Question about Toshiba 24HV10E 24" REGZA Multi-system PAL NTSC LCD TV - Worldwide
Toshiba Regza Power TV 24HV10E. Power indicator
Toshiba Regza Power TV 24HV10E. Power indicator keeps on and off. No image on screen. remote and side panel buttons not working
  • 309 Answers
SOURCE: My toshiba 50hp66 cant turn on with the remote
What you are reporting does not sound like any problem I have heard before.
I suggest you contact a TV repair guy and have them come out to take a look at your set. You may possibly have an infrared signal/circuit board problem.
Posted on Nov 20, 2009
SOURCE: Vertical red line on Toshiba REGZA 52HL167 tv.
I have this same problem with my 52 inch toshiba regza , The repair shop has said the cost of repair is as much as it is to replace the TV. I am past the one year warranty, but less than 2 year ownership, so Toshiba won't fix the known issue. Solution is don't buy a Toshiba
Posted on Feb 05, 2010
  • 8457 Answers
SOURCE: I have a Toshiba regza LCD 32AV600 TV set. The
Tries reset the tv back to factory setting and the cable box too by unplug,replug it back an hour later.Go to tv menu,go to PICTURE,go down to reset,so the Tuner board it reset it back to the factory setting.This should solved ur problems,not than the tv tuner board that recieve the bracasting signal board have probems.
Posted on Jun 02, 2010
KingDWS
  • 1606 Answers
SOURCE: Regza 32RV530U HD TV, dead,
Generally when you see no life at all the problem will be in the main power section or the power source.
The cheap things to try are just to try another outlet as well as reconnecting the power cord. Sometimes those will be just loose enough. If you are very lucky this is all it is.
Normally when the tv is dead the problem is in the main power section or an internal fuse has popped. The power section requires replacement as there are no easy to fix parts on it. The fuses can be replaced but that may just pop again as the cause may still exist. As an example the power supply could have a problem that popped the fuse so if you replace the fuse it will work just long enough to go out again.
What you need to do is check to see if you have any warranty. This might be Toshiba or perhaps a extended store warranty. If you have warranty then you just need to talk to the store or Toshiba or drop it off to a repair depot or authorized service centre. To find out if you have warrenty you need to dig out your sales receipt and call the store. They will tell you if you are covered and by who. If you are not covered then this becomes a bit trickier. This is not a cheap repair so you need to get a estimate only. You also want to know what the price is of a replacement tv. The repair for a main power board can be over $500 (and more) depending on the model. So there isn't any sense to repair it if it's a hundred or so cheaper to just get a new one. Wish I had a better fix than this for you but there really isn't one.
Posted on Nov 09, 2010
  • 38 Answers
SOURCE: toshiba regza 47" flat screen last night i was
Check your power cable. Unplug it from both ends and plug it back in
Posted on Mar 05, 2011
TV worked 1 day and no sign of power when turned on the next.Toshiba REGZA 42
if no any power indicator at the front panel, check for a blown fuse at the power supply board.
Oct 27, 2012 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Toshiba power tv 24hv10e not working
Someone has to open and check power board first for bad caps and then check for voltages out on that board---place to start.
Oct 15, 2012 | Toshiba 24HV10E 24" REGZA Multi-system PAL...
I plug my video jack of my dvd player to a service use only plug of my toshiba power tv model number 24hv10e, the power not turn off and no display and anything on it just a black screen and even i ca
You may need a dealer to reinstall the TV's operating software in order for it to work again. Applying an incorrect signal to the service port can corrupt necessary files on the TV.
Sep 30, 2012 | Toshiba 24HV10E 24 REGZA Multi-system PAL...
I need how change system
To which system you need to change. Make the system setting to auto. The set will detect the system and will select the correct one.
Aug 18, 2012 | Toshiba 24HV10E 24" REGZA Multi-system PAL...
TOSHIBA REGZA 24" LCD/TV cannot
"JUST PRESS CINEMA MODE ON YOUR REMOTE CONTROL AND SELECT APPROPRATE VIEWING MODE" it might be located under the left of 0 with an image like stretching as indicated on my remote. It is the issue about the overscanning and underscanning of tv using HDMI connection. I have been the same problem as you but I did solved it using this. Hope this would help!
Mar 10, 2011 | Toshiba REGZA 47HL167 TV
TV Won't turn on
hi
go to this site download ur tv manual and see what may be the problem hope it helps it might be kids lock or something to that effect then buttons on tv wont work until reset http://www.nodevice.com/
Apr 19, 2009 | Toshiba REGZA 32XV515DG 32 in. LCD HDTV
Toshiba regza
the best thig and easiest way would be to reset everything and start overthose things have so many differnt settings but to start turn it off then on the right side it has a power button, hold that power button down for 5 seconds and its reset.
Dec 13, 2007 | Toshiba REGZA 32WLG66 32 in. Television
Toshiba 24HV10E 24" REGZA Multi-system PAL NTSC LCD TV - Worldwide Logo
67 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
