Question about NEC PlasmaSync 42MP3 42 in. Television
NEC plasma television
Hi, I was messing around with my stereo at the back and may have bumoed some leads and now the tv display is showing red and green colour mostly. There are no blue and yellow colours and I think the aerial is in ok. It is an onkyo reciever. Any ideas? Thanks.
  • 30 Answers
Hi jubbi, actually i'm not sure your problem you describe. So you can go to this link http://www.fastrepairguide.com/plasma-tv-pdp-information/how-to-describe-explain-the-plasma-tv-problem-or-sym.html see your plasma tv problem is it inside this guide?
Posted on Sep 02, 2007
    Genius:
  • 1,153 Answers
First are you in the A/V area? These are the inputs to you set. You also have G/Y, R/pr, B/pb these are for component level, which is for Standared Definition, or High Def. You inputs should be on the input av Yellew, white, red.
Posted on Sep 04, 2007
My nec 42 in plasma tv has a black line coming from the bottom of the tv to the top can this be fix
double check that there is no interverance from the lead (try adiverent lead iv not check or get somwhone to check the internal connections that they are not lose or dirty other wise proceser board us
May 20, 2010 | NEC PlasmaSync 42MP2 42 in. Television
Hi. When I switch on my NEC 42" Plasma (PX-42VM3A), the on light changes from red to green but then nothing happens. I have box-loads of spare parts but would appreciate any assistance in pointing me in...
CHECK FUSE AT Y-SUSTAINER PCB. IF BLOWN, DO NOT REPLACE IT! LOOK AT SCAN CONVERTORS BOARDS. THEY ARE CONNECTED BETWEEN Y-SUS AND PLUGS FROM DISPLAY(LEFT SIDE WITH FACE DOWN, BACK OPEN). SCENARIO: SCANS GOT BURNED(LOOK FOR A SIGNS AT THOSE LONG BOARDS: UPPER&LOWER).FIND ANY IMPERFECTIONS: REPLACE ALL 3 BOARDS: Y-SUS, UP/LOW SCANS.LAST THING: IF FUSE IS OK, CHECK POWER SUPPLY FOR BLOATED CAPACITORS(BIGGEST BOARD IN A MIDDLE OF THE SET) SAME SERVICE POSITION.
GOOD LUCK,
LET ME KNOW HOW TI GOES.
ALEX'S TV?PHILADELPHIA, PA.
Apr 06, 2010 | NEC PX-42VM3A 42 in. EDTV-Ready Plasma...
NEC plasma sync 42mp2 vm2g
If your referring ot an outside antenna or cable, your set does not have a tuner, it is a monitor style. You will have to get a converter box and use the video input ( yellow) (red/wht-audio) on the tv, or the component input ( green, blue, red ) on the tv, provided, the box has the output for it. Most cable boxes have these and the antenna dtv converter boxes do not as far as I know but look into it.
Dec 27, 2008 | NEC PlasmaSync 42MP2 42 in. Television
Thin red line in middle of screen on nec 42 inch plasma monitor
I had the same problem -red, vertical bars along the right side of my Samsung 42" Plasma- and this is what fixed it: Removed unterminated cable.
I had hooked up an HD video camera to the set about two weeks ago. While I disconnected the camera I left the other end of the connector cable plugged into the T.V.. As I've since learned from friends who work in television, this is what's called an "unterminated cable" -meaning one end is unconnected. It can lead to problems with electrical interference and appears to have been the problem in this case; When I disconnected this cable from the T.V. the red bars went away.
So, check your cables. Make sure everything is properly connected and get rid of anything that might be picking up interference.
Dec 27, 2008 | NEC PlasmaSync 42PD3 42" Monitor
I have just purchased a nec px-42vr5g plasma monitor and intend to use it as a tv connected to my sky plus, dvd and wii the guy i bought it from cant find the manual it has lots of sockets etc whats the...
Get the Wii "COMPONENT" cable set. This set has white-red (sound) connectors plus the red-green-blue (component - video) connectors. You can get this cable where they sell the Wii. It will give you the best possible picture with this device.
Plug the Red-Green-Blue connector in their respective sockets on the NEC display (upeer right-hand side). Switch the NEC display to the DTV/HD input (upper right button on the remote).
Please note that this setup does not provide sound since the display does not have speakers.
Use the white-red connectors and plug them into your amplifier or other sound device.
Good luck.
Sep 03, 2008 | NEC Televison & Video
Colour problems
try to go in menu do factory reset ok
Feb 03, 2008 | Sampo PME-42S6 42 in. HD-Ready Plasma...
A Plasma TV
Sorry forgot to say ours is an NEC plasma PX42vp4g/s
Nov 18, 2007 | NEC PlasmaSync 61MP1 61 in. Television
Nec 42'' plasma
Try holding down the 'INPUT SELECT' button, then press the power button on, on the tv at the same time.
Oct 29, 2007 | NEC PlasmaSync 42MP3 42 in. Television
Problem with plasma tv
Something in the path to drive the other half of the screen has failed or is broken. Need some basic troubleshooting information in order to be any more specific, but I've seen this problem before with NEC plasmas. If still under warranty better use it Good luck
Mar 20, 2006 | NEC PlasmaSync 61MP1 61 in. Television
NEC PlasmaSync 42MP3 42 in. Television Logo
114 people viewed this question
Top NEC Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a NEC Televison and Video Expert? Answer questions, earn points and help others
