Question about Sony STR-DE925
Display says protector - Sony STR-DE925
Display on control panel no longer displays.
Surge associated with power outage can make disasters in refrigerators. You need a power protector for refrigerators.
Now, what already is damaged, should be repaired by an authorized techician.
For protector, you can do a search; typical return is this one
Electronic Surge Protector for Refrigerators up to 27 Cuft and Freezers
May 13, 2015 | Samsung RS277AC (27 cu. ft.) Side by Side...
Push power protector
if your pushing the power protector to on back its a resettable fuse an you have another insue inside shorting it out
Aug 03, 2014 | Sony Dream Home Theater System, DAV-DZ120...
Free download whatsapp
i am unable to download ur whatup apps
Oct 25, 2013 | iPhone Apps
How do you get bubbles out of iPad screen protector?
To lift the protector off one edge of the display, place a sticky tape on the edge of the protector and then pull on the sticky tape to lift off the protector.
Lift the screen protector from one edge, peel it back to the last bubble then re-fix the protector in place by slowly apply pressure across the proctector as you push the protector onto the display making sure no bubbles forms between the display and the protector.
Dec 28, 2011 | Apple iPad Tablets & eReaders
The word protector is displayed
If protect is coming up on the display, it means the system is detecting a short somewhere on one of the speakers and so is turning the amp off to avoid damage.
Check all the connections at the back of the amp to ensure they are not shorting, and at the back of each speaker, if nothing is found there, check each wire for damage (like squashed or rodent damage).
Mar 06, 2010 | Sony STR-DE705 Receiver
IT DISPLAYS PROTECTOR PUSH POWER
its in standby, try it again, if it does it repeatedly theres a problem in the switching power supply not letting it power-up to save components
Oct 18, 2009 | Sony DAV-DX375 System
Error code - protector
Try disconnecting all the speakers from the back and turn the unit back on. If the "protector" display goes away, turn the unit back off and reconnect one speaker. Turn it back on and check for "protector". Repeat.
If you find that one of the speakers causes "protector" to appear, you either have a bad speaker cable or bad speaker. Try swapping each of those out to see what happens.
Apr 20, 2009 | Sony STR-DA90ESG
Sony str-de525 system "protector" problem
You've blown it. It recognizes a potentally harmful situation and goes into protect mode.
Mar 15, 2009 | Sony STR-DE935
Stuck protector mode
find out why the fuse blew in the first place.the protector is just PROTECTING the main circuits of the receiver.the receiver turns on just to confirm the power circuit is OK.
have it checked by an electronic engineer.
Apr 16, 2008 | Sony STR-DE597 Receiver
Sony STR-DE925 Logo
27 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
