensioner with a spring attatched to it. as the belt stretches the tensioner spring pulls against the arm causing it to apply tension to the belt thus tightening it. it sounds as if your belt is stretched beyond the limits of the tensioner. at least every new season it would be a good idea to inspect the belt tensioner for room or space of free play. that is to check to see if it will move opposite the pulley allowing the belt to tighten. if there is not enough sufficient room then i suggest replacement of the drive belt.
Posted on Mar 29, 2009
  • 376 Answers
SOURCE: large belt routing for crafstman lawn tractor
Go to... http://www.searspartsdirect.com/partsdirect/index.action Enter the model number that is under the seat. If it's a lawn tractor, it will start with 917. That will get you to all the diagrams of the mower.
Posted on Jul 02, 2009
  • 61 Answers
SOURCE: Roper 16 hp Lawn Tractor: belt replacement
you need to remove the mower deck there you will see the pullys.
Posted on Sep 06, 2009
  • 17 Answers
SOURCE: i need a pully and belt diagram to put the drive
These are a pain. You can go online with model number & get the diagram. Its the same as a John Deere. You will have to loosen the steering arm 7 rasie the steering wheel just enough to pass the belt thru. Make sure you mark its position for reailigning before disconnecting. Diagram should also be in your owners manual. Goo dluck with this one
Posted on Aug 04, 2010
WHAT SIZE DRIVE BELT I NEED FO 30" RIDING LAW MOWER ? MODEL NO P01230lt SERAL NO.011310A001123 model no PO12530lt 12.5 HP
We do not have any info on this site
Just a chat room
Take you info to a small equipment
dealer/repair shop & they can look it up
for you
Jul 06, 2014 | Poulan Pro Lawn Tractor 2006 and Newer...
2008 poulan pro 18.5 hp 42" cut 6 spd smokes bad when i put it in gear
check drive belt make sure its not rubbing against melt guied tabes
Aug 18, 2013 | Poulan Pro Lawn Tractor 2006 and Newer...
Need to put drive belt on poulan pro model pb195h42lt
You can search on amazon for belts... take a look: Amazon com Craftsman 42 in belt. I hope this was helpful. Cheers
Sep 23, 2012 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
My poulan pro lawn tractor won't start. when i turn the key it click's 1 time can you help ?
Have you checked the battery terminal connections? Is the battery charged fully? Are you sitting on the seat when you try to crank the mower? Could be any of the above but most likely battery connection or the battery is discharged or old.
Aug 20, 2012 | Poulan Pro Lawn Tractor 2006 and Newer...
Belt is slipping off pulley
your should have a tension spring on the idler pulley. that maintains the tension on the drive belt. check to make sure you have the right belt and that is not worn or stretched out. also check to make sure your variable drive assay is working
Oct 10, 2009 | Poulan Garden
I cant get the drive mower belt on my poulan pro lawn tractor!
The belt you should have bought is part # 140294 and yes, it is longer.
Jul 27, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Cant get mower to go in to drive or revers
check that belt is on the drive train pulleys. belt maybe stretched. look for adjuster to tighten slack out of belt tighten in small increments. hope this helps
Oct 24, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
32 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
