Question about Samsung SGH-Z500 Cellular Phone
Freezing Samsung Z500
After turning the phone on and entering the SIM pin code, the phone goes to the stand-by screen as normal then 5 seconds later the phone freezes completely. All the keys don't work and the backlight stays on even when you close the clamshell. The only way to turn the phone off afterwards is by taking the battery out. It also heats up if you leave it on while frozen.
  • 2 more comments
  • Anonymous Nov 11, 2007
    Have the exact same problem. New software? Where do I get it? How do I install it? More importantly, how do I save all the files (images, video) that are still on my phone?
  • ZeeLee Jan 28, 2008
    My phone is doing the same thing. Quick question...is there any way of saving all the photos and videos before doing the upgrade? OR Can the upgrade be done without losing these files?
  • CRAZY_BOY298 Jun 28, 2008
    ncncvn
  • Anonymous Nov 27, 2008
    Mine freezes too. It didn't help when I removed the sim card with the battery still in and changed the settings.
I have a better solution that requires ** cables ** downloading ** bull...
You might need 2 people to do this
- The aim is to let the phone start up and as soon as you can see your wallpaper push out your sim card!...
- so let the top of the battery connect with the phone and keep the back up off the phone, turn the phone on
-when the phone starts up (a bit before it freezes) get some1 to push the sim card out, dont let go of the battery!
- the phone should still be on and working, push the battery and lock it in position without the phone dying.
-your phone should work perfectly ** freezing, NOW GO TO SETTINGS IN THE MENUE AND PLAY AROUND CHANGE EVErYTHINZ!!!
- turn phone off propperly and insert your sim card it should work perfectly, you can change your setting back **w of course
this better work for you too!
chow
Posted on Mar 10, 2008
Hello guys,
i have exactly the same problem.
i did whats written above. it worked. i got to my settings, re-set them. changed other settings too.
turned the phone off, inserted sim card and turned it on again. entrered the sim pin. the phone starts reading the sim, i receive a message and thats when it freezes again. the phone doesnt have time to read the sim. it looks like the received message (which i cant open or delete) is freezing it. i dont know what to do.
any help please??
thanks a lot
Posted on Oct 29, 2008
This completely WORKS. I was finally able to save all the files that I thought were lost forever. I highly recommend trying this if you have the same problem. It's tricky with this Samsung's battery to hold it in place and to knock the SIM out before as soon as the welcome screen comes up. I found it easier to plug the usb connection into my computer, leave the battery off entirely, and turn it on that way. Anyway, it's pretty straightforward and it DOES get the phone working again--which is pretty impressive considering that most places will make you pay a bundle to fix the phone, while more will offer extremly complicated fixes that require soldering irons, etc!
Posted on Apr 15, 2008
    Problem Solver:
  • 7 Answers
Ok , new software will overcome your problem
Posted on Sep 01, 2007
SOURCE:
How can you jailbreak a lg g800?
ow to Enter Unlock Codes on LG KB770: Insert an original simcard and turn phone on Enter sim PIN if required Enter 2945*#770# From the menu that pops up select "SIM unlock" Enter unlock code you received and press OK The phone will then reboot and the unlock is complete How to enter Unlock Codes to LG GB250 & GB220 Power on your phone without SIM card Enter 2945#*505# From the menu that pops up select "SIM unlock" Enter unlock code and press OK The phone will then reboot and the unlock is complete How to Enter Unlock Codes on LG GT505: Power on your phone without SIM card Enter 2945#*505# From the menu that pops up select "SIM unlock" Enter unlock code and press OK The phone will then reboot and the unlock is complete How to Enter Unlock Codes on LG KP100: 1) Insert a not allowed SIM card 2) Press the unlock button 3) Enter the code OR 1. Insert allowed SIM. 2. Booting (Request PIN Code, PIN Code enable) 3. In Idle Screen, Input the hidden number (2945#*20001#) 4. Input the number (above), go back to the idle screen 5. Menu-4.Settings, 7.Security-6.SIMLock Code:-1.Network Unlock Code:-1.Deactivate: 6. Select "1.Deactivate:" Menu, Display pop up " SIM Lock Code:". 7. Input right Unlock code, Display pop up "Deactivate". 