Question about Yamaha DSPE390 Amplifier
Power suply no osolation on power suply i change regulator and other capacitor
    Novelist:
  • 236 Answers
Can you explain more of what is your concern? what help do you need.
Reden
Posted on Mar 19, 2008
    Problem Solver:
  • 8 Answers
Osolation? What do you mean - isolation, or oscillation?
Posted on Sep 03, 2007
Bpl tv power suply more
Check those capacitors in video chroma section.
Jun 30, 2014 | Sony Televison & Video
Wont turn on
If your computer is in a loop boot the problem is clearly the chipset, but before being sure of it you have to disconet the memory cards and to change themfrom the slot try one at the time in slot 0 if the problem continues then 80% for sure is the chipset that needs to be changed. If your computer does not turn on then the problem is power suply, check the power suply inn maybe it is defectuose, or the starting capacitor is defective, hope tou solve the problem
Oct 22, 2011 | Acer Aspire One PC Notebook
I have waves running up my screen how do i fix that
hi
depending on the waves if it is light dark bar rolling from bottom to top it may be a defective
capacitor in IF section or interference comming
for ex:defective neon sign leaky electric power transformer etc. If it is a slow moving
wave but no bars you have a defective power suply regulator and I don't suggest you try to fix it yourself
Sep 29, 2010 | Hitachi 50UX57B 50" Rear Projection...
Gateway gt motherboard failure
Yeah that's right. Change/replace the power supply. Yet, you have to test the power supply's conditions if it still works alright. since you are suspecting both motherboard and HDD first. If yellow light comes and no action to the whole machine then that must be something in the motherboard. Before you finally follow your decision to change the power supply, check the motherboard. There are capacitors and examine if it didn't bloat. If it does, just take out the capacitors with exact microfarad and voltage specs or change the whole board. And granting though that the supply is bad, there must be some electric signals that have caused to the mother board which will eventually, at the end of the day, you encounter the same problem with it.
Jun 23, 2009 | Gateway GT4010 (RBGT4010) PC Desktop
TV frozen on standby
Power suply voltage might check good, but change the regulator in this unit partnumber is Ssr-9001a-M2
hope this helps.
daniel.
Jan 12, 2009 | JVC AV-48P775 48" HDTV
Doesnt turn on anymore.
Hi..there,
It's seems your backlight inverter is burnt out... need to be replaced with a new one or you can repaired yourself by testing all the capacitors to see which it has been burnt out or has a leaked. After that just replaced the bad caps... Good lucks, Have nice a day!
Aug 16, 2008 | Fuji FP-988D 19" Flat Panel LCD Monitor
350w switching power suply
Michael
at first chack at which time it shutting down. if it happen when u click on any drive or when u using cd/dvd drive then power supply cant regulate power. then chack switching transistor and filter section capacitor.
(Be careful about filter capacitor in primary section because some time it stored high voltage dc after plug of power supply at first discharge this two capacitor.)
** also chack supply voltage r stady or not.
Jun 26, 2008 | Codegen POWER SUPPLY CG|PS-350XA-12 RT...
Acer AL1715 going on and off (LED blinking)
Hi maxwell,
Firstly check for the surrounding components like th coupling resistors for a short. Change them, then look for leaky diodes (a diode shows low resistance when connected to a multimeter with correct polarity and MUST show infinite i.e. NO resistance at all when polarity of the meter testprods are reversed) As for the deformed capacitor change it with similar type, voltage and size.
VERY IMPORTANT: Make sure you put in the new one back in the same polarity (since it is an electrolytic type capacitor from what you mentioned in your querry) elase the new one will explode if the polarity is wrong.
Better still, if you are not good at soldering components that are so closely attached on the circuit board, just give it to an authorised service center in your area.
May 04, 2008 | HP Pavilion F1703 17" LCD Monitor
Yamaha DSPE390 Amplifier Logo
53 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
