Question about IBM x3850 M2 Server
Hot swap drive stuck - IBM x3850 M2 Server
2005 avalanche fan runing truck is off
is the engine getting hot? it will if engine is over temp. if not, possible relay stuck. locate fan relay and swap w another one. try this and let me know.
Feb 16, 2013 | 2005 Chevrolet Avalanche
Crashes.
Since it's not hot the main suspect is the hard drive. I'd recommend swapping the drive out and reinstalling the operating system.
May 20, 2010 | Acer Extensa 5420-5687 Notebook
GW52F Fisher and Paykel Washing Machine Col...GW52F Fisher and Paykel Washing Machine Cold water valve does not seem to be letting any water into the washing machine, so it does not spray rinse or deep...
You are better off swapping the valves over in the machine until you can buy a replacement valve. I've done this for a month or so until I replaced the valve. Works as long as you only use a cold wash and your cold water is not too cold as to make the machine want to add some hot. If it does this then simply press start to clear the fault.
Jan 21, 2010 | Fisher and Paykel GWL11 Top Load Washer
Server XSeries 220
Yes, that is the total amount of hard drive space.
This server was built for speed not for storage.
The xSeries 220 server supports four SCSI hard disk drives. The server does not support IDE hard disk drives. Some models support hot-swap hard disk drives and other models support only non-hot-swap hard disk
drives.
Your server supports four 1-inch (26 mm) slim, 3.5-inch SCSI hard disk drives in the hard disk drive bays. You can install four non-hot-swap hard
disk drives in the models that have the standard non-hot-swap drive cage. You can install three hot-swap hard disk drives and one on-hot-swap hard disk drive in the models that come with the hot-swap drive cage. Both the non-hot-swap and hot-swap drive cages hold a maximum of three hard disk drives.
The calculation at that time was 4 drives with 36.7GB storage.
Even if you find the drives somewhere, they will be very pricy.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Oct 28, 2009 | IBM xSeries 220 (86451SF) Server
I tried the hot swap harddrive and now its having harddrive boot problems. What do i need to know about swapping out the drives?
TOOLS NEEDED
hard drive pins (located at the back of the hard drive)
be sure to pin your hard drives accordingly ,primary drive to master (ma)and secondary drive to slave (sl) if you are running 2 hard drives
or pin the hard drive to cable sellect (cs) if you are running single hard drive
if 2 hard drives running the master hard drive has to go at the end of the ribon cable and the slave hard drive goes into the slot in the middle of the ribon cable.
if you hot swap aka pulled drive wile the computer was on you might be able to do a c mos reset perhaps you are using a usb drive if you are using a usb drive you might have to go through system admin to bring your system back up by using a confirmed drive you have booted up from before.
be sure in c mos that the usb feature is enabled sometimes by defalt usb dissables.
i hope this helped.
Oct 21, 2009 | IBM Netfinity 6000R 8682 Server
The washer will not call for cold water.
if all water supplies are clear, yes faulty switch. make sure you checked the screen on the water supply, both ends.
Jun 14, 2009 | Kenmore 24902 Top Load Washer
When booting up the screen scrolls to ''Auto-detecting AHCI PORT 0..'' then stays there for 5 minutes then displays ''Reboot and select proper boot device or insert boot media in selectec boot device and...
In your BIOS use IDE(IDE mode). This lets the Sata drive run without any special drivers. You loose hot swap and native command queuing.
ACHI(Advanced Controller Host Interface) is for things like hot swap and native command queuing(more useful for servers).
If you plan to hot swap drives later then ACHI is a good option, but requires a driver on windows install. You may be able to change it after windows is installed.
Mar 31, 2009 | Computers & Internet
Is it safe to keep data cable connected without power cable
It is perfectly safe to remove the power cable from a hard drive but leave the data cable connected. Make sure that whenever you want to connect or disconnect the power cable, your computer has been shut down first. You could do it with the computer powered on as well, but this would not be good practice and you may put errors on your drive.
Sep 26, 2008 | Seagate Barracuda 7200.7 ST380011A 80 GB...
New HD in PowerEdge 2600
Put the hard disk in, allow the OS to identify it, format the drive and you'll be all set.
Jul 19, 2008 | Dell PowerEdge 2600 Server
The Screen shows "welcome. Powering up....." and is stuck
Direct TV has been working on numerous software issues. Some patches have been downloaded for TiVo that in some cases have caused problems. In your case, it is more possibly an indication that the hard drive is not running and you have a possible hardware failure. When you rebooted and became stuck on the "welcome, powering up screen", it could be an indication of a software glitch or a hard drive failure. I would go with a hard drive failure. Since this is a Hughes Receiver like mine and you own it, you could try a drive swap with another TiVo drive out of a like receiver. If one is not available, you may have to purchase one. Pre-configured and initialized drives are available from www.weaknees.com. I have no interest in them, but that is where I buy Tivo pre-configured Hard Drives from. You can get replacement or upgrade Maxtor Drives preconfigured from them for this specific brand and model of TiVo DVR. A drive swap would be cheaper troubleshooting. There is also a possibility of a problem with the built-in IDE controller or the power supply on your receiver which can't be determined until you do swap out with a Known Good Drive to eliminate a hard drive problem. If you are able to swap it out and If the good drive works, then your old one has corrupted data and would need to be re-initialiaed and reloaded. If it is an older smaller (35 hour) drive, you would be better off with a new replacment since the loading is a somewhat lengthy process and must be done on a computer running the Linux Operating System.
Nov 09, 2006 | Hughes HDVR2 with 105 Hrs DirecTV DTV...
IBM x3850 M2  Server Logo
19 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
