Question about LG Washing Machines
LG Washing Machine WM2032HW displays LE error code & makes a grinding (best i can think to describe) noise during the wash cycle. Starts right after filling.
    Top Expert:
  • LG Master
  • 9,472 Answers
LE error also referred to sensor assembly- HALL switch and/or stator assembly. Replace the assembly by removing the back cover, removing the rotor with one bolt. You have to hold the rotor from turning while loosening the bolt, slide the rotor off of the spline shaft, take off 6 or was it 8, bolts holding the stator, unplug the two wire plugs, and, now, out of machine, unclip the hall sensor and replace.
Reinstall opposite way.
Here is the stator to order.
Here is the sensor to order.
Keep me posted!!
Posted on Jul 31, 2013
dauphine
  • 207 Answers
SOURCE: Washing machine making whining noise during spin only
Yes, bearing, most definitely. It is a cheap part but difficult to replace.
Posted on Apr 11, 2008
IrishDruid
  • 2712 Answers
SOURCE: Grinding noise from hell - no spin, no agitation (except my own!).
Please see the following link for all possible troubleshooting tips:
http://www.repairclinic.com/0088_11_1.asp#Level1_3
Hope that helps! Should you have any further questions,please feel free to post them here.
P.S. - If you find that the solution/answerI provided led you to, or resulted in a fix, please close the ticket with a FixYa!rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on Oct 04, 2008
SOURCE: Whirlpool Calypso Washing Machine
I have the same washer. Over the past weeks I have had all sorts of error codes. In no particular order, I've had: CA, CI, ld, ob, and SL. Had a repair guy come out and put in a new pump. Didn't solve the problem. Had a more experienced guy come out from the same company. We basically tore the thing apart. We found an underwire from one of my wife's bras (she wondered where it went) along with a bunch of lint in the recirculation tube. You can see the outlet of the tube at the top back of the drum. We also found one of her small booty socks inside the tub blocking the drain tube. We fished everything out and it works great again. I have a two foot long cable grabber that we needed to get the sock out of the tub. You'd be amazed at where things can get trapped in these things. So, I spent $230 or so for a pump that I probably didn't need, but the new pump design is vastly superior to the old one so I'm not complaining too much. The company didn't charge me for the repeat visits, which was nice because the senior repair guy was at my house for about four hours at the end of his day. So the more experience guy and I brainstormed about why all the different error codes came on and this is what we came up with.
CA and CI -- These are current fault codes. Either the average draw or and instantaneous draw tripped a set maximum. These were likely caused by the pump trying too hard to pump thru the blockage in the drain line.
ld -- This stands for long drain. The pump must be able to drain the water form the tub within a certain time frame, if not, you will get this error code. Again, likely came from the sock blocking the drain tube. This may have also came on because the washer recirculates the water throught its cycle. With the recycle tube clogged by the underwire and lint, the only place for the water to go was out the drain. With that being clogged as well, the ld code comes on at the beginning of the cycle.
ob -- stands for out of balance. This one confused me a bit, because I was getting an out of balance signal with nothing in the washer. Apparently, with too much water in the tub and the thing sloshing around, an ob signal is very common with the drain clogged.
SL -- is for suds lock. You can get this one if you put too much soap in the thing. It can also come if you use conventional soap instead of high effencicy soap. I only got this one once. This message can also be caused by a faulty pump.
Hope this helps anyone with these problems. I wouldn't have wanted to tackle this one myself, but probably could do it now after helping with the repair last night. I know these machines have a bad reputation, and I wouldn't buy one of these again, but when its working, my wife and I think it does a good job washing our clothes.
Posted on Dec 11, 2008
  • 219 Answers
SOURCE: Grinding noise during agitation on washing machine
check water pump
Posted on Apr 17, 2009
SOURCE: Why is the fault F18 error code on my bosch washing machine flashing?
