Question about Canon imageRUNNER 5000 Copier
Please.. how to fix error code 607 for canon ir5000
  • 168 Answers
SOURCE: IR5000 bloque
this is a code for detection of no or faulty charge to the drum open front door remove toner hopper take out primary charge unit see if any wires are broke on grid , then see if the wires underneath the grid are still there... if all seems ok gently clean the grid with cloth and windex then clean wires underneath dont break grid wires . put it back in let me know
Posted on Dec 23, 2008
Douglessd
  • 284 Answers
SOURCE: Error code E000020-0000 in canon iR5000/6000
I found this solution. It seems to indicate a tonner problem.
http://www.copytechnet.com/forums/canon/7278-what-e000020-0000-a.html
Posted on Aug 26, 2009
Testimonial: "thanx...."
  • 39 Answers
SOURCE: Error Code 00532-0002
The problem is in the stapler unit which is in the sorter unit. If you are tech savey then pull it out and removed all of the bent staples.
Posted on Dec 17, 2009
SOURCE: CANON IR5000 ERROR CODE E000002-00000
NEED HELP WITH ERROR CODE E000246-0005
Posted on Dec 21, 2009
SOURCE: how to remove error E000013-000 canon IR5000 Photocopy mashine?
Waste toner feedscrew (locked)It is likely that the feedscrew inside the waste toner pipe is preventedfrom rotating because of some fault. If the outlet of thewaste toner pipe is clogged with toner, remove the waste tonerdrive unit, and remove the toner. If otherwise, try turning the mainmotor clockwise by hand. If the screw rotates, wait and see whathappens; if the screw does not rotate, replace the waste toner feedingunit.
Posted on Feb 15, 2012
How to solve this e000061-0001 error
Hi
The description for this error can be found here:
Error Codes Canon iR6000 Code E061 0001
and is the same for both the IR5000 and IR6000. There is a link on this page as well to download the full service manual for the model displayed, which should enable you to solve the problem.
On the right at the top of the page you can change the error code you are looking for to get a quick reference.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 27, 2014 | Canon iR5000-6000-L1 PS Ver 1.0
How can i solve my ir3300 error code e000003-0000
Looks like this will require service by a technician.
http://www.printcopy.info/?mod=free&chap=erc&brand=Canon&model=iR3300
E003-0000 The main thermistor reading is lower than 140C when paper is moved
Aug 16, 2014 | Canon iR5000-6000-L1 PS Ver 1.0
How to fix error e000001-0000 for canon ir6000
You can try to reset error code in service mode, but if the error persist after clear, you need to rectify the problem and replace fault component which is fairly fixing easy to do.
The problem can be in thermistor, sub thermistor or dc controller pcb, or ... call service!
To reset error code:
while ready to copy/showing the error code:
1) Press the user mode key ( * ) on the control panel.
2) Press the 2 and 8 keys at the same time.
3) Press the user mode key ( * ).
Choose: COPIER>FUNCTION>CLEAR>ERR
Turn off and back on the copier.
Jul 30, 2014 | Canon Imagepass L1 Print Controller For...
Ir5000 error code 000005-000 how do i clear it
Whenever you have replaced the fixing web, be sure to set '0' to
the following in service mode:
COPIER>COUNTER>MISC>FIX-WEB
COPIER>COUNTER>DRBL-1>FIX-WEB.
do not clear the limit,
Jan 16, 2014 | Canon imageRUNNER 5000 Copier
User manual or User Guide of iR325s and iR5000/6000
give me your email and ill try to get some manual for you
Mar 11, 2010 | Canon imageRUNNER 5000 Copier
Error code E000020-0000 in cannon ir5000/6000
Main cause: The machine is not receiving toner properly because 1)The hopper connector is left disconnected. 2) The hopper motor (M9/M10) is faulty.3) The toner sensor (TS1/TS2) is faulty. 4) The DC controller PCB is faulty.
If you recently added toner, recheck that area.
Basically the copier is trying to add toner and is not getting it.
Oct 25, 2009 | Canon imageRUNNER 7200 Copier
Mar 27, 2009 | Canon imageRUNNER 5000 Copier
IR5000 bloque
Dec 23, 2008 | Canon imageRUNNER 8500 Copier
Help me.....faster....
Errors commencing with E3---- means that something to do with the reader unit,,,, apart that error mentioned does not exist. If youhave plenty of parts that you can try out I will try to replace the reader board....
Dec 15, 2008 | Canon imageRUNNER 5000 Copier
Look up error code E00061001 for Canon 5020i
Title : E-061 Error Code Problem :
E-061 code is occurring for the IR5000/6000
Solution :
Check, re-seat or replace the Primary Corona Assembly
Apr 25, 2008 | Canon imageRUNNER 5020i Copier
Canon imageRUNNER 5000 Copier Logo
54 people viewed this question
old marine
old marine
