How do i use the hdmi input on my audiosonic hdt909 set top box? not sure what to press on the remote?
5 Suggested Answers
  • 4 Answers
SOURCE: lost remote to freeview set
replace system control and memory control.
Posted on Sep 07, 2008
SOURCE: audiosonic 51cm tv, will a HD set top box work?
nope standard def should though. will say tv does not support hd channels
Posted on Sep 08, 2008
bernardlunda
  • 318 Answers
SOURCE: JVC LT-Z37SX5 no sound when using hdmi connection to HD box
the tv has a configaration that conveys the sets focus on both audio and video performance. full hd resolution of 1920-1080 pixels.
hdmi inputs allow connection of the generation of 1080p sources for the systems which offer 1080p outputs
Posted on Apr 30, 2009
gopakumarg43
  • 74377 Answers
SOURCE: How do I reprogram my tv to get to my HDMI input application?
Click here to download its user manual. It have all details about how to select HDMI and other video inputs.
Posted on Jun 24, 2012
Hi, I have an Audiosonic HDT909 set top box and I cant find the 4 digit brand code for it so I can use the Audiosonic universal remote control for/with it .. the orginal remote is shot ! cheers D
You should be able to use code search on the remote to find a code that works. If a search through all codes stored in the remote control fails, you may have to try a different universal remote control. All universal remote controls do not contain all possible codes.
May 27, 2017 | Universal Remote Control Televison & Video
My digital tv is saying no singal whats the problem and how do I fix it? we have a huge antenna on our roof
1 – Is the NO SIGNAL issue happening on just one TV?
CORRECT INPUT or SOURCE
If it is just one TV that is showing the NO SIGNAL…
-Be sure your TV is on the correct source or input as your CABLE or SAT BOX.
-Press the TV button on TV remote control to turn your TV ON.
-Press the INPUT button on your TV remote control.
-Cycle through all the inputs on your TV.
-Do this until you are on the INPUT your CABLE or SAT BOX is plugged into.
-You should then see the CABLE or SAT programming show on your TV.
HINT: Your TV will most likely list the TV INPUTS as: HDMI 1, HDMI 2, HDMI 3, VGA, Component 1, Component 2, and so on.
If you still see NO SIGNAL on your TV screen, see the next step below…
2 – If you have your TV on the correct INPUT or SOURCE and you still see NO SIGNAL…
CABLE OR SAT BOX NEEDS RESET
-Remove or unplug the power cable from the Cable TV or SAT set top box.
-Keep it unplugged for 2 to 3 minutes.
-Plug the power cable back into your Cable or SAT set top box.
-Give it some time for the Cable or SAT box to power up, get the signal, and initialize.
3 – If you have reset the Cable or SAT box and still have the NO SIGNAL…
UNPLUG THE CABLE GOING FROM THE TV TO YOUR CABLE OR SAT BOX
-Remove the HDMI cable or other cables from your Cable TV or SAT set top box.
-Keep the cable unplugged for 2 to 3 minutes.
-Plug the HDMI cable or other cables back in.
-Give it some time for the Cable or SAT box to get the signal and initialize.
HINT: Make sure all the cables that are connected to your Cable or SAT box and your TV are tight, undamaged, and secured.
4 – If all of your TVs are affected with the NO SIGNAL screen…
BE SURE THE COAX CABLES OR ETHERNET CABLES ARE SECURE or CABLE OR SAT IS DOWN TEMPORARILY
-Be sure to check the ones where the CABLE or SAT come into your home.
-Be sure ALL Ethernet and Coax cables are secure.
-Call your CABLE or SAT provider to see if there is an outage.
-Realign your Dish if you have SATELLITE.
May 10, 2017 | Televison & Video
On my e-motion tv when I switch it on and go onto did it says no signal....help please
Why does my TV say no signal? If your HDTV or Standard TV displays a "No Signal" error message, it may be due to one of the following issues:
  1. Determine how many TV's are affected.
    • If it is one TV, continue to step two.
    • If multiple or all TV's are affected, continue to step five.
