Question about Vivitar DVR390H Digital Media Player
Will not charge up
I bought a brand new battery because I thought the old one was finished. But after replacing them and trying to charge the unit it will not turn on.
0 characters
1 Points
My Jukebox will not take the charge
IF you remove the battery does it function the same way? that would indicate that the battery is not connected into the circuit.. loose connection or broken wire.
Aug 26, 2008 | Creative Labs Nomad Jukebox Zen Xtra MP3...
My Sony Walkman MP3 player will not power on. I thought that it was because the charger was broken, so I bought a new one. To my surprise, it was not the charger.
If the battery was completely dead you may need to leave it plugged in for a few minutes for the battery to be charged enough to turn the unit on. Also sometimes the battery can be so bad that it will no longer take a charge. The charging mechanism inside your GPS may not be charging the battery properly either.
Mar 08, 2011 | Sony Network Walkman NWZ-S545 Digital...
Charge not lasting
try discharging the battery completly and i mean dead wont even try and turn on the charge it overnight and see if that helps a bit as far as i know there arnt any batterys you can change with it, and anyway the battery if avalible would cost you about as much as a brand new mp3 player
Sep 16, 2009 | RCA JET S2002 MP3 Player
Archos not charging
You don't say how old the device/battery is. Does it fail right out of the box new? This behavior can be common with an older failing battery. If this occurs in a new device then it is faulty and needs be sent back on warranty.
Aug 18, 2009 | Archos 404 Digital Media Player
Not charging
Try connecting directly to USB port on your computer, NOT a hub. It needs power to charge.
Apr 29, 2009 | SanDisk Sansa c240 MP3 Player
ZVM won't charge
Usually this problem is due to the firmware. If you upgrade the firmware to version 1.62.02, this problem usually will disappear. The older firmwares have problems in recognizing the battery and allowing the battery to power the unit.
Here is what you'll need to do to save your Zen: you will need a charger for the operation. I recommend buying a brand new charger from the Creative Labs website or a used one here, instead of getting an aftermarket one off Ebay. Aftermarket ones tend to cause problems or fail to work altogether.
Plug in the wall charger and USB cable at the same time. Your Zen should power on when connected the charger. Once it is powered on, connect the USB cable to your computer.
If your Zen does not power on when connected to the charger, your unit is dead and its time to replace it or get the motherboard replaced via one of the Repair services offered on this website.
Download the firmware to your PC, then reboot your PC and connect the Zen via USB cable. Open the firmware icon to begin the download.
If the upgrade button on the firmware window is not available, it is also time to replace your motherboard due to corruption of a chip on the board.
Oct 02, 2008 | Creative Labs ZEN Vision:M Digital Media...
New Battery Charge?
This means your unit does not see the battery and is running on AC power only. You need to check and make sure that your battery polarity is correct making sure that positive goes to positive, and negative to negative. If you can attach some photos, that might help also.
Aug 13, 2008 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Zen Vision M battery not charging
The problem was partially solved in that I put my old battery back in and at least it charged properly. I did receive a new battery from BatteryMill and I fitted it and left it charging for 5 hours. However, when I unplugged it to see if it had charged at all it did the low battery thing and then when I tried to recharge it the battery fully charged symbol ame up. I suspect that had I left the new battery charging for say 24 hours it might have charged fully. However, I have decided to send my batteries back and get a refund. The problem must be something to do with a battery memory problem.
Jul 31, 2008 | Creative Labs ZEN Vision:M Digital Media...
Epson P-2000 won't work on battery power
yes, the p-2000 is basically a pile of ****. epson dont do repairs, but offer a replacement for £170! rubbish product, rubbish company, no support! bin it - my second has done the same.... junk!
Mar 17, 2008 | Epson PhotoFine P-2000 Digital Media...
Vivitar DVR390H Digital Media Player Logo
16 people viewed this question
Top Vivitar MP3 & Digital Media Players Experts
Are you a Vivitar MP3 and Digital Media Player Expert? Answer questions, earn points and help others
