Question about Olympus SP-570UZ Digital Camera
Canon pc 1586 1585 1587 - Olympus SP-570UZ Digital Camera
Need help. Flashing E2 and 61 codes. The paper is not jammed and it has a new carterage.
Canon PC-920 Black and White Copier E2 error - Questions ...
www.fixya.com > ... > Canon > Canon PC-920 Black and White Copier .. error code e7 & e2 Cannon pixma mp145 printer error code e7 & e2 E2: Reload the paper correctly and press [Black] or [Color]. E7: The cartridges are not ..
Jul 21, 2015 | Canon PC-920 Black and White Copier
Connect canon xl1e to pc without firewire
The only solution is to install a fire wire card in the spare slot on your pc if there is one available
Oct 29, 2012 | Canon XL1E Mini DV Digital Camcorder
Where can i get exposure lamp for canon PC 920
It is best to check out with the Canon dealer in your area , If you need to find the nearest dealreship check on the official cannon website
http://support-in.canon-asia.com/
http://usa.canon.com/cusa/support
http://software.canon-europe.com/
Jun 05, 2012 | Canon PC-920 Black and White Copier
I want to copy pictures from my PC back to my camera but it won't let me do it. How can I do this?
No it is not possible to transfer pictures from PC to your CANON as the image quality changes. Yes you can transfer pictures from CANON to your PC (because it will auto adjust the image quality by windows). The best solution is to remove the SD card from the camera and put it on your PC. If the camera had a built in memory card...use the software that comes when you by the camera. Install it then transfer between PC-CANON and CANON-PC is possible.
Mar 09, 2011 | Canon PowerShot SD1200 IS / Digital IXUS...
Hi, I have brand new Canon MP140 3 in 1. I am getting the error message &cannot communicate with scanner. Cable may be disconnected or scanner may be turned off. Check status. scanner driver will be...
1. If you are connected correctly (via a USB cable), first be certain that the cable is snug on both sides (PC and Canon MP140).
2. If still a problem, remove the Canon MP140 icon from Printers and Faxes.
3. Then, disconnect the USB cable.
4. Restart your PC and log into Windows.
5. Connect the USB cable.
6. The PC should recognize the Canon MP130 and ask for a driver.
7. Install the driver.
If #6 does not happen, your USB cable could be faulty or may be a problem with USB port or your Canon. Move USB cable to a different USB port on the PC. Replace the USB cable. Try to install the Canon on a different PC to test.
Hope this helps.
Aug 11, 2009 | Panda ANTIVIRUS ED PLT 7.0 1YR 26-50...
Canon LBP 2900 printer problem.
canon printer lbp 2900 fixing error E000 0000 plz solve the problem
Jan 12, 2009 | Canon LASER SHOT LBP-2900 Printer
Free canon ip1700 software
hi sir i need free canon ip1700 software to install my pc plz help me
Feb 16, 2008 | Canon PIXMA iP1600 Printer
Olympus SP-570UZ Digital Camera Logo
306 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