  2. Ensure that your HDTV is on the same source/input as your MTS Ultimate TV service.
    1. Press the TV button on your MTS Ultimate TV remote control.
    2. Press the TV/Video button.
    3. Wait 10 seconds.
    4. Repeat steps b and c continually to cycle through all the available source/inputs on your TV until the correct source/input is selected. (ie. HDMI 1, HDMI 2, Component 1, Component 2, etc.) On standard TV's (non HDTV), you may have only 2 choices, TV or Video.
  3. If the source is correct from step two:
    1. Unplug the HDMI cable from your MTS Ultimate TV Set-top Box.
    2. Wait 30 seconds.
    3. Plug the HDMI cable back in.
    4. Wait for the signal to initialize.
    5. Make sure all cables connected on the set-top box and your TV are secure.
  4. If the problem persists:
    1. Unplug the power cable from the back of the MTS set-top box.
    2. Wait 60 seconds.
    3. Plug the MTS set-top box back in.
  5. If you are still experiencing a problem:
    1. Make sure ALL Ethernet and/or Coax cables are securely in place.
    2. Unplug the power from the MTS box labeled 2Wire or Pace as well as the affected set-top boxes.
    3. Wait 60 seconds.
    4. Plug the power back into the MTS box labeled 2Wire or Pace.
    5. Wait for the broadband light to turn a solid green colour.
    6. Plug the power back into the affected set-top boxes.
    7. Wait for the signal to initialize.
Good Luck
Feb 24, 2015 | Televison & Video
How do I pair srp4004/86 philips universal remote control with audiosonic hdt909 HDTV?
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Feb 20, 2015 | Philips SRP4004 Remote Control
Audiosonic hdt909
Posssibly antenna orientation could be a factor. Also, STB suppliers recommend repeating channel search periodically so that missing channels magically appear.
Apr 22, 2014 | Televison & Video
On my Audiosonic HDT909 set top box, I cannot get the picture for channels 9 GO and GEM. I get the audio but no picture.
I have the same problem and searched around and found the solution. It's a hardware fault. You have to take it back and swap it for a different one.
Sep 06, 2013 | Car Audio & Video
I need the maual for this rca tv L37wd22yx6 tv just keeps saying unusable signal and i need the maual
What is the signal source for the TV? Make sure that you are on the correct input. Use the Input button on the remote. If you do not have the original remote, you need one that matches that function. (Often a Source or Input button is not available on the low end remotes.) Check that you have the signal set to Antenna or Cable if you are using the coaxial connection and the source is TV. (Menu > Setup > Channel Setup > Signal Type)
If your source is a computer, use the VGA port not the HDMI port. Computers send a different type of video signal than video set top boxes. The L37WD22 can't interpret the PC signal on the HDMI input.
For a set top box on the HDMI port, the unusable signal message indicates a communication issue. Try pressing the Info button on the remote. If you see an additional message of Acquiring Channel, then the set top box isn't responding to the remote. Check that the device is on and set up correctly to communicate with the TV. (For example, if your set top box offers progressive scan, try turning of that feature with the control for the box.)
The L37WD22 was built by TTE for the RCA label. The manual is available on the TTE support page.
The direct link to the User's Manual in English is http://support.ttetech.com/RCATV/Assets/pdfs/L37WD22_16788070_IB_e-07.pdf .
I hope this helps.
Aug 29, 2011 | RCA Televison & Video
Just set up the tv... have cable going to hdmi 1 and dvd to hdmi 2... checked all wires, but tv saying NO SIGNAL... wondering what am missing. is there a setting i have turn on for hdmi input
On your Sony TV remote, press the "Input" button and make sure you select HDMI 1. Also, check to make sure you HDMI is plugged into your cable box.
Feb 14, 2010 | Sony Bravia KDL-37M4000 37 in. LCD HDTV
i have the booklet tell me what tv dvd or item you wish to control i'll look it up in my book tonyand.michelle@gmail.com
Oct 05, 2008 | JC Whitney - Audiosonic 3-way Custom-fit...
Televison & Video Logo
181 people viewed this question
Top Televison & Video Experts
Electro Med Services...
