Question about Panasonic PV-GS31 Mini DV Digital Camcorder
Pv gs31 playback
I am trying to playback my tape, but when I press play, the screen stays blue. Help please?
SOURCE:
SOURCE: Panasonic ag-dvc30p
dffdggf
Posted on Jan 03, 2008
SOURCE: Panasonic PV-GS500
I had the same problem but without the needing cleaning message on my Pana PvGs12, weird as it sounded, I stopped it but left it on and gave it a whack on my palm and then tired playing it again and it fixed it. But I have heard it may also need professional head repair and that it may be out of alignment too? Try switching from doing it in the camera mode and or in the playback mode. I'd also try the reset button.
Posted on Apr 06, 2008
SOURCE: Please Help with Panasonic PV-GS31
Is there a missing step between 1 & 2? Under Vista, I have a list of about 20 different categories.
Posted on Aug 13, 2008
  • 3 Answers
SOURCE: PV-GS9 mini dv playback problem
I covered several threads that recommended buying a Mini DV cleaner and running it up to 4 times. They also suggested to change to change your video tape as it may have been the cause of the original problem.
These solutions may have worked for many but not me. My camera was becoming progressively worse. It went to blue bars and no sound to no picture at all...just blue. After using a cleaner 4 times I became frustrated to the point I was going to buy a new camera.
However, with the camera still playing, I did the typical guy thing and rolled up my fist and gave it a good hit along side of it. Remarkably it went back to just the blue bars. I hit it again and it went back to a perfect picture. I'm not saying this will work for you and hitting it too hard could make things worse but I was at a point where I didn't care any more and took a chance that paid off.
Posted on Sep 21, 2008
SOURCE: Panasonic PV-GS31 video to PC trouble.
The usb is only used for the still pics and for the webcam. You need a DV cable to upload vid.
Posted on Sep 24, 2008
Panasonic PV-GS39 -- Eats Tape, Reset Button, Playback Problems
ya sounds like a bad tape loader. your estimate sounds about right. tape sensors also go bad so I would have them check it also.
Jun 01, 2009 | Panasonic PV-GS19 Mini DV Digital...
Help!! No playback!!
First try a cleaning tape, if that doesnt work it most likely the tape path is out of alignment and you will have to send it in for repair.
Nov 17, 2008 | Panasonic PV-GS31 Mini DV Digital...
Thick Blue Lines
just forward a blank new tape...5 times if needeed i suggest not to use a video head cleaner..just imagine using a sand paper to the head what will happen..:-)
Aug 02, 2007 | Panasonic PV-GS31 Mini DV Digital...
Help it's going to fast
Your camera has a capstan servo problem which is more than likely being caused by the capstan motor itself.Nothing you can do youself,would suggest bring to service but reccomend getting estimate before repairing.
May 23, 2007 | Panasonic PV-GS31 Mini DV Digital...
Blue bars across video
I have the same problem with my PV-GS14. You have to find the last spot you recorded in, pause it, then switch to record, and just record something for a couple of seconds. Switch back to playback, and it should be fine. Neonlaundry, I read your other posts, and it seems we both have the same problems. If you find a solution, please post it. Thnks.
Mar 13, 2007 | Panasonic Palmcorder PV-GS12 Mini DV...
Dec 30, 2006 | Panasonic Palmcorder PV-GS9 Mini DV...
Tapes wont play in palmcorder vcr mode
just clean the video head and you will get the image.
Oct 31, 2006 | Panasonic Palmcorder PV-DV53 Mini DV...
Acts like it's reconrding, then won't play back. Plays back older tapes with difficulty
You have one of two problems my freind. One could be the CCD sensor or related circuits have a problem in it and most likly a bad capacitor or a CCD imager, or the shutter is bad and sticking. Unfortanatly you really cannot tell untill the unit is taken apart and bench yested. I found a few really reliable folks that will give you a free estamate as I have sent a few peeps to them in the past and with great results. Good Luck http://www.videoonerepair.com/ Or http://www.videotech.com/ http://www.camcorderrepair.com/
Oct 07, 2006 | Panasonic PV-GS31 Mini DV Digital...
Panasonic PV-GS31 Mini DV Digital Camcorder Logo
29 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
