Question about Sharp AR-M205 Copier
Erreur "e7-15" sharp ar120EN - Sharp AR-M205 Copier
CODE ERREUR U2 appear on screen sharp ar 5316
press # press INTERUPT press C press INTERUPT then put 16 then start then press clear after that the machine will turn off and agin
Jul 27, 2011 | Sharp AR-5316 Advanced Digital Imager...
Code erreur u 2 sharp ar 5316
memory error, pls press the copy key to see what the sub code is...if 04 appears, eeprom problem failure....try to cancel using simulation 16.
Jul 13, 2011 | Sharp AR-5316 Advanced Digital Imager...
Code erreur E7 03 SHARP AR-M350N
E7-03 means that the machines hard drive has gone bad. It can be backed up and replaced by a trained copier technician.
May 22, 2011 | Sharp AR-M350N Copier
H5 erreur sharp AR-5516
if there is a paper jam in the fixing many times this err will be displayed. go to the service mode (C-interrupt- # - interrupt) and enter 14 and then start button.
Feb 05, 2011 | Sharp AR-5316 Advanced Digital Imager...
I have a sharp photocopier AR-5316 flashing error code is h4 how to reset this code and solve the problem
i have a sharp photocopier AR-5316 flashing error code is E7 how to reset this code and solve the problem
Jul 06, 2010 | Sharp AR-5316 Advanced Digital Imager...
CODE ERREUR L4 DANS UNE PHOTOCOPIEUR SHARP 5316
L4 mean this copier main motor is not move or run.
First time, Open your copier back cover and check any gear is broken,solve it .Or clean all mechanical which one jam.If you are not a technician so you call a service Engineer who are qualified this Brand.
Dec 02, 2009 | Sharp AR-5320 Black and White Copier
Sharp AR-M205 Copier Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
