Question about Cell Phones
Hi, I am having Sanfransisco2 ORANGE, its not booting up even i kept it without battery,sd and sim card for many hours, kindly also mention how to install rom android 2.3.5 (Gingerbread)by FTM mode in the set
Iwant power movie registration key for my nokia e72 imei : 351513041271518,pls send the code: my mail id : vahid.jodat@yahoo.com
Posted on Jul 31, 2013
Bajanguru
  • 7752 Answers
SOURCE: nokia N72
sounds like a manufacturer error....take the phones back to where you bought them from and have them exchanged
Posted on Aug 22, 2008
SOURCE: The FTM mode is on my Huawei phone and will not get off
I have formatted my N70 memory card by using card reader. After formatted it, its not dettecting in my mobile. Please suggest me what can I do for enable my memory card.
Posted on Dec 27, 2008
SOURCE: i have a xt r100 and it is curently in ftm mode
you need to take it in , it stands for Factory Test Mode. software fault. sometimes occurs when accessing bluetooth, telecom will send it to telegistics and get it fixed under warrenty as long as it isnt water or impact damaged,
Posted on Jan 12, 2010
  • 11 Answers
SOURCE: touch screen on my samsung behold won't open anything
http://www.youtube.com/watch?v=HFUrH_6-WmY
try this
Posted on Feb 18, 2010
  • 4 Answers
SOURCE: Hi My ZTE F102 is on FTM mode what should i do...
Hi My zte F102 is on ftm mode what should i do. any body ask me
Posted on Jul 06, 2010
Can I format my Triumph WX435 without an SD card?
you should be able to use it unless your phone runs on the SD card
Jan 18, 2015 | Motorola Mobility Triumph WX435 Cellular...
Sim card not ready
Try going to storage in the settings menu. See if it says mount or unmount SD card. If not just take out sd card n turn off phone. Turn on. Look in menu, see if phone recognizes there is no sd card. If so, good. Turn phone off. Remove battery 5 seconds. Insert battery and sd card. Turn on phone. Allow total boot process before manupulating phone. Go to contacts. If it doesn't read the sd card automatically then press add contact. See if it has add from sd card
Sep 27, 2012 | Nokia E71 Smartphone
My mobile phone received an Orange message saying 'Update error 020146'. All Inbox messages disappeared! What is the cause?
Hi, I have had the same problem, its to do with the merging of Orange and T-Mobile networks to give you better signal coverage, but if you have an old phone or sim card, mine is over 12 years old, it wont automatically update, hence the error message. You need to call 150 from your mobile and ask them to send you a new sim card, which you will need to register when you receive it. Good luck, PS Dont bother going into the shop, they couldnt help me, although you could call from there.
Mar 06, 2011 | Orange Cell Phones
I have the sim card slot in my dell inspiron n5010 laptop but when i am inserting the sim card it is not supporting and the sim card falls inside the laptop.
Is it not a sim card slot.
The slot you are mentioning sounds like a card reader, its used for SD memory cards which you would normally use in a camera.
Cheers
Myke
Nov 11, 2010 | Computers & Internet
So much hanging & Battery Problem
Hi Friend,
Kindly follows the below mentioned Steps
1.Switch off the mobile
2.Remove the battery,sim card and the memory card
3.Hold the Switch ON/OFF button for 20 to 30 sec's
4.Now Replace the battery and the Sim card
5.After it has Switched ON,replace the Memory Card
Thanks for using Fixya
Regards,
Ayyasam
Jul 01, 2009 | Nokia N72 Cellular Phone
Actually my nokia 1600 nothing display in my display did not work properly
Hi Friend,
As you have mentioned that you are not able to view any thing on the display,
kindly check with these steps ,
3.Remove the sim card
4.hold the switch on button for 20 to 30 secs
5. replace the battery and the sim card
6.Check by switch on the mobile
Even after u have checked the above steps u are not able to view any thing on the display,then the problem is with the display,kindly replace your display,u will get a perfect solution.
Kindly check and revert back
Regards,
Ayyasam
Jul 01, 2009 | Nokia 1600 Cellular Phone
Phon is turn on for few hours only
I guess the problem might have occuerd because you must have left your mobile aside without removing the battery for quite sometime... try recharging your mob for about 4-5 hrs... even if the problem prevails then I think that you need to go for a new battery..
Jun 21, 2009 | Sony Ericsson W350i Cell Phone
Need samsung g600 unlocking code
I have just tried it with my new locked to orange g600 and it works fine on all networks.
1-Turn on the phone without sim card .
2-Pull off the battery cover and insert any non-accepted sim card (without turning off the handset)
3-Do full reset *2767*3855# , phone will reboot and goes to Menu .
4-Customize Sp-lock code *7465625*638*00000000*00000000#
5-Unlock your phone with new SP code #7465625*638*00000000#
6-Enjoy G600 unlocked
if it doesn't work after step 3.. try changing the 'non-accepted' sim card that ur putting in..
eg if you are locked to vodafone and you try this method and use an orange sim card and it doesn't work, try using a o2 sim or even virgin :)
its easy good luck
Jan 29, 2009 | Samsung SGH-G600 Cellular Phone
Samsung SGH-U600 lost password
You should be able to reset by turning on the phone without the SIM card inside, entering *2767*2878# and waiting for the phone to reset
Jun 01, 2008 | Samsung SGH-U600
Cell Phones Logo
27 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
