Question about LG Computers & Internet
T1710BP-BN 17 problem whith TACH
Lt565
Sounds like you need at least one new capacitor in your monitor. Before you check that out, Double check your power cord and make sure it has a good tight connection.
Dec 11, 2011 | LG L1717S-BN 17" LCD Monitor
How do I reset an LG L1751S-BN back to factory settings?
You may reset your LG L1751S-BN to factory settings by:
1. Press the Menu button. OSD (On Screen Display) should appear on your LG L1751S-BN.
2. Press the Lightview +/- button to highlight Setup then press the Auto/Set button.
3. Press the Lightview +/- button to highlight Factory Reset then press the Auto/Set button.
4. Press the Menu button to finish.
I hope this works for you. Kindly reply for further assistance. Good Luck!
Thanks for using Fixya!
Mongkey
DELL Tech ID #456563
TIPS: Is your computer slow? This might help
http://www.fixya.com/support/r8158906-diy_manual_pc_tune_up
(for Windows only)
Mar 29, 2011 | LG L1751S-BN 17" Flat Panel LCD Monitor
How can disassembly LG monitor Flatron L1717S?
MONITOR CAN BE DISAMBLY BY USING SPECIAL TYPE OF SCREW DRIVERS
Jan 12, 2011 | LG L1717S-BN 17" LCD Monitor
Monitor keeps coming up with 'power saving mode' and the green on light turns to orange.
  1. remove the rear cover and the front cover
  2. look at the power supply you will find some puffed capacitors change them by the value
  3. if all capacitors looks good, check the inverter for shorted transistor
Dec 10, 2010 | LG L1717S-BN 17" LCD Monitor
It is showing a permanent white and a blue line vertically on screen
Around here, "previously-owned" 17-inch LCD monitors are available for $50. If you take your monitor to a TV/video technician, it will cost *MORE* than $50 for "labour" by the technician to trouble-shoot.
Buy a replacement monitor, and responsibly recycle the old monitor.
Sep 03, 2010 | LG L1751S-BN 17" Flat Panel LCD Monitor
Power green LED on for a second and nothing more
That is nice, what is now the problem with it?
Regards.
Jul 25, 2010 | LG L1717S-BN 17" LCD Monitor
Horizontal line appears even computer is off.
Unfortunately that means your monitor is in need of repair.Most likely you will have to consider replacin the monitor as a 17$ most likely isn't worth the price of repair.
Thanks,
Lee
May 27, 2009 | LG L1751S-BN 17" Flat Panel LCD Monitor
How can open the monitor Body (Cover)
hello,
it seems that you open any monitor first time i suggest you to if any screw is not present then not to try to open and if screw is present then remove the screw and remove the base also. then see any lock present on the cover. pull the housing upwards and plz unlock the cover very safety and this you may remove the cover
thanks
ramesh722
Nov 13, 2008 | LG L1717S-BN 17" LCD Monitor
Serial number
HAVING PROBLEM WHITH PHONE LOCK CODE FORGOT MY CODE OF SONY ERRICSON K800I
Jun 30, 2008 | Sony Ericsson K800i Cellular Phone
Computers & Internet Logo
48 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
