Question about Hampton Technologies Brinks Timer
Brinks lamp digital timer 44-1070 - Hampton Technologies Brinks Timer
3 Suggested Answers
SOURCE: Need how to use my timer. Brinks digital plug in
Manual appears on following links:
http://waterheatertimer.org/Woods-timers-and-manuals.html#Brinks
http://waterheatertimer.org/pdf/Brinks-44-1020-manual.pdf
The manual has important illustrations, and has more words than allowed for free answer.
Open manual and get as far along as you can, and then add a comment where manual is confusing and I will help.
The battery is rechargeable type, so plug timer into outlet for hour and then unplug timer to set programming.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Mar 02, 2011
  • 5089 Answers
SOURCE: Can I use a 60W bulb in my lamp that I plug into the timer
Yes. Brinks timers will work with 60 watt bulb.
http://waterheatertimer.org/How-to-set-timers.html
Posted on Sep 17, 2012
Brinks model 42-1050 manual?
Brinks timers and manuals: - Water Heater Timer
waterheatertimer.org/Brinks-timers-and-manuals.html
Brinks timers and manuals. ... Brinks 44-1020 manual · Brinks 42-1020 manual ·Brinks 42-1020 instructions ... 42-1050 yard stake · Invisa timer 52-9206 · Brinks ...
I need an instructions guide for Brinks timer 42-1050 - Fixya
www.fixya.com/.../t10900275-need_instructions_guide_brinks_timer_4...
Nov 28, 2011 - SOURCE: Brinks model 44-1050 digital outlet timer- I don't. I have an instruction for a Brinks 44-1030 which I believe programs the same.
Brinks-outdoor analog stake timer-42-1050 Timer will not ...
Dec 14, 2015 | Hardware & Accessories
My brinks 44-1020 digital timer was set up right and dose not work. i bought a new one and that one also dont work am i doing something wrong or is there a lil trick to it
1) I posted Brinks 44-1020 manual
Folks can order Brinks manuals from hamptonproducts.com
2) Manual shows phone number for defects 800-562-5625
3) I test timers, and some arrive defective, and people occasionally tell fixya they got 3 bad timers in a row. I tell them buy different model: for example buy quality timers at Lowes and Home Depot
4) Timer manuals have more words than allowed for free answer, but I suggest you write out steps shown in manual. Most timers have same basic steps so once you know how one timer works, all other timers work same way. This will eliminate human error as possible cause.
5) Here is a list of common problems with timers:
If plug-in timer doesn't work
a) Check receptacle for power
b) Check lamp is turned ON
c) Check bulb is good.
d) Check tabs or pins are set
e) Check override switch pushed fully in position
f) Try timer in different plug and with different lamp
g) Test circuit with inexpensive circuit analyzer from hardware
h) Don't exceed maximum wattage
i) Programmable: check for overlapping programs, and conflicting days.
j) Programmable: write out programming steps
k) Outdoor with photo cell > test with black tape over photo eye
l) Turn photo eye away from light source
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Feb 14, 2011 | Hampton Technologies Brinks Timer
Got a brinks EZ- dial timer model42-1034B @ Walmart a few days ago can not seem to get it to work, Inst, seem so easy too. I read on some forum online someone thought the am/pm may be backwards to how it...
1) This Brinks timer is a bit lightweight for an appliance (unless for coffeemaker or tiny gerbil-feeding motor)
You might need 1/3 HP (horsepower) appliance timer like Woods 59201
http://waterheatertimer.org/Woods-timers-and-manuals.html#59201
http://www.amazon.com/Woods-59201-Appliance-Grounded-3-Prong/dp/B001Q9EFTQ
Intermatic HB113C is for heavier appliances
http://www.amazon.com/Intermatic-Hb113c/dp/B000GHKO6C
http://waterheatertimer.org/images/Intermatic-HB114C-plug-in-4.jpg
2) How to set the Brinks:
I will use lamp as example since you can easily test the timer using a lamp.
Turn lamp ON. Make sure bulb is good.
Leave lamp turned ON and plug lamp into timer.
Move slide switch one direction.
Plug timer into outlet.
Manually rotate timer dial clockwise and see if lamp turns on-off
Move slide switch other direction, and rotate dial clockwise again to see if lamp turns on-off.
Now you know which way switch has to be moved.
Push down trippers and rotate around dial until they line up with 1:00 on dark part of dial and 5:00 on dark part of dial. Dark is for pm hours.
Last step: Set current time: rotate dial clockwise until current time lines up with arrowhead located on inner dial
Dial rotates at time passes, trippers push lever that turns circuit on-off.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Jan 29, 2011 | Hampton Technologies Brinks Timer
Please assist me in setting this light timer. brinks-42-1020
Instructions for Brinks 42-1020
1) There are plastic segments located around outer edge of timer dial.
These segments divide each hour into 15 minute periods.
Push segments down like a piano key for all hours you want timer ON-or-OFF
2) Push switch to Auto ON -or- Timer
3) Turn lamp ON, make sure bulb is working, plug lamp into timer.
4) Plug timer into wall.
Manually rotate timer dial clockwise to observe light turning on-off.
This action will say if light is ON when segments are up or down.
5) Unplug timer, and set segments for times you want lamp to turn on-off.
6) Rotate timer dial clockwise until current time lines up with arrowhead located on inner dial
7) Plug timer back into outlet. Dial rotates as time passes, segments click a switch that turns lamp on-and-off.
Add a comment for more free help, or to further clarify this free answer.
For a price, fixya expert speaks with you over phone while you work on timer or any do-it-yourself project.
Jan 11, 2011 | Hampton Technologies Brinks Timer
How do i set the Brinks 44-1040 timer?
Brinks 44-1040 is a 24-hour plug-in timer, with 1 on tripper and 1 off tripper.
Dial has 24 hours with each hour marked for am and pm times.
Push tripper down and rotate until tripper aligns with time you want for ON and OFF.
Rotate dial until current time lines up with arrowhead located on inner dial.
Plug lamp into timer. and plug timer into wall.
Move slide switch one direction or the other to control mode.
When switch is one direction, lamp in ON all the time.
Move switch other direction, and timer programs work.
Dial rotates as time passes, and trippers move on-off lever that turns lamp ON-and-OFF.
Dec 24, 2010 | Hampton Technologies Brinks Timer
Hampton Technologies Brinks Timer Logo
126 people viewed this question
Top Hampton Technologies Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hampton Technologies Hardware and Accessory Expert? Answer questions, earn points and help others
