Question about Frigidaire Gallery GLHS66EJ Side by Side Refrigerator
How to remove drip pan from frigidaire gallery side by side refrigerator
fridgetech
  • 473 Answers
SOURCE: when icemaker is filling water comes out door dispenser
I need the entire model # from the sticker inside the fridge section. My guess is this is the model that has a diode in the wiring harness that directs power to the valves and has gone bad letting power go to both valves. I would look and see if you also have water going into the icemaker when you press for water out of the dispenser. If there is no diode then the water valve is bad. I need the model # so I can look at a wiring diagram. You can look at the wiring to the water valve and see if it has a diode. It is black block and has two wires in one end and one out the other. If so the diode only can be bought and spliced in. Let me know so I can help.
Posted on Nov 03, 2007
tborn6
  • 700 Answers
SOURCE: Frigidaire Side by Side Gallery Model Refrigerator
yes where thr water go\es into the ice maker is where the problem lies, take the ice maker out and then you'll see the tuding where the water goes into the ice maker. Then take a hair drier or a shop vac reversed and thae out the utde and the water will flow after it is thawed.
Posted on Jan 30, 2009
SOURCE: drain pan
If u have 2 people u can lean the fridge back and the drain pan unscrews from the fridge from the bottom even though it says "non-removable
Posted on Jul 31, 2009
BIKER T
  • 909 Answers
SOURCE: Frigidaire Gallery refrigerator, evaporator fan not running
As insignificant as it may seem, that evap fan motor is as important as petrol in a car. That fan controls the fridge cooling on many fridges and circulation in tha freezer compartment. Replace it with the correct one and you should see a functional fridge/ freezer again. Note, i wouldnt run unit without it for long, as condensig temperatures run high and compressors dont last long.
Posted on May 23, 2010
heatman101
  • 43501 Answers
SOURCE: refrigerator not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Sep 30, 2010
Where is the drip pan on Frigidaire 18 cu. Ft. Refrigerator
Hello friend, that's a great question!
Typically the drain pan is located at the bottom of your Frigidaire refrigerator. You can look it by removing the toe grille. Hopefully this is helpful. -Matt
Sep 10, 2014 | Frigidaire Refrigerators
My side by side drip"s
The water is from a blocked drain of the defrost, especially with the water off that's where its from. This tip i wrote will tell ya how to clear that drain http://www.fixya.com/support/r9991618-wrong_when_side_side_refrig_leaks_from
GENE
Sep 14, 2011 | Frigidaire Gallery Series GLHS269ZDB 36"...
The drain pan under my refrigerator stinks really bad how can i remove it to clean it
The drain pan can be removed by lifting up the refrigerator and removing the four torex screws on the bottom of each side of the refrigerator. Use 2 pieces of 2x4 to hold up each side of the fridge while removing these screws. After removing the screws the bottom panel will separate from the refrigerator and you can remove the drip pan from the panel as it isn't attached by screws. The pan is VERY fragile and removing the drip pan is a two person job. I recommend just pouring bleach into the drip pan to kill any bacteria causing the smell by removing the back panel which will be held on by several quarter inch screws. You'll see the white drip pan on the right hand side of the fridge looking from the back.
Aug 06, 2011 | Refrigerators
Frigidaire Gallery FRS24XGCW Regrigerator is not cooling. The freezer side is about the temp of the normal refrigerator side.
Remove the grill along the bottom of your refrigerator. Locate the drip pan, using a flashlight if necessary. The pan should be sitting on a set of black condenser coils.
Remove the pan and wash it. Use a mixture of warm, soapy water and bleach to kill the mold.
Reinstall the pan and the grill.
Locate the coils. They look like thin, black radiators and may be underneath the fridge or attached to the back.
If the coils are on the back, pull the refrigerator away from the wall, then vacuum the dusty coils, using the brush and crevice attachments. Reinstall the refrigerator grill.
If the coils are underneath, pull off the grill and remove the drip pan. Vacuum the dusty coils, using the crevice attachment to get between them. Take care not to damage the delicate coils. Reinstall the refrigerator grill.
Mar 01, 2011 | Frigidaire Refrigerators
I have water collecting on the bottome of my side by side refrigerator on the frigerator sided un the crisper.
Hello and Welcome to FixYa!
Actually the leaking water is from the evaporator coil unit....(it is located at the back wall or underneath the freezer compartment). Under normal conditions,Self-defrost refrigerators usually dispose the water generated during the defrost cycle through a tube or channel that directs the water a pan (Known as Drip pan), commonly below the refrigerator unit....
The channel or tube is clogged and the water is leaking to the refrigerator/freezer unit, so you need to clear that blockage/contamination....Once the blockage is removed, the generated water will move through that channel/tube directly to the drip pan and there will no water on the floor in the refrigerator/freezer compartment. This is all you need to do....
Best of Luck,
Your token of appreciation in form of rating would be highly obliged,
Concerned.
Sep 17, 2010 | Frigidaire FRS6R5EMB Side by Side...
The freezer auto defrost puts a lot of water into the bottom of the freezer which in turn just freezes again. Then the next time it dumps more water there and it runs out the door.
There should be a drain hole or line allowing it to drain into a drip pan under the unit. You need to unplug the unit, melt or chip the ice out, make sure the drain is not plugged ( it could be plugged under the freezer.
Sep 23, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Water on the floor left side of refrigerator
well theres a couple of things it will do at that frequency.defrost cycles and may be making ice.defrost water goes down a drain.ice maker fills thru tubes.also the defrost drain could be blocked you would see ice on frezeer floor.you have to us your fingers and trace out those places to find leak
Dec 31, 2008 | Frigidaire FRS23F4C Side by Side...
Frigidaire side by side refrigerator problem
is it coming from underneath or out of the units refrig or freezer bottoms ??
Jan 26, 2008 | Frigidaire FRS26R4A Side by Side...
Frigidaire Gallery GLHS66EJ Side by Side Refrigerator Logo
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
