Question about Toshiba 62HM95 62" HDTV
Toshiba blinking lamp light 16times - Toshiba 62HM95 62" HDTV
    Top Expert:
  • Toshiba Master
  • 12,223 Answers
Follow this steps and fix it. God bless you
Lamp Problems
Rear-Projection TVs have a lamp, which picks up the picture and projects it on the TV screen. A burned-out or connected lamps are two of the most common problems for Rear-Projection TVs. First, you will want to confirm the bulb is still good. If the bulb is bad then then replace it immediately. Second consult your user manual and verify the lamp and lamp cover are installed properly. Most Rear-Projection TVs have warning light which notify you when there are lamp problems. Again consult the user's manual to see what each light means.
Overheating
Temperature is a common reason why many Rear-projection TVs do not perform well when they get to hot. You may start to see your TV shutting down automatically when it overheats. Here are a couple of things you can do to prevent overheating. First make certain any TV ventilation ports are free and clear of debris and dust. Second make sure the TV has enough room for airflow. Third, the temperature in the room should be around 72 degrees. Due to the high degree of heat generated by a rear-projection TVs, it is not advisable to watch TV on a hot days when you don't run the air condition. This could cause damage to your TV.
Reset component settings. Usually, the problems you encounter with a projection TV may be resolved through the resetting to its factory settings. If you experience inaccuracies in the color, reset the television's PerfectTint/PerfectColor capabilities. Simply press the Menu tab and then highlight "Perfect Color" using your right key arrow. After this, press "Enter" and then "Reset" in order to reset to factory settings. If you have audio / video problems (VCR or DVD player), simply press "Menu" and highlight the "Reset" option.
Posted on Jul 31, 2013
THE YELLOW LAMP LIGHT KEEPS BLINKING NO OTHER LIGHT IS ON AND I JUST CHANGED LAMP
Did you use a Toshiba lamp--Toshiba sets will NOT work right with a generic !!
Mar 27, 2014 | Toshiba 56HM66 56" Projection HDTV
I replaced the lamp on my toshiba 42HM66 and that worked for about 2 weeks. I ordered a new lamp and replaced it. Now the lamp light blinks amber and then the power light blinks green at about 30 second...
You will need to check if the output supply going to the lamp is good. If not the ballast will need replacement. That model is actually famous for haveing ballast issues. You can get the replacement ballast from www.tvcircuitboards.com they also assist with installation assistance if you require it.
Nov 07, 2012 | Toshiba 62HM95 62" DLP HDTV
Red/green lights both blink and tv will on turn on
Are the red and green lights blinking at the same rate or not? If the green light is blinking every 3 seconds and the red light is blinking every 1/2 second, the lamp door is not properly secured. If both lights are blinking at 1 second intervals, try replacing the lamp. If a new lamp doesn't solve the problem, the TV needs service.
I hope this helps.
Jun 23, 2011 | Toshiba 52HM95 52" HDTV Projection...
My 62hmx95 tv power dont go on light just blinks i
hi , ther is a lock out switch which prevents the tv from operating IF the LAMP cover door is NOT in it proper secured place... Check this..MAke sure when replacing the lamp, the main power cord is unpluggged..
Mar 20, 2010 | Toshiba 62HM95 62" HDTV
No picture and the power light blinks
A red blinking light could mean that the lamp timer is at it's limit and it is time to change the lamp. You will also have to reset the lamp timer by pushing and holding down 2-3 buttons on the tv or remote. Refer to your user guide for the proper way to reset and or change your lamp.
Oct 04, 2009 | Toshiba 50H81 50" Rear Projection...
Red power light continuously blinking. no picture no sound.
It could be the lamp went out and needs replacement. The Toshiba website states when this happens to unplug the televison for 10 minutes then plug back in. If that does not work then try another power outlet. If that does not work then call for service
Sep 12, 2009 | Toshiba 57H81 57" Rear Projection...
What are the blinking light codes on a toshiba dlp meAn?
90% of the time your lamp needs replacing.( DLP sets only )
Jun 18, 2009 | Toshiba Televison & Video
Cant find a ballast
The ballast is actually a switch mode power supply that powers the lamp. It is an
integral part of the light engine and is not replaceable. The light engine has a price
tag of $950. If you replaced the lamp with an after market one and not the Toshiba
lamp you can experience the same problem. Some of the after market lamps will
not fire at the same voltage as the Toshiba. The blue led will come on solid and the
yellow blinking. It will try to start 8 times then give up.
Charlie
Sep 29, 2008 | Toshiba 65HM167 65" Projection Television
Toshiba 62HM14
What are the labels on the lights? Timer/Lamp/Service and what color is wich?
Jun 03, 2007 | Toshiba TheaterWide 62HM94 62" Rear...
Blinking red lamp light
blinking red light normally only occurs when lamp needs replacing. one thing to try other than replacing the lamp is resetting the lamp used hours timer (page 33), and if this solves the flashing light you may get some more hours out of your bulb http://tacpservice.toshiba.com/ConsumerProductSupport/Manuals/projectors/MT500.pdf The wheel noise is supposed to be normal and an element of the design - don't think they thought that one through too well. Saying that, if it is all the time and painfully loud then something (possibly the bearing or the housing that the bearing sits in) needs bending back or replacing - toshiba do not suggest any long term solution to the problem at all. Hope this helps please bother toshiba about this, and it may help stop them selling unfinished designs. We must all fight for a better future etc. etc. etc. ;) Hope this helps :)
Mar 08, 2007 | Toshiba TDP-MT500 Multimedia Projector
Toshiba 62HM95 62" HDTV Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
