Question about LG Washing Machines
Model wf-t8517tc drum top cover damage can have a
Model wf-t8517tc drum top cover damage can have a pictures of the top drum cover
2 Suggested Answers
stradeteox
  • 88 Answers
SOURCE: help me to known
If you push in on the door does the error code go away? If so, then it may just need an adjustment. This is a door error code. Probably a losse or faulty door switch. If you are a do it yourself person you can try shimming out the door switch from the inside. You will need to take the top off of the machine to see if you have enougfh room to get your hand down to the switch where it is held on by 2 screws. If there is not enough room then you will have to also remove the door gasket, front control panel and then the front panel to get to it. It may be possible to put a few flat washers between the door switch and the front panel and then put the screws back in to pull the whole door switch assembly back a little bit (therby causing the door to shut tighter). If this does not stop the DE error then the door switch is bad and will need replaced. Your model number does not appear to be a US model, so I do not know the correct phone number for you to order the part if you need one. You will have to call LG customer service (for the country where this model was sold) to get the correct phone number if you need to purchase a part.
Posted on Jan 07, 2009
Purchased the ciss ink system for my epson wf-3540. the ink tubing keeps getting pinched and the ink isn't flowing continuously.
I installed a CISS system in my WF-3640 which is very similar to the 3520. I just leave the top open and put a small piece of white eraser in the slot where the cover peg would go into. That way the printer thinks the top is closed. Yo can print, scan, copy, fax, etc., with the top open.
Oct 05, 2015 | Epson WorkForce WF-3540 All-in-One InkJet...
A great deal of fluff is appearing on the washed clothes. The machine is an LG WF-T1391TP top loader, 15kg.
If you told us the make and model of the machine maybe someone could help?
Aug 12, 2015 | Washing Machines
LG washing machine model WF-T753A drum off balance and hitting sides even while empty. Called tech who said perhaps a support leg/suspension leg broken or spring broken. Took weight off drum to remove and...
things that you can check. Is the machine level ( use a spirit level in both directions) and 2 are the adjustable feet adjusted so that the machine dose not move from corner to corner Check the insulators at the top of the drum support rods as they crack and allow the drum to sit off centre. You may have to remove the agitator and inner drum as thee may be a build up of mud in the bottom and sides that is causing the problem. If the bearings are failing you will have a very loud rumble on spin cycle.
Aug 16, 2013 | LG Washing Machines
I have Model WF-S6607?WF-S6607TC. Washing Machine. Loaded the clothes, pressed the POWER button, pressed the WATER LEVEL button, pressed the PROCESS button, and pressed the START/PAUSE button, But few...
This might be Lid cover open protection. There is a small magnet at the edge of the lid cover, housed in some sort of a catch.
If the plastic housing cracked, the magnet might have dropped into the washing drum. To overcome this, place a magnet on the position where the plastic catch will contact the washer when the lid is close.
Apr 04, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Help me to known
Jan 07, 2009 | LG WD-1280FHD Front Load Washer
LG WF-T753A Top Loader washer hot water inlet valve
Just found this whilst looking for known issues with my machine as the cold water won't stop when filling.
http://safemanuals.com/user-guide-instructions-owner-manual/LG/WF-T753A-_E
Aug 25, 2008 | LG WFT1071TP Top Load Washer
LG WF-764STP
Remove the belt and check whether the motor spins and let us know with your result. Good luck !
Aug 16, 2007 | LG WFT1071TP Top Load Washer
Washing Machines Logo
19 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
