Question about Apple iPhone 4 Black Smartphone
Can i used my ipone 4 as a wifi modem to my other wifi device?
  • 9 Answers
My Packard Bell T1000 keeps disconnecting from wifi. Can you help?
Hi, try this:
1. Try and restart the tablet. Sometimes it is that simple.
2. Update the firmware and any apps that need updating on the tablet.
3. If the problem persists, check your time and date on the tablet to make sure it is correct.
4. Should none of the former work...
a. Clear out the WiFi data on the tablet.
b. Reboot the modem/router.
c. Once the modem/router is fully 'up' again, reboot the tablet and re-input the WiFi data.
5. Check your internet connection. It may be what is going in and out rather than the tablet.
6. Make sure you have "Data" turned off on the device when using "WiFi" (that is if you have a plan with data through your tablet). If you don't make sure it is turned off, the device can keep trying to switch to "Data" when you try and use "WiFi".
7. Now, if you are still having the problem at this point, and you are sure it isn't the modem/router that is the problem. Then you may wish to try a "Hard Reset" of the device. However, I really suggest saving this as a last option (or last before parts repair/replacement).
May 11, 2018 | Packard Bell Computers & Internet
ADSL modem Configured Gateway 192.168.0.9 by provide. i want to configure DLINK-DIR-816L & use Wifi. How can i configure/connect wifi router with ADSL modem??
I think you need only plug the modem into the router, then plug other devices into the router, or hook up through wifi..
If you want to reply, please click the Comment link.
Mar 03, 2018 | Gateway Computers & Internet
Does wifi require a router? What is the difference between a router and a cable modem? I have activated a network connection, but I don't know how to activate wifi to use my browsers.
Modem- connects to incoming cable or phone line, it creates a connection between the internet your computer or other internet using items.
Router- splits up the connection to the internet to share it with multiple computers, TV's, cell phones, ect. Can be wired or wireless (wifi)
Wifi- wireless connection, it's always a router too because multiple devices work with it.
Now here's the confusing part, you can get any combination in one modem.
Cable modem, no router, no wifi, just hooks up to one wired device.
Cable modem, with router, no wifi, usually can hook up to 4 wired devices.
Cable modem, with router, with wifi, can have 1 to 4 wired devices and has wifi which can connect to hundreds of devices.
You can also get Cable modems with phone connections they use the internet service to connect to the phone system.
To activate the wifi, you usually need one computer to change the settings to set a name and password for your wifi. Then all your other devices will have to be connected to that named signal and use that password to set them up.
Nov 12, 2016 | Computers & Internet
How do I get wifi to work after the service guy has left
If he has activated WiFi, your WiFi capable devices should be seeing an Arris-XXXX wireless network. Just select that network and use the password the service guy has left you.
Dec 19, 2014 | Gateway Arris Touchstone Telephony Cable...
My tablet is saying i am offline and will not connect to Wi-fi
Firstly Check if your WIFI router is working by accessing the WIFI connection from another computer, tablet or phone.
If it does, then use the same WiFi connection settings that it has on your ARCHOS.
You could also try connecting your ARCHOS to a friend's WiFi network and if this works, change your access point parameters to similar ones.
OTHER TROUBLESHOOTING OPTIONS:
1. Check your WiFi router/modem documentation to see if it has a pairing button that needs to be pressed. Some modems have such a button that must be pressed the very first time you try to make a WiFi connection with a new device.
2. If you have to enter a password (a security code of type WEP or WPA) be very careful that you do not confuse a 1 and I (one and letter "I"), a 0 and O (zero and letter "O"), or U and V. These are common mistakes.
3. When entering a security code for your WiFi access, check the box "Show Password" which will allow you to see exactly what you are typing in. This will avoid any mistakes.
4. Some access points use what is known as MAC filtering. That means, the WiFi access point has a list of access numbers (every hardware device has a unique MAC number) which are the only ones allowed to access to the WiFi point. The person managing the WiFi modem/router should shut off this MAC filtering system to see if this solves the problem. It is recommended to shut off MAC filtering in general as this is now known to be an outdated and ineffective system for WiFi security. If you must use it, you can find your device's specific MAC address by going to Settings >Wireless & Networks > Wi-Fi settings > Menu > Advanced. It will look something like 00:16:dc:5e:9e:39.
5. Try temporarily shutting off the encryption system of your WiFi router/modem to see if the problem has to do with the encryption system you are using. The preferred encryption system is the WPA2.
Aug 14, 2014 | Archos Tablets & eReaders
Arris WiFi Modem to lenovo thinkpad t61
As it works ok on your other devices then it may be the software on the T61. Try going to devices - wifi and update the driver.
Jan 28, 2014 | Arris Computers & Internet
Can i hook up 2 computers to the rca dcm425 without a wireless router
RCA DCM425 digital cable modems only have one Ethernet cable located in the back of the device. In order to have two computers connected at the same time you will need to have router. The router will connect to the Ethernet port on the back of the RCA modem and then you can have up to 4 computers connected directly to the router using Ethernet cables. If any of your computers are wifi compatible they will also be able to get online by using the wifi from the router.
Sep 29, 2010 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Apple iPhone 4 Black Smartphone Logo
71 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
David
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
