Question about Whirlpool Duet GHW9150P Front Load Washer
My front loader washer whirlpool codes fdu and the door won't unlock.
  • haat62656 Apr 02, 2009
    Thank you, But All it was, was that my son button had broke off and got **** between the door and the machine. I had to push the door shut real hard the cancle the machine then it open. hope this met be a help to other people.
    Sergeant:
  • 254 Answers
F/dU error means --------- Door Unlock Error
A Door Unlock Error occurs if the door cannot be unlocked. It will try to unlock the door 6 times before displaying the error. -------- to resolve the error --------- Door Lock Mechanism broken. My front loader washer whirlpool codes fdu and the - globul1a.gif Check Door Lock/Switch Assembly for foreign objects globul1a.gif Check Wire Harness connections to the Door Lock/Switch AsseMy front loader washer whirlpool codes fdu and the - globul1a.giftral Control Unit (CCU) globul1a.gif Door Lock/Switch Assembly Failure
Posted on Apr 01, 2009
SOURCE:
What does F09 mean mean for a whirlpool AW0 3561 front loader?
Washing Machine Fault Cod Fault
FH No Water Inlet
FA Aquastop Failure
FP Drain Failure
F5 NTC Failure
F6 Tachometer Failure (no motor movement detected)
F7 Triac Short Circuit detection
F8 Heating Element, Open Circuit
F9 Overflow Failure
F10 Motor control unit (Thermal)
F11 Communication failure
F12 Heating Element Short Circuit
F13 Dispenser Circuit Error
F14 EEPROM Failure
F15 Motor Control Unit Error
F16 Control Failure (Control Unit)
F18 Control Failure (Control Unit)
F20 Control Failure (Control Unit)
F21 Control Failure (User Board)
F22 Control Failure (User Board)
FDL Door Lock Error
FDU Door Unlock Error
Whirlpool Washing Machine Fault Codes
So the answer is Overflow Failure
Apr 13, 2015 | Whirlpool Washing Machines
Cycle does not complete - code d appears
There is no code D that I know of . There is a code FdL and FdU (door lock, door unlock) If you remove the front cover below the door (three screws at bottom of machine) taped inside on the wall of the cabinet should be the technicians packet that shows all the codes and their meaning. Good Luck.
Feb 16, 2011 | Whirlpool Duet GHW9150P Front Load Washer
FRONT DOOR WILL NOT UNLOCK
This advice is for Kenmore Elite and Whirlpool Duet model front loading washers. If you experience a problem where the door becomes jammed and will not unlock or open, here's an easy way to gain access inside your washer WITHOUT calling the repairman.
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" "DLE" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How do I unlock my frontload whirlpool duet washer
Aug 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a front loader and the door wont unlock
The latch may be broken.
Here are the instructions to manually unlock...
(tip courtesy JSRock)
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Mar 29, 2010 | Kenmore HE2 Plus Front Load Washer
It won;t power up at all, clothes... Solve It won;t power up at all, clothes are locked inside, no lights on the panel. Plug in is working, I... (More) It won;t power up at all, clothes are locked inside,...
Jul 04, 2009 | Kenmore HE2 Plus Front Load Washer
Will not lock, seems to be in the locked position. DS pushed "something" in that should be out.
You'll need to manually unlock it.
May 26, 2009 | Kenmore Washing Machines
Simpson front loader model 45S651D i can't open the door. its having trouble finishing cycle now it has i cant open it!
Jan 28, 2009 | Washing Machines
After a cycle my door does not open on my LG front loader
Jan 26, 2009 | Washing Machines
Kenmore 45986 door lock
Jan 25, 2009 | Kenmore 43142 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
1,092 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
