Question about Sony Audio Players & Recorders
My sony walkman WM EX-190 is playing at low speed than normal. I changed the belt. bot still it is not playing at normal speed.
  • 63 Answers
Its maybe a failed speed ajustment or its slipped there is normally a tine whole on the back under the belt clip, press play and insert a small screw driver and turn u should find it speed up or slows down, if not its failed, but please be careful they are delicate anyhow
Posted on Jun 02, 2015
SOURCE: Sony Walkman WM-D6C
If your WM-D6C has a serial number below 267201 (take out the battery block and you'll see the serial number sticker there) then the problem is electronic, not mechanical. It is likely due to the speed controller chip (labeled as IC601 on the circuit board), which is made by Sony and is type CX20084. This chip decides the voltage that is fed to the motor which is only about 2.4 volts, Should the chip be defective then the motor receives about twice this voltage and thus runs too fast. If you take the back off the recorder you will see the circuit board; it looks like a rectangle with a small square extra bit sticking out to the right. It is here that the IC601 resides. It is about the size of a small pinky finger nail and has 8 tiny legs down each side. Measure the voltage on pin 15 (put one voltmeter probe (+) on the second leg down on the right side (pin 15) and the other one (-) on the battery negative), it should read about 4.8 volts, which it feeds into the base of transistor (Q601) that in turn will then feed 2.4 volts to the motor (if everything is working OK). If the chip is damaged, then the voltage on pin 15 will be close to zero, and the transistor Q601 will not be "held back" and so will feed about 5 volts to the motor. CX20084 is (unfortunately) obsolete, someone in the UK sells them for about $50, but an excellent company in Hong Kong (utsource.net) sells them for $5 (plus $8 S&H). Taking out the old chip and putting in a new one is close to microsurgery, you will need a micro soldering iron (18Watt Antex), a good eye, a powerful magnifying glass and a steady hand, but it can be done - I've done it! There is a possible second reason that could cause the motor to run too fast. There is a pick up coil on the main flywheel called FG901. If this is damaged it will be open circuit and then the only use for your recorder is probably a paper weight. You can test this by going back to chip IC601 and locating pin 1 (top left pin; a small circle on the body of the chip is next to pin 1), Pin 1 is connected to the positive side of a capacitor,  C602 (0.47 microF), check the resistance from the negative side of C602 to the ground (take battery out, and use battery (-) as ground). You should get about 600 - 650 ohms reading. If you get nothing, sorry there is not much you can do about it as these pick up coils are definitely not available. Finally, chip 601 (CX20084) goes bad if you connect the batteries back to front. Good luck. Giles..
Posted on Jan 16, 2009
caroldon
  • 17129 Answers
SOURCE: I have a sony walkman WM-3. It suddenly stopped
Please check for the belts if the battery you have installed is new and the set gives a hum on play. If not you will have to check the power switch, the mechanism switch and the line to the main board.
If the motor turns but not the capstan and the reel then change the belt, the rollers or the pulley. I hope this will get your set back to action. Good day
Posted on Jul 21, 2010
caroldon
  • 17129 Answers
SOURCE: how to replace the drive belt on the sony walkman
Since this is a very small player what is important is to be very careful and delicate to open the rear cover and do the repair. The printed circuit board has to be removed and moved up carefully not to damage or detach wires. Now remove the capstan cap and take out the old belt, check the size with the new one and if OK run in the same direction you had taken out. replace the lid and the pcb carefully and fix the wires according to the same pattern so as not to touch the belt and drives. Now put in a cassette and test. If it works ok with the speed close the rear cover. clean the headd, the rollers and the transport section . Now your tape has been serviced and must work well. Hope my advice helps you . Good day
Posted on Jul 22, 2010
wwga
  • 106 Answers
SOURCE: My sony walkman WM-F63 plays sound from radio mode but not cassette mode, how do I fix it?
replace the belt or clean the heders.
Posted on Mar 22, 2012
wwga
  • 106 Answers
SOURCE: my sony walkman wm-3 is not playing at speed is there a simple adjusment can be made
my walkman wm-fx141 is doing, try the belt.
New tape playing too fast. What do I do to slow it to normal speed?
You have to replace the IC 601, probably burns because of some passive components that must be replaced. "Doctor.walkman @ gmail.com"
Nov 21, 2010 | Sony Walkman WM-D6C Personal Cassette...
Speedproblem. My wm-d6 walkman goes way to fast! More than twice as fast normal speed 4,75cm/s. Is there anything I can do about it myself or is it a component failing? /Mats
Inside the unit, theres a capacitor or something on the circuit board that has a little phillips head screw area on it, that if you turn it either clockwise or counter clockwise, you can adjust the speed of the cassette playback. This is usually a silver metal thing sticking up somewhere inside kind of shaped like a letter "U'. the inside of the "U' is a round insert like I said with a phillips head screwdriver cut out. just turn that inner piece left or right while playing a cassette to your desired speed.
Nov 08, 2010 | Sony Walkman WM-D6C Personal Cassette...
My unused WM-FX 195 doesn't play cassette
Fault with the drive belts, remove rear covers and take sample belt to buy and replace. Might be difficult to get them but in old stocks.
Aug 30, 2010 | Sony Walkman WM-FX193 Personal Cassette...
I have a sony walkman WM-3. It suddenly stopped playing. Do you do repairs ?
Jul 19, 2010 | Sony Walkman WM-D6C Personal Cassette...
Tape speed distorts and slows
motor belts are cheap. try replacing the belt that drives the wheel. this become distorted specially when the unit has not been use for quit long time. if you think its not about belt, clean up the rubber that touches the tape when played, also the tape head with 70% alcohol. hope this help.
Mar 24, 2009 | Sony Walkman WM-FX290 Personal Cassette...
Motor is ALWAYS running on this thing?
No not normal motor shuts off when not in play or other drive functions! we repair that model! want to sell it?
Nov 11, 2008 | Sony Walkman WM-D6C Personal Cassette...
Plays too fast
WMD6C has a pitch control on the back of the unit that can change the speed of the tape, so switch it off, but if that is not the problem then inside the unit it has a servo set speed pot on the main board.
Dave, Electronic Doctors email eledocs@hotmail.com
Nov 08, 2008 | Sony Walkman WM-D6C Personal Cassette...
750 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