8. Reboot, and unlock simlock code How to Enter Unlock Codes on LG KF390 and KF390q: 1) Insert a SIM Card from the network the mobile is locked to and turn it on 2) Insert the following sequence *#865625#; 3) Select 'Unlock USIM' 4) Select 'Network Lock' 5) Insert the unlock code 6) Reinsert the unlock code 7) Select OK. Done! How to Enter Unlock Codes on LG Prada (e.g KE850, etc): 1. Switch the telephone on with Original SIM card inside. 2. Enter SIM pin if required. 3. Enter 2945#*8501# and press the call button (middle button bottom of the screen). 4. SIM unlock mode will appear on screen. 5. Enter unlock code 6. Select Reboot. 7. Switch phone off, and then turn back on again. Phone is now unlocked How to Enter Unlock Codes on LG KE990 / KU990 Viewty: 1. Insert original sim card and turn phone on. 2. Press telephone icon at bottom of screen to bring up the phone keypad Enter 2945#*990# 3. A menu will pop up, select sim unlock: 4. Another menu will appear, select Network lock. Enter your unlock code and press ok 5. The phone will then reboot and the unlock is complete. How to Enter Unlock Codes on LG KG245 (Vodafone Australia): 1. Insert a Vodafone Australia working SIM card. 2. Ensure the phone is charged and then switch the phone on. 3. Optional Step: If the SIM card has a PIN, enter your PIN number 4. Wait for the phone to power up then enter 2945#*7101# 5. Select Menu , then go to Settings > Security > SIM Lock > Network 6. Select Deactivate and enter the 8-digit unlocking code provide for your handset. 7. The handset will be unlocked automatically and will display "Done". This will be confirmed if you can make and receive calls with the Non-Vodafone Australia SIM card. (You will need reception and phone credit with the different network provider) How to Enter Unlock Codes on LG KG800 or TG800 Chocolate: 1. With the phone in standby, enter 2945#*7101#. This will activate the extra menu. 2. Go to: Settings>Security>SimLock>Network 3. Select deactivate. Enter the unlock code How to Enter Unlock Codes on LG C2000: 1. Insert non-Cingular SIM card 2. Power on the handset - phone will display "phone restricted" 3. Select "Cancel" - phone will display "phone restriction code" 4. Enter the SIM Unlock code 5. Select "OK" - the handset is now successfully unlocked How to Enter Unlock Codes on LG U8150: 1. Switch ON your phone with a not allowed SIM card. 2. Compose: 277634#*#. 3. Go to menu "SIM Lock". 4. Enter the unlock code How to Enter Unlock Codes on LG INCITE CT810 Power on phone with original SIM card Type 2945#*810# In the menu that appears select Sim unlock Enter supplied unlock code Your phone is unlocked How to Enter Unlock Codes on LG F2250 Power on phone with Orange SIM card inserted While in the Start menu type 2945#*3311# Return to the startup screen Press Menu key Select Settings > Security
Jun 06, 2014 | Samsung Galaxy S GTI9000 Smartphone
Unfreeze code samsung sgh-A777 AND Procedures
I don't have the Unfreeze Code,you can get that through Only Online Unlock code selling site,You can use the Unfreeze Code to remove the Network lock in the Phone get the Unfreeze Code for your Samsung SGH-A77 Phone from here
Onlinegsmunlock
Samsung 804SS Unlocking Instructions Warning : Do not enter any wrong unlock codes on your Samsung 804SS mobile phones. If you enter over a certain amount of wrong unlock codes on your Samsung 804SS mobile phone, your phone may get hard locked and sometimes become unusable.
Method 1:
1 - Switch ON your Samsung 804SS with a NOT ACCEPTED SIM Card.
2 - Samsung 804SS will ask for "Password".
3 - Enter the Unlock Code.
OR (if the Samsung 804SS shows "Insert Correct SIM Card")
Method 2:
2 - Don't bother about what's being displayed on your Samsung 804SS.
3 - Compose : #0111*CODE#.
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Samsung 804SS is locked to.
CODE: Its the unique Unlock Code for your Samsung 804SS.
If method 2 does not work, you can try method 2 again but this time without any SIM card on your Samsung 804SS.
Jul 09, 2011 | Cell Phones
I bought one SAMSUNg SGH-J700i. When I am trying to poweron the phone it asks for Phone lock password which is 1234 and opened but immediatly it asks for SIM loack password. But I am not awrae of any SIM...
If u enter PIN code incorrectly 3 times, PIN will be blocked n phone will ask you for PUK(Personal Unblocking Key). This is a 8 digit code. If u enter Incorrect PUK for 10 times Your SIM will be lock permanently.
Your cell phone service provider can(Call from other no. n ask tell them for puk of ur no.) give you the PUK code aft3r answering simple security question.
