Question about Quart Stroke Pump F/15-55 Gallon Contain"
What is contain - Quart Stroke Pump F/15-55 Gallon Contain"
    Novelist:
    Scholar:
  • 150 Answers
It means put it in a 55 gal. container. like a drum or barrel.
Posted on Aug 10, 2013
What's E00025-2c0
Error in Cover Sensor (PS14) in M Toner Container
Description Unable to detect opening of the Toner Container Inner
Cover when removing the Toner Container.
Remedy Identify the cause of the error whether it is due to link
mechanism to open the Toner Container Inner Cover or
problem at the Toner Container Inner Cover Sensor side. ?
1. Perform the user mode (Adjustment/Maintenance>
Replace Specified Toner) to check if the Toner Container
Inner Cover opens normally (damage, slide of shaft area,
etc.). ?
2. Check if the Toner Container Inner Cover Sensor is
soiled and the installation of the sensor. ?
3. Check the service mode (COPIER> I/O> DCON> P024
bit9) to see that the output value of the Toner Container
Inner Cover Sensor is changed normally when opening/
closing the Toner Container Inner Cover. ?
If it is normal, the value becomes 0 by rotating the Set-on
Drive Shaft with the attached tool and opening the Toner
Container Inner Cover. When closing the Toner Container
Inner Cover by hand, it becomes 1. ?
3-1. When the Toner Container Inner Cover is not opened
although the Set-on Drive Shaft rotates, check the drive
system from upstream (Set-on Drive Unit -> Hopper Unit
-> Bottle Base Unit -> Toner Container Inner Cover Unit). ?
If it is damaged, replace the damaged part and then
perform step 5 and later steps. ?
3-2. When the output value is not changed normally
although the Toner Container Inner Cover can be opened/
closed, check the Sensor Harness (to see if the harness
is caught, disconnected or physically removed, *including
the Relay Connector). ?
If there is no problem, replace the sensor. After checking
the output value in step 3, perform step 5 and later steps. ?
4. If the problem is not solved by replacing the foregoing
parts, replace the Drum Driver PCB (UN4) and then
5. Clear the error in service mode (COPIER>
FUNCTION> CLEAR> ERR), and then turn OFF and then
ON the main power. ?
6. Replace the toner (reinstall the removed Toner
Container) at least once in user mode (Adjustment/
Maintenance> Replace Specified Toner), and check that
toner replacement can be performed normally.
Sep 24, 2014 | Canon imageRUNNER ADVANCE C5051
How many atoms of hyrdrogen gas in tow moles how
Hydrogen gas is a diatomic substance: Each molecule contains two hydrogen atoms.
A mole of hydrogen gas contains 6.02*10^23 hydrogen molecules, but since each molecule contains 2 hydrogen atom you have 2*6.02*10^23=?
The formula for nitric acid is HNO_3. It contains 5 atoms regardless of the elements
Now, 0.25 moles contain 0.25* 6.02*10^23 molecules oh nitric acid, ans since each molecule contains 5 atoms then 0.25 moles contain 0.25*5*6.02*10^23=? atoms
0.25*1*6.02*10^23 of hydrogen atoms, and the same number of nitrogen atoms and 0.25*3*6.02*10^23 oxygen atoms.
Oct 01, 2013 | Cars & Trucks
I am looking for a high quality ready to drink meal replacement. Which ones are good?
My two favorite ready to drink meal replacements are the EAS Myoplex and the Met-Rx Original meal replacement drink. Both of these products I prefer the chocolate flavor. As far as nutrition goes, they are very similar:
They both contain a high amount of protein (EAS contains 42 grams and Met-Rx contains 40 grams of protein).
They contain similar amount of calories- EAS contains 310 calories, while Met-Rx contains 260 calories.
They both contain 20 grams of carbs with only 2 grams of sugar.
They both contain over 20 minerals and vitamins
They both cost around $3 per drink.
Feb 04, 2013 | Health & Beauty
What are the benefits of green tomatoes?
Green tomatoes provide us with the following benefits:
They contain a large amount of calcium.
