Question about Sewing Machines
Brother xl-3022.....the top thread is gathering on the bottom bobbin...so its not passing the bobbin & gathers up about 5 times than stops....it also feels very tight when the needle is going up & down...
  • Sewing Machines Master
  • 7,365 Answers
Try a new needle
try turning the bobbin the opposite way
and if these suggestons don't help then it's possible that the seiwng machine may need some type of adjustment or may having a timing problem
Posted on Jul 31, 2013
  • Susan Bussell
    Susan Bussell Oct 30, 2013
    re-thread the machine, if you have been using it then this happens, it jumped the looper. I you ran over something and it won't stitch, change needle. then you did something as above.
SOURCE: Yet another stitch tension problem...
Thank you, thank you! I just tightened the screw on my bobbin case and that instantly fixed my thread tension problem. How on earth are you supposed to know about the little screw?! I thank you so much for the tip!
Posted on Dec 14, 2007
SewExpress
  • 41 Answers
SOURCE: bobbin thread/feed dog eating fabric
This is a very common problem with really lightweight fabric and can often be cured (if doing straight stitching) by using a straight stitch needle plate and foot. The wider needle plate and foot openings on newer machines give the machine/thread a wider area to pull the fabric into the machine. By using a straight stitch plate/foot you remove the wide opening, eliminating the majority of the problem.
Also - try using a specially coated needle (Teflon or other non-stick finish). The thread feeds more smoothly through the needle and the needle more smoothly through the fabric, causing less drag into the needle plate opening.
Hope this helps. Don't hesitate to respond to this if you have further specific questions. We're always happy to help
Happy stitching,
Kim & Linnette
www.sewingexpressions.com
Posted on Dec 03, 2008
  • 5 Answers
SOURCE: Sewing Machine (brother XL 3200)
You may have the bobbin case in wrong.  I have this machine, and I know that it is really easy to put the bobbin case in wrong.  Try taking it out and making sure that the little stop is in the front and it is seated down in there and able to wiggle back and forth.  My experience with this machine, until the other day when my cat knocked mine off the table and knocked something out of alignment, is that it just works.  Any time mine hasn't worked, it has either been dirty, needing oil, threaded wrong or the bobbin case wasn't seated right.  In other words, it has always been my fault.
Posted on May 25, 2009
SewTechWayne
  • 186 Answers
SOURCE: Brother xl-2600I sewing machine thread problem
Try turning the handwheel so the take up lever is at its top position, then remove the garmet.
good luck!
Posted on Jul 30, 2009
  • 255 Answers
SOURCE: thread jams
Hi! I've had this happen to me many times and it is so very frustrating! First, take the bobbin out and also the bobbin assembly and clean the entire area of all lint, fuzz, little bits of thread....get it as clean as you can. Take out the upper thread too. Clean and oil. Change the needle. Make sure you're using the appropriate size and type of needle and thread for the fabric. Take off the needle plate and look for any nicks or scratches. If you've got them, you can get emery cloth from a good hardware store (often in the plumbing department) and polish them out (or mostly out).
Rethread the machine, carefully following the instruction manual. Use your basic, normal settings. Using a scrap of the fabric you're trying to gather, sew a seam and see if everything works ok. You may need to hold the top and bobbin thread firmly behind the needle as you sew the first few stitches (I find this little trick helps a lot to prevent birdsnests).
To gather, sew three parallel lines of long, basting stitches (you really don't need a special foot or special settings other than to make the stitch a long one). Don't backstitch, reverse, or lockstitch either end, and leave the thread long when you cut it. Pull the three bobbin threads and the fabric with gather nicely along them.
Something to keep in mind--if you're trying to gather very sheer fabric on a zigzag machine, you may need to replace the throat plate with the zigzag hole for a throat plate with a single, small hole for a straight stitch. I've run into this situation before, and ended up using one of my antique straight-stitch only machines to do the gathering.
If you don't have a throat plate with the single hole, you might try some light weight interfacing to give some density to the sheet fabric.
Hope this helps!
Posted on Feb 01, 2010
I'm having a problem threading my brother sewing machine model XL 3010
1. Clean up any loose thread in the bobbin area.
2. Pull on the bobbin thread while it is out. It should give a tension that is equal to the top tension of three. You'll have to approximate. Adjust the screw tension on the bobbin. It is the screw nearest to the thread exit hole on the side.
3. Put it back in.
4. Now, the top tension should be at about three. If it still allows a little wad on the bottom of the fabric you can adjust the top tension by tightening a small amount and monitor each time you adjust. The wad should go away.
Oct 05, 2016 | Brother Sewing Machines
Why does thread gather in bobbin area and jam machine
Completely unthread the top and bobbin threads. Clean any lint build up out of the bobbin race assembly using the little brush and some canned air. Check that the needle is inserted correctly...with the flat side towards the back. Then carefully rethread the top and the bobbin threads. Make sure the bobbin is inserted correctly...if it's backwards the machine won't sew properly.
Jun 30, 2014 | Brother PE770 Computerized Sewing Machine
How to put the bobbin case back together on a brother xl 2600 i
I would go to a sewing machine store with it and ask them it it looks right .if I wasn't sure
Oct 10, 2012 | Brother XL-2600I
What is the setting for gathering
Loosen the top tension until you see little loops on the bottom. Lengthen stitch length. Test first on scrap to get it down... sew a line then gather by pushing and pulling the bobbin thread. (don't pull it out!!)
Another way to do it without a special foot is to zig zag over a cord. :)
Once you have the gathers distributed... re-tighten the top tension and test on scrap again... then stitch your gathers in place.
Jul 20, 2012 | Sewing Machines
Bobbin xl5130 is gathering but the stitch on top is fine. how do i adjust the bobbin tension
to adjust the bobbin use the top tension
also try rethreading the machine top, using every thread guide & bobbin making sure to insert the bobbin correctly into the bobbin case
also try changing the needle
May 22, 2012 | Brother Sewing Machines
Brothers Sewing Machine
if its the bottom gathering loosen the top tension and vice versa( make sure its threaded right first bottom bobbin and top)
Aug 15, 2009 | Brother CS-100-T Computerized Sewing...
Brother XL-5130 Sewing Machine
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_XL_5130_5232_5340_EN_208.PDF
Feed the thread thru one of the holes (the hole that will be on top) going from the middle of the bobbin thru to top. pull up about 2 inches, push the bobbin over to start winding and before pressing the foot, hold the 2inch piece sticking up. HOLD TIGHT. after the thread is wound about 25 times, stop winding and snip the 2inch piece level with the top of the bobbin. Finish winding.
Apr 13, 2009 | Brother XL-5130 Mechanical Sewing Machine
Brother Sewing Machine model:CS8150 bobbin thread problems
The top of the machine is not threaded correctly. First raise the presserfot then rethread the machine. Bottom looping is usually caused by a lack of top tension. There could allso be a bur on the hook.
Feb 22, 2008 | Brother CS-8150 Computerized Sewing...
Nov 22, 2007 | Euro-Pro Shark 80 - 7133
Sewing Machines Logo
87 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
