Question about SAMTRON 55V 15" CRT Monitor
The value of D607
The value of diode D607
The value of diode D607 is in 1N4148,100V,200mA,DO-35,TP.
Posted on Sep 01, 2007
SOURCE:
No sound or display on Pioneer sx-2300
I have a pioneer sx-2300 in my case the symptoms were powers on you could hear relay click but no output and display was spazzing out flicking on and off or partial image on display I found a fried diode in 5 v section of power supply labeled (D607) on pcb. Replaced and that seemed to do the trick. Hope this helps someone. People always say “ fuse “ or “loose connection “ sometimes this is the case but in my experience it’s usally a little more advanced issue than that.
Jun 09, 2017 | Pioneer Audio Players & Recorders
What the voltage value of zener diodes? (D825, D826 red,red,gray) and D823 (red,yellow).
This table is the information used by MOST diode manufacturers that use color banding on diodes. Most manufacturers stamp the ID right on the diode but some do use color banding as the method of identification. For purposes of alignment, the side with any color band closest to either side of the diode is the equivalent of the left side of this table. The three examples in the table when associated with the values in the lower table, are identified as 1N64E for the top diode, 1N452G for the middle diode and 1N4762 for the bottom diode.
See the color coding
25789975-o5icj23xic0ud0c1fg3qznri-3-0.jpg http://electronicshelponline.blogspot.com/
Jul 20, 2015 | Panasonic Televison & Video
What is the value of D607, in a lc320em2 tv
To know more about this, you have to download the repair manual to your set. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box.
Jun 07, 2014 | Televison & Video
Short internal power supply
please check for any blown fuses, if there is replace with the same value, do not replace it with a higher value. also check resistors near the rectifier diodes, check full wave diodes & ic regulators, if you find an error replace with the same value or specs.
May 30, 2013 | QSC Audio Players & Recorders
LG 32lh200 power supply failure common problem
You might try to follow the diode back to the source and read voltage to know the value of the diode and also look on the diode for generic number--short of that Google the model number with "parts" as it might be cheaper to replace the board than try to fix it by guessing values.
Aug 27, 2012 | LG 32LH200C-A1 LCDTV 32LH200C 32inch Wide...
The problem is power out put voltage diodes are completely burned I not getting the value of the diodes The voltages are 72v 50v 6.3v 13v -12v These are out put voltages .so please sending me...
hi;
  1. Diode: UF4007, 1000V 1Ampere ; for 72V
  2. Diode: GUR460L, 600V, 4Ampere : for 50V
  3. Diode: UF5404,400V, 3Ampere: for 6.3V
  4. Diode: UF1G, 400V, 1.2Ampere: for 13V
  5. Diode: TVR10G, 400V, 1Ampere: for -12V
Nov 12, 2010 | SAMTRON 55V 15" CRT Monitor
Volt value of the zener diode no-UZL-30L
That part can be purcahsed from tritronincsinc.com for $1.07 using part number 8-719-934-21.
Or the substitute can be ordered from BDENT.COM using part number HZS30L for .33 each.
Dan
Mar 26, 2009 | Sony Audio Players & Recorders
UNKNOWN VALUE OF VOLTAGE ZENER DIODES
I was not able to find any service or schematic for this model. The colors means that the value is 22.6 volts zener diode with the other blue band indicating where the cathode is.
Could you tell me where or what other components this zener diode is connected to?
Jul 02, 2008 | Televison & Video
Samsung HT-X30 psu diode blown
The surest way is to get a schematic and get the value from there if you can't get a number off the diode itself.
May 28, 2008 | Samsung HT-DB120 System
SAMTRON 55V 15" CRT Monitor Logo
Top Samtron Computers & Internet Experts
William Miller
William Miller
Ekse
Richard Lilja
Richard Lilja
Are you a Samtron Computer and Internet Expert? Answer questions, earn points and help others
