Question about Health & Beauty
What is normal reading for voldyne 5000? - Health & Beauty
Normal range of spirometer reading
Normal spirometry Normal readings vary, depending on your age, size, and gender. The range of normal readings is published on a chart, and doctors and nurses refer to this chart when they check your spirometry readings.
Jul 18, 2016 | Hudson Rci Voldyne 5000 Volumetric...
How I now, wath is my good resoult when I use voldyne 500, wath is my best breath ?
Go to wiki answers. This section is for computer desktops. Not breathing machines.
Apr 17, 2013 | Computers & Internet
MGE Pulsar 5000 - environment fault
Go to enter bouton in front of the ups and read the fault code if it's a temporary fault when you try to read the ups show that you have to press 3s to reset
Aug 29, 2012 | MGE Pulsar MX 5000 (68505) UPS System
Can you show me how to use it?
As volumetric exerciser is related to the breathing or inhaling it is necessary to consult the physical trainer about how to use it.
http://www.aokemergencyroom.com/
Aug 15, 2012 | Hudson Rci Voldyne 5000 Volumetric...
When I put DVD disc in my Norcent DVD Home theatre system DP 5000 ast TV screen ,have a NOT DISC message. CD disk work great. Helpp me what to do,please! Thanks
If it plays CDs but not DVDs then the Laser is failing.
It takes less power to read a CD than it does a DVD.
Your only solution is to see about have the laser replaced, although these are often not available and when they are, it is not normally cost effective to do so.
Jun 29, 2011 | Norcent Technologies DP 5000
What should the druck press read at 60 miles per hour
Hello there
It all depends what is the temperature of the oil ,what gear are you in?
Ususally when you start the Porsche it should read higher because the oil is thicker.After the engine warms up the reading will go down.
At idle you can see almost no press,which is normal(warm engine).
From the Porsche technical book:
"Oil pressure at90oC oil temperature and speed of 5000 rpm -- bar---approx.5,0"
Any other question you are welcome to contact me at
proporsche@yahoo.com
proporsche
Jan 30, 2011 | 1982 Porsche 911
ImageRUNNER 5000 Copier: how to set a password for ir 5000...
under User mode ( round button with * ), choose ID management. The rest is yust the reading from panel.
Pls. rate
May 05, 2010 | Canon imageRUNNER 5000 Copier
Bucks at high ecelerations
May be going into overboost and the sensor cuts off the fuel. Is the boost guage reading higher than normal? If so the waste gate diaphram may be bad.
Mar 08, 2009 | 1988 Audi 5000 CS
NAD 5000 CD player
I FIX MY NAD 5000 CLEANING THE LASER LENS USING COMPRESS AIR
Nov 06, 2007 | Audio Players & Recorders
Health & Beauty Logo
461 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
