Question about Alpine MRP-F300 Car Audio Amplifier
Wondering how to hook up sub to my alpine stereo
3 Suggested Answers
  • 83 Answers
SOURCE: alpine amp and subs questions
it will depend on how you use the 2 alpine subs,, do you know what there individual impedance is [ ohms ] and how you intend on wiring them,,,in series, in parallel, in any case you must maintain the min load in order to load the amplifier properly,,,otherwise the amplifier will operate improperly and allow DC [ direct current ] to pass and fry your subs...so what I really need is more in formation
Posted on Jul 16, 2007
  • 71 Answers
SOURCE: I have the MRP-M1000 amp.
Your best bet will be to wire 2 subs in parallel to the amp. Each sub should be rated for at least 300 watts rms at 4 ohms. This will give you a total impedance of 2 ohms, and your amp will put out 600 watts rms at that impedance. That way, each sub will receive 300 wats rms. I would not recommend wiring subs in parallel, as you will need two 1 ohm subs at 300 watts rms, which are harder to find and will be more expensive. A parallel circuit is the most efficient way to do it.
Posted on Mar 07, 2011
Friend of mines gave me a alpine 3516 power amp, was just wondering if I can hook it up or even use it for a stock stereo
Yes it can be used with most stock stereos. If you've never interfaced an amp with a factory radui before i highly recommend having it professionally installed.
Nov 01, 2016 | Alpine Car Audio & Video
What amp would be better to use with what speakers/sub? I have a KAC-7202 kenwood 920W maximum power (150wX2 RMS, 4ohms) (230wX2 RMS 2ohms) and then the other amp I have is a Alpine MRP-M500 mono power...
I'm using that Alpine right now for 2-12" subs and I have compared it to 6 or 7 other amps this month and most were 4 channel 150Watt/Channel Bridged to 300Watts x 2 and found the Alpine to be superior in both sound quality and loudness. The Alpine has also not turned off even with full volume for hours at a time, Very solid amp I was very surprised due to it's size!
Apr 04, 2013 | Kenwood Car Audio & Video
I can no longer adjust my subwoofer level from my head unit. I used to be able to in my other car but since I put it in my new car I can no longer adjust it? I have the alpine cda-9886.
make sure that before the sub woofer is hooked into the stereo that the settings for the sub are blank that way there is no previous setting once you have hooked up the sub and amp.
Feb 04, 2011 | Car Audio & Video
Hey I have an Alpine CDA-9851 CD Player and was wondering how to hook up my two 10" Kicker subs, since there is no subwoofer connection on the back of the player.
First to start you need an amp something that is a little stronger than your subs. What you want to do is 'T' off your speaker wires into RCA's to hook up into the amp. There is a device you can buy or you can cut some RCA cables. There are a few down sides to do it this way because as you turn up the volume the Subs will get louder and start to distort a lot faster than hooking up proper. The best way to do it is to get a deck with RCA sub outputs. Good Luck
Mar 25, 2010 | Alpine CDM-7874 CD Player
Hi i have brought a second hand car, which was fitted with an Alpine cda9830r stereo, but no user manual, i have found one for a cda9830 stereo, is there a lot of difference in the two, as i have amps,...
Hi stephen my names Josh. Its great you could find a second hand manual for the cda9830 and theres not any difference your manual will tell you need to know about the cda9830r as well. Your amp hook up will be very standard speakers and sub will match very well with the that alpine in your car.
Mar 05, 2010 | Alpine CDA-9830 CD Player
Alpine subs not hitting hard
could it be as simple as bass boost??? maybe you have the subs hooked up wrong... have to have the ohms right.....hopefully this helped
Jan 26, 2009 | Pioneer GM-X962 Car Audio Amplifier
Need to know
I'm assuming that you have an amp that you are installing these to. Its always tricky installing subs of different impedances. Do you have the model number of the amp that you are hooking them up to.
Most likely if you have a 2 channel amp, you would connect one sub to each channel as most amps can handle a 2ohm load in stereo, but don't bridge the amp with these two subwoofers without specific instruction from someone with experience as you will most likely overlad the amp. If you can be more specific with your set-up I'd be able to assist you more.
Mar 30, 2008 | Alpine Type-R SWR-1042D Car Subwoofer
Amps
It comes down to Amperage and RMS, your best bet is to go in and talk to a salesman at a stereo shop. That way he can decide on what sort of power you want and how you wanna use the subs. But 1000amp AMP is probably a good start 4 channel of course. Alpine or SOny make some kick a$$ AMPS
Feb 17, 2008 | Pioneer TS-W3004SPL Premier 12" SPL...
Open Questions:
See all Alpine MRP-F300 Car Audio Amplifier Questions
Alpine MRP-F300 Car Audio Amplifier Logo
23 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
