Question about Retail Supplies
Cash register flashes 0.00 and the paper feed keeps spinning
flexion1
  • 737 Answers
SOURCE: Sharp cash register XE-A41s
Hi. turn key to OPX/Z mode. Press the receipt button. Turn back to REG mode. Now when you want to issue a receipt, press the receipt button.
Mark
Posted on Jun 23, 2008
flexion1
  • 737 Answers
SOURCE: Royal alpha 601 sc cash register
Hmm. That is almost NEVER a paper problem, so forget about that.
It is always difficult to diagnose head problems without seeing the machine.
It can be a dirty thermal head, but that's not common unless something has been spilled on it. If you want to try cleaning the head, open the printer, and find the head. It is usually a small aluminium block that clamps against the paper when the printer is closed. it will always sit against the front of the paper. On that block, you will see tiny lines all very close together. They go to a connector at one end, and a thin black line at the top of the head. Wipe this black line firmly with a dry cotton bud.
Here is a picture of a thermal head:
http://www.jarltech.co.uk/ger_new/new/pix/products/web/printhead.jpg
Just above the light brown strip, you can just see the black line. This is what you would rub clean.
Otherwise, make sure the paper is clamping hard against the head while closed. If the clamp is not pressing with the same force at both ends of the head, then you will miss some printing. Try pressing against the back of the paper at the head while it prints, and see if it prints any more than before, then you know if your'e on the right track.
Hope this helps.
Mark.
Posted on Aug 18, 2008
gavinsx
  • 12 Answers
SOURCE: Sharp Electric Cash Register XE-A203.
Hi whitwall,
Please make sure that you have the right paper roll.
Your machine takes a thermal paper roll, which means it actually burns the print into the surface of the paper as opposed to printing with a ribbon or ink roller like other makes.
The thermal paper will only show a print on one side of the paper, in other words if you do indeed have the right roll and it is in upside down you will get a blank printout.
An easy way to see if it is the right paper hold the roll in your one hand and scratch a line with the thumb nail of your other hand accross the surface of the roll,if you get a black line on the paper then it is the right one, otherwise you have what we call a "bond" paper roll and it will not work in your machine.
If you got the "black line" with your thumb nail, then lift the printer head arm (green lever) place the roll in position with the paper rolling out from the bottom of the roll towards the front of the machine, pull the paper out past the catch mechanism and close the printer ****.Tear off the excess paper and replace the printer cover.
You should be ready to go ahead with sales.
This should solve the problem .
Regards
Gavin.
Posted on Oct 18, 2008
  • 3 Answers
SOURCE: Swintec SW20 Portable Cash Register Paper feeding
I was wondering if you ever found the solution to your issue, as I am having the same one. I have the SW20 Swintec manual and it does not help with troubleshooting.
Does anyone have any ideas?
Angel
Posted on Jun 07, 2010
SOURCE: star tsp100 printer feeds extra paper
check that the paper type is set to receipt and not ticket in the printer properties: device settings.
Posted on Dec 22, 2010
How to change paper
This product uses 2 1/4in (57/58mm) wide standard thermal paper. Use the feed keys only when changing the paper. Do not pull the paper manually.
1. If prompted during use, or when setting up the printer for the first time, open the printer compartment by lifting up on the tabs located toward the back of the register. This will expose the printers.
2. Depending on each sides needs, use the release buttons to open the paper wells and release the print rollers.
3. Place the paper rolls into the paper well so it feeds from the bottom of the roll towards the front of the cash register (not the back). Pull the paper up and past the print heads towards the front of the cash register.
4. Once done, close the printer arms and use the feed keys to advance the paper.
5. To attach the journal roll to the back of the winding wheel, remove the wheel from the comparment. Put a small fold in the end of the journal roll and feed it under and around the tabs located on the wheel. Spin the wheel manually to take up paper slack.
6. Once the paper is attached, place the wheel into the holder in the back of the printer compartment. The part of the winding wheel with two discs should be on the right side.
Dec 23, 2015 | Royal 29445B Alpha 9500ML Cash Register
My shape XE-A207 cash register won't roll out the receipt paper when a sale is made. It is trying to print a receipt but the paper isn't rolling out.
Usually a broken feed gear in the printer. If you can hear the feed motor whirring but no paper movement, it probably needs a new printer.
Sep 07, 2015 | Retail Supplies
How do I change register tape on 500dx electronic cash register
There should be instructions where the paper feeds in. Usually, you follow the rollers with the paper and feed it in. Did you try google.com for you instruction manual?
Nov 17, 2014 | Royal 500DX CASH REGISTER
Paper will not feed
It could be that the cover is not in the rightful position . Push the cover hard down or you feed gear is worn then you need to replace it
Apr 19, 2014 | Sharp XE-A106 Cash Register
I have a Sharp XE A22S cash register. After replacing the paper it just feeds the whole through.
1) make sure tour feed button is not depressed
2)Use the right paper i,e thermal, 57/58 x .....
Oct 19, 2013 | Sharp xe-a22s cash register, thermal...
Sharp xe-a506 cash register wont print after paper change
If you see "HEAD UP" or "PAPER EMPTY" on display, make sure the head lever on the side of the printer is locked in closed position and press CL (clear) button.
If the paper is feeding out blank, make sure you have the shiny side of the paper facing the front of the machine - if no shiny side to paper, you have wrong paper.
If that doesn't fix it, please let me know which side is having the trouble (receipt or journal) and whether the paper is feeding or if you have an error message.
Nov 02, 2011 | Sharp XE-A402 Electronic Cash Register
Problem with paper roll feed - does not finishing feeding through on transaction need to manually feed to get the whole receipt
hi top of the left side on the cash register their is a button its shape like a arrow .it is the paper feeding key if you wont to manually get the receipt press it
Jan 05, 2011 | Sharp XE-A402 Electronic Cash Register
Sharp A203 cash register froze up
hmmmm are you try to install new paper roll?
the paper feed arm didnt lock
open printer cover and again install paper roll
and close the printer arm
then press cl key
Jul 22, 2010 | Sharp XE-A402 Electronic Cash Register
Cash register will not accept new role of paper, when trying to fix it I must of hit something now the roller won't spin and 'error 94' pops up.
For Casio 110/120/130CR E94 = Printer Problem
Normally there are something "stuck" inside the printer or paper feed assy spoilt.
Jul 10, 2009 | Casio Parts Cash Register PC Desktop
Changing the paper feeding roller in a cr 110 cash register
hi. You buy the feed assembly (the whole black plastic part that holds the roller) from a dealer, then it clips into the back.
Mark
Apr 11, 2008 | Casio Parts Cash Register PC Desktop
Retail Supplies Logo
24 people viewed this question
Top Retail Supplies Experts
Electroboy
Electroboy
Patrick Tinashe...
Are you a Retail Supply Expert? Answer questions, earn points and help others
