Question about RCA 25202RE3 Corded Phone
Line 1 stays lit
I cannot figure out why line 1 stays lit up red. I have to push line 1 to activate the speaker because if you push speaker it gives you the error beebs
  • savannahsdad Nov 27, 2007
    No, it is plugged into line 1. I've checked all my connections (electrical & phone) inside and out. I've tried unplugging the phone as in a cold re-boot.
Do you have your phone plug, inserted into line 2?
Posted on Nov 27, 2007
Pilot will not light after repeated attemps. Shut main gas line off as book suggested. Re-lit burners and then oven pilot. Pilot only stays lit if holding red pilot button
90% chance your thermocouple is bad.
This should work: http://www.partstown.com/southbend_range/sou1196078
10% chance your red push button safety valve is bad. If it is really hard to push in I would recommend changing that as well.
Jan 27, 2014 | Southbend 4603AA-2TR LP - 60-in Range w/...
I have a Jayco pop up with an Atwood water heater, serial # 37C14U-5. My problem is two-fold. The water heater pilot doesn't stay lit after initial run, and propane is leaking out of the vent on the...
Leaking propane is red flag #1 and fire hazard.
Immediately update your insurance and then turn off gas.
If pilot is not staying lit, then gas leak can be cause of pilot problem since pressure on the line is reduced.
Other causes include bad gas control valve, air in the gas line, bad thermocouple, burner parts need cleaning, or all the above.
After fixing leak, replace thermocouple, clean combustion chamber and burner parts, and bleed gas line to remove air.
More resources:
http://waterheatertimer.org/Atwood-water-heater-resources.html
Jun 28, 2011 | RTO Atwood Water Heater - 6 Gal LP
Avaya Partner line always lit
If the line button is lit then something within the system has picked it up. If the phone is a multiline set, the line 1 light on the set that is using the line will show green. The line could also be held by either a cordless phone on the system or the voicemail system. The easiest way to clear the line (if the held set isn't apparent) would be to cycle down the power to the phone system for a moment. That will clear the line if its held by the voicemail
Jun 02, 2010 | Avaya Corded Phone avaparp18d
So much static I can not hear properly
The line that stays lit for line 2 is just the way it is.. not a problem. If you only have one phone line and a two line phone you will always have the one (non working line 2 ) lit.
Have you replaced the cord to the handset? Many times it is a bad cord that causes static.
May 11, 2010 | RCA ViSYS 2-Line Speakerphone
Line 2 stays lit with red light
I think that just means that you do not have a 2-line connection to the phone. Either your cord is a 1-line cord or your 2-line cord is plugged into the wrong jack on the back of the phone,
Apr 14, 2009 | RCA 25202RE3 Corded Phone
That red line
give more details please.
- case 1 : does it not turn on at all ?
- case 2: or does the screen stay blank with that red line, but laptop still makes noises (a sign for hardware activity and a proper boot up..!, but the lcd monitor is broke then)
- case 3: or do have a steady red line on the display all the time whatever you do in windows?
(your lcd monitor maybe damaged in that area,) you will have to use it that way..then.
you may try to connect any other vga monitor to the laptop's graphic card (the 3 -row pin input in the back of the laptop) to double-check.
In both last error cases, just to see if error is still there (if not, you're lucky, work with the external monitor then.., if yes, it's the laptops' graphics card then, bad luck as in case 1).
check this out, if still problems, please give more prob details - you know where to find us, don't you? :-)
Oct 23, 2008 | Toshiba Satellite A100-S8111TD Notebook
Light comes on
First, it is normal for the line 1 light to quickly flash once every hour or so while it scans all of the phones. If the light is staying on though then this is a problem.
Look at all of the phones. All will show a RED light except for one that will have a GREEN light lit up for line 1. The green lighted on line 1 means that this is the phone that believes it has the right to use the line. When one phone uses the line all of the others are given a signal through a sub carrier of line one to light up in the color red.
I would suspect that the problem phone is a wall phone unit. This is because the switch on this phone is fighting the weight of the receiver versus gravity. There is not much tolerance in these switches as you will notice if you gently put your finger on the receiver at the top of a wall hanging phone.
If it is a wall phone unit causing this problem you can do 1 of 3 things.
1- you can switch this phone to a desktop so gravity is not working against you but for you.
2 - you can put an ugly looking spacer on the button so it pushes in farther.
3- you can try to perform inside surgery on the phone to adjust the tension of the spring on this button.
Jul 05, 2008 | GE 29488GE2 Corded Phone
RCA executive series
No ringer could well be a setting and light on 2nd line means their is No 2nd line and most 2 to 4 lines phones at least require 2 active lines for the system to work correctly
Mar 30, 2008 | RCA 25202RE3 Corded Phone
No Dial Tone
If you are sure that both cords are good (use another phone to test), make sure the Speaker button light is off. If both lines stay lit up when the phone is on the hook, your phones has problems. Can't help you there.
Hope this helps, and please rate my advice.
Nov 24, 2007 | RCA 25202RE3 Corded Phone
BLUE SCREEN
I got this Sony KP-57WS500 57 in TV for FREE from a guy posting it on craigslist because he saw "BLUE SWIRL LINES" also knows as "Retrace Line" on the screen and he went to several repair people and got high repair costs so he was giving it away for free, but i found a guide that tells you how to adjust the tv to make the blue or green or red lines go away, aparantly the line show up because the voltage on the color ray gun tubes that get out of adjustment. Here is the Link to the REPAIR GUIDE. http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Sep 25, 2007 | Sony KP-57WS500 57" Rear Projection...
RCA 25202RE3 Corded Phone Logo
347 people viewed this question
Top RCA Lands Phones Experts
Marvin
Marvin
Steve Allison
Steve Allison
Are you a RCA Lands Phone Expert? Answer questions, earn points and help others