Later enter PUK than enter new PIN, confirm new pin. Go to -Setting
-Security
-SIM lock
-off
Disable SIM n Later Phone Lock
PS:(You have to block your PIN to get access to PUK,
Default PIN- 0000, 12345)
Apr 18, 2011 | Samsung J700 Cellular Phone
Dont know puk or pin code called 2 # then was atempting to put lock &pin or pin code in . now no screen just enter .puk.enterd limit8 hidden # put in ok.then enter new pin, with ok or sos enterd8...
PUK stands for Personal Unblocking Key. This is a uniqueeight-digit code specific to your SIM card. This is required when the PINnumber to unlock your mobile phone is entered incorrectly 3 times. You are thengiven 10 attempts to enter your PUK code. If an incorrect PUK code is enteredafter the 10th attempt, you will block your SIM card permanently and willrequire a new SIM card from your mobile phone provider.
PUK codes can be obtained through the following ways - The PUK code is in your SIM card documentation Starter Pack.If you do not have this then -Please contact your phone service provider.
Your cell phone service provider can give you the PUK code once you give themyour account details and they have confirmed your identity.
Apr 16, 2011 | Cell Phones
SAMSUNG S5233 WHY THEMES IS NOT DOWNLAOD ?
Tired of memorizing new PIN codes? We show you how to change your SIM card's various PIN and PUK codes in less than 5 seconds.
Although most people remember their primary SIM PIN code, those other codes - used for various verification purposes - are never to be found when needed. Below we've included a set of short codes which, when entered on a handset's standby screen, will let you easily change PIN and PUK (short for Pin Unlock Code) codes - but keep in mind, they may not work with all handsets and mobile operators.
More importantly, when changing ones PUK codes there'll be no help to get from the mobile operator if the new codes are forgotten, so make sure to write any changes down alongside the old PUK codes. Also, please note that the codes should be entered without the spaces shown below.
Change SIM Card PIN
** 04 * old PIN * new PIN * new PIN #
Change SIM Card PIN 2 (Write down the new code)
** 042 * old PIN * new PIN * new PIN #
Change SIM Card PUK (Write down the new code)
** 05 * old PUK * new PUK * new PUK #
Change SIM Card PUK 2 (Write down the new code)
** 052 * old PUK * new PUK * new PUK #
Display Handset IMEI
*# 06 #
<a href="http://www.5starandroid.com">Android Mobile</a>
Dec 15, 2010 | Samsung Star GT-S5233 Cell Phone
My samsung B7722, first time insert sim card, after enter pin number, error massage came out "phone freeze, sim unavailable, please contact your service provider" how to settle?
Although most people remember their primary SIM PIN code, those othercodes - used for various verification purposes - are never to be foundwhen needed. Below we've included a set of short codes which, whenentered on a handset's standby screen, will let you easily change PINand PUK (short for Pin Unlock Code) codes - but keep in mind, they maynot work with all handsets and mobile operators.
More importantly, when changing ones PUK codesthere'll be no help to get from the mobile operator if the new codesare forgotten, so make sure to write any changes down alongside the oldPUK codes. Also, please note that the codes should be entered withoutthe spaces shown below.
Change SIM Card PIN
*# 06 #
Oct 03, 2010 | Samsung SYNC SGH-A707 Cellular Phone
Won't turn on without charger attached, but goes blank after
You have a software issue, sounds like it is fried. Call your phone company and get a replacement or exchange shipped out. You cannot fix this manually. Good luck, sorry about the problem
Mar 19, 2009 | Samsung SGH-Z500 Cellular Phone
Vodafone Samsung SGH-Z500 Cellular
need to unlock this.
did the following procedure
1. Turn off your phone, put in a SIM of a provider that it is not locked to, and turn it back on.
2. At the wrong card message, type *#9998*3323#. A message will pop up telling you to press exit, so hit the right softkey. Choose number 7 (or 8 or 9 work, I think). Your phone will reboot and your SIM will work.
3. Type *0141# and then hit call. This will give you a message saying your phone is personalized.
4. Power down your phone and insert a SIM card other than the one that is in it. Power back up your phone.
5. At the SIM code prompt type 00000000, that is 8 zeroes
Apr 18, 2008 | Samsung SGH-Z500 Cellular Phone
it wont fix your fone but the way tp get the pics and photos off is as follows..... u need another bluetooth enabled phone or pc nearby.,
1. turn fone on.
2. once it has turned on to normal wallpaper take the sim card out whilst leavin the battery on. very tricky but is possible ( i did it to get my pics off)
3 once the battery is out the fone should not freeze and will allow you time to transfer the files via bluetooth
Jan 29, 2008 | Samsung SGH-Z500 Cellular Phone
Samsung SGH-Z500 Cellular Phone Logo
407 people viewed this question
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