Open the small flap at the front bottom right of the machine. DONT unscrew the circular white knob yet!!! Use the small black hose to drain the machine into a tray, by removing the small cap on the end of the hose. You will have to use a tray, rather than a bowl because the hose is only short, and keep emptying the tray.(put a washing up bowl next to the machine, so you don't have to carry the tray.) If water does not come out of the hose, then gently unblock it with a piece of wire or fine knitting needle. When water finally stops coming out of the hose, it is time to gently unscrew the white knob anti-clockwise, and pull it forwards. Now you can clear the debris out of the pump rotor, which is behind the white knob. Check with your finger that it can rotate freely, then replace the white knob firmly. Make sure the small cap is replaced on the end of the hose, clip it back into place and put back the cover panel. If this doesn't work then there is a blockage deeper in the machine, and dismantling will be required. Good Luck!!
Posted on Dec 24, 2009
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Stopping during rinse cycle . not spinning. OE light
The code OE is a draining error. The washer has sensed that the water has not completely drained all of the water within 10 minutes and will display this error code. The grinding noise you are describing is most likely a failed drain pump or clogged with foreign debris.
  1. Locate your drain pump access door on the front of the machine.
  2. Clean out the filter area.
If you are unable to resolve the issue by cleaning, I would recommend replacing the drain pump.
Jan 17, 2011 | LG Washing Machines
Dishwashing cycle starts for about 3 minutes then flashing LE light comes on and the machine stops. Why?
Display Condition LE = Motor Error
Possible Cause For Error Occurrence:
Wiring connection is OK?
The Impeller of Washing Pump is locked.
The rotor of Washing Motor is locked.
The Blade is locked.
Remedy:
Check the wiring connection.
Replace the cause of restriction.
Replace the Washing Motor.
Replace the PCB.
Try the following steps:
Unplug the washing machine if you see an LE error on the two-digit display electronic readout. This error indicates a miscommunication between the control panel and wash motor.
Press and hold the "Start/Pause" button on the front panel for five seconds.
Plug the LG dishwasher back in.
Run a cycle. The LE code will clear.
Aug 31, 2010 | LG 24 in. LDF 7811 Stainless Steel...
Maytag neptune tl makes grinding sound and stops at 33 minutes in normal mode and at 24 minutes in quick wash mode
Hello djlampl,
With the lowest spin cycle setting I enter spin cycle in Quick Wash around the 21 minute mark. But first question is do you hear the grinding noise with the tumblers rotating during the wash/agitate cycle?
If you start a spin only cycle do you hear the grinding noise?
Does the washer error code out with an error code to the display? Codes such as dC, uC, Lr?, I assume the machine type is a FAV6800AW is that correct?
Any additional info will help in troubleshooting…..Rich
Assuming the machine type is a FAV6800A/FAV9800A here are some handy links;
The Service Manual for reference. Sears Parts Direct for reference.
Nov 24, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Whirlpool Duet Sport not running it makes clicks and it grinds
A common problem with noises from washing machines has been the under wire that may come out of small clothes. In the washer they can get stuck in one of the inner basket holes and make a scrapping noise, they can actually make there way into the pump and jam the pump, or make a terrible noise when the pump is running. Grab a flash light and have a peek inside the washer for this. Front load washers seem very common to this happen! If the tiny cloth is showing signs of fraying, may be best not to wash it in the washing machine, replace the cloth.=======
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Dec 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
LG Dishwasher making grinding noise then blinking E1 code 10 minutes later
Well done by resolving this problem. The other way to avoid the siphoning problem through the drain hose is adding an air gap valve/connector (available at any hardware store). You can use it even if you don't have a garbage disposal in your kitchen sink. That will assure that you have the proper height of the drain hose.
Hope this helps!
Oct 22, 2008 | LG LDF6810ST Stainless Steel Built-in...
Lg wm2032hw
check the pump filter and if necessary clean it up.
if you stop the programme and hold the start/ pause button for 3-5 sec the programme will cancelled and the drain will work.
if you hear a slow noise from the pump it may be blocked with external objects from your clouthes pocket,
so you need to contact a repairman.
Jan 28, 2008 | LG WD-1280FHD Front Load Washer
Washing Machines Logo
107 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