They contain a large amount of vitamin c, which strengthens the immune system.
One cup of green tomatoes contains 2 grams of fiber.
They contain large amount of beta-carotene, which helps the body to produce vitamin a.
Jan 17, 2013 | Cooking
Where do you check the transmission fluid?
PERFORM AN ELIMINATION OF ENGINE FLIUD CONTAINERS TO ACQUIRE THE TRANSMISION CHAMBER
The vehicle should only have an engine oil compartment, radiation compartment for antifreeze/ water, power steering fliuds, a water wiper blade spray dispenser compartment, and finally the transmittion fliud container area all situted within the engine entrapment area. Usually, opening the engine for the first time would require observing the fliud compartments that are identifyable from the remaining engine chambers. Observing closely on the fliud container should have written descriptions of what is expected within compartment. For example, the water fliud containers for wiper blades would usually have written lables as wiper blade fliud container, radiantion container would usually have the antifreeze demarkation logos visibly observable when engine is opened. Rely by elimination methods to ascertain the transmission fliud compartment. For example, once antifreze container, wiper water container, engine oild container, power steering fliud containers have been identified, the most like only remaining in the engine would be the transmition fliud compartment. Alternately, every fliud container within the vehicle engine is situated at separate areas. For example, the only fliud container closest to the transmittion chamber is the engine oil compartment. The vehicles usually require more engine oil than transmission fliud. Between both fliud containers, the smallest chamber for fliud oil is usually for transmission perposes in the absence of hydraulic fliud compartments with newer vehicles.
Jan 22, 2011 | 2000 Oldsmobile Alero
Waste toner tank
Here are the steps to replace the waste toner tank:
1. Turn the machine off, and then wait a few minutes for the machine to cool.
2. Open the front cover.
3. Pull the waste toner container out of the machine using its handle.
Note: Make sure that you lay the waste toner container on a flat surface so that the toner does not spill.
4. Remove the container's cap from the container as shown below, and use it to close the waste toner container opening.
Caution: Do not tilt or turn over the container.
5. Take a new waste toner container out of its package.
6. Insert the new container into position and then push it to make sure that it is firmly seated in place.
7. Close the front cover firmly.
Caution: If the front cover is not completely closed, the machine will not operate.
8. Turn the machine on.
Note: After rebooting, your machine will automatically reset the counter for the waste toner container.
Dec 02, 2010 | Samsung CLX 3160fn All-In-One Printer
THE WASTE TONER CONTAINER IS EMPTY BUT IT STILL KEEP SAYING TO REPLACE AND WONT PRINT
There is a sensor that registers the presence of toner in the plastic container. Remove the container and blow out the sensor. Also, the container has a plastic window that can get dirty with toner - clean the container and the plastic window which is part of the container head and screws into the container body. It is better to unscrew carefully and clean with soap and water. Allow to dry properly.
you can also get the service manual to help with future errors and the like from the link below but first try my suggestion:
Canon Service Manual
May 28, 2010 | Canon imageRUNNER C3200 Copier
FULL LIGHT FLASHES
An automatic overflow switch and Container “Full” indicator light are provided to turn the
dehumidifier off before the container overflows. When the indicator light on the control panel
glows, the water container must be emptied. If the light remains on and the dehumidifier does
not begin to operate make sure the float is attached to the water container.
When the condensate water container is full, the indicator lights up.
1. Turn the power off before removing container. Wait 3 minutes for
any remaining water to drain into the condensate container.
2. Tilt the container forward then lift carefully by the handle.
3. Empty and gently re-insert the container.
Important:This water is not suitable for drinking.
Please rate and god bless:)
Apr 24, 2009 | Fedders A7DH45B2A Dehumidifier
How to create labels from excel data sheet
sir u just have to write all info row wise then ur issue will be resolved good luck
Oct 21, 2007 | Microsoft Windows XP Professional With...
Quart Stroke Pump F/15-55 Gallon Contain" Logo
37 people viewed this question
Top Zeeline Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Zeeline Vehicle Part and Accessory Expert? Answer questions, earn points and help others
