Question about Amana Refrigerators
Ramtons freezer not working
I have a ramtons chest freezer (model rm/171) that has been unused for some time. When I put it back on, it runs, the button that shows it is working but it is like the cooling mechanism is not working at all. It sounds like it is on, looks like it is on but no cooling inside the freezer, not even a little bit. Please help.
mosesclive
  • 191 Answers
SOURCE: Not freezing or cooling
There should be a small relay switch near the compressor. Sometimes dust or (ugh) a bug may get in there and block the relay from starting the compressor.
Posted on Sep 28, 2008
huuum
  • 750 Answers
SOURCE: Kelvinator Chest Freezer will not cool after spray painting rust spot.
Dear Landport2
Welcome to the site,
You said, you have a Kelvinator chest freezer, model number CFS101SM1W. This freezer is in excellent condition and was working ok. I notice that there was a rust spot on the bottom area so I decided to spray paint the entire inside with the appropriate appliance spray paint. After spray painting the freezer will not cool.
How old was your freezer?
This must be an ancient freezer!
And Unfortunately I was not able to tell you to leave it alone and not to turn it off!
You did not cause this!
Unfortunately it was so old that it probably was already on it's last legs.
Here is an interesting report I just read!
Repair or replace your appliances?
When to pull the plug on your old freezer
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model ?
The answer depends mostly on the age of your ,freezer
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your refrigerator is under warranty or less than four years old freezers),
paying for a repair makes sense.
Note that freezer under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your freezer is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new freezer.
Data also shows that it doesn't pay to fix a less-expensive freezer
six or more years old .
Thanks to better recycling programs, less than 10 percent
of a freezer you replace is likely to end up in a landfill.
Thanks for giving me the opportunity to help!
Please do not for get to give a rating before you sign off!
Thank You, HUUUM
Posted on Oct 10, 2008
tech master
  • 120 Answers
SOURCE: kenmore fridge model#596.52679200 side by side
remove back cover on evaporator inside frezeer if is full of ice all over then you have a defrost problem and you might have a faulty defrost timer or defrost thermostat repl both so you wont go wrong if the coils are clean and not frost is on coils then check compressor to see if its running just by touching you can find out if it si not running then you have a faulty relay or overload repl and compressor should start.if there is only partial frost then you have a leak or restriction depending when you bought it most refrigerators have a maufactures warranty on compressor for about 5 years call for service on the number on the sticker inside refirgerator
Posted on Oct 14, 2008
docjohn174
  • 943 Answers
SOURCE: Freezer frozen solid freezer cool fridge not
HI look for this part in the freezer. its the most common one to fail.replace it
MicrowaveSvc
  • 9047 Answers
SOURCE: Not heating
This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix) or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There may also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you only need a switch, you can order a universal type from us for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
Posted on Nov 25, 2008
My ramtons micro wave does not have it internal light working,whats its the problem
Does it work?
Change bulbs in Microwave sometimes is tricky
See if you can get the manual for your device from here and chek if say anything about internal light
Jun 30, 2015 | Microwave Ovens
Where are the cooling lines for a frigidaire chest freezer model#GLFC2027FW6?
they run around the entire perimeter... Just put something heavy on the top of it.
Aug 09, 2014 | Frigidaire 13 cu. ft. / 368 liter Chest...
Sears chest freezer model 225.19702010 serial bfp2111188f31157 I came home last night and my freezer had stopped freezing, there's power, but the compressor clicked but wouldn't actually run, left...
If this is a small chest type freezer you paid around 189 bucks for and it's out of warrenty,toss it. No parts are avable for them. I do sears contract work and these freezers are junk. By chance if it's a upright, not any better
Sep 12, 2012 | Refrigerators
I have a kenmore chest freezer model 19502/19702. I had it unpluged for 5 months. When I plugede it back in the power light flickers. Tryed other outlet. Other then that it seems to be working
We purchased this same Kenmore chest freezer model 19502/19702 in 2010. In less than 2 years the compressor quit. If you do a search on this model you will see dozens of complaints. Don't waste your time or money on this freezer.
Apr 16, 2012 | Kenmore Freezers
THE GREEN POWER LIGHT FLICKERS, AND COOLS ONLY WHEN THE FAST FREEZE POWER BUTTON IS TURNED ON
This sounds like the freezer stat is gone. If it is digital, there may be a power card issue but most chest freezers are run on a standard thermostat with the capillary running up into the base of the unit. Whilst sourcing the part, put a standard socket timer on to the plug to stop the unit running all the time.
Dec 09, 2009 | Magic Chef Chest Freezer MCCF5WBX
Briefly unplugged and now when plugged back in freezer wont turn on?
fairly unusal but ...posibly vapour locked.... people transporting fridges and freezers laying them down or chest freezers standing them up in a truck or trailer (taking them to the cottage) have this problem all the time unplug it for 24 hrs should cure it Good Luck
Oct 12, 2009 | Frigidaire 13 cu. ft. / 368 liter Chest...
Refrigerator and freezer not cooling/freeding
Possibly a defrost circuit problem -
1) Bad defrost thermostat
2) Bad defrost heater
3) Bad defrost timer
4) Failed evaporator fan motor.
Look for frost accumulated inside the louvers at the back panel, top and bottom. If you see it, remove food from freezer and put in ice chest. Take out shelves, get hair dryer and warm the backside of the freezer, directing air down the louvers. Then leave to sit for 4-6 hours with the freezer door open. Put towels in the bottom of the freezer to catch any melted ice.
After period of time, plug unit back in and power the unit back up. Once you know it's cooling, empty ice chests back into freezer.
If there is a problem in any of the above components, then it will show up in 3-4 weeks witht he same problem again.
Jan 29, 2009 | Kenmore 53642 / 53644 Side by Side...
Kenmore Chest Freezer C675-18012-1G purchased april 2000
Average freezers last for several years, usually 10 or more. The compressor should not run all of the time, maybe less than 10 to 20 percent of the time if it is working properly. Not sure what you mean by the bipass, some freezer have a manual defrost, and in this mode it will not cool. Insure the location where you have the freezer allows for ample air circulation, sometimes folks put them in little spaces that prevent air circulation to the condensing/compressor unit and they overheat and do not work well and fail very quickly.
Nov 27, 2008 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Frigidaire refrigerator Model # FPD12TF - not a chest freezer
I have not solved the problem I wrote about. I don't have a chest freezer...I have a refrigerator, model number referenced above. I don't want to join anything - I just wanted advice about my 13-year-old refrigerator. Never mind.
Jul 24, 2008 | Frigidaire 12.8 Cu. Ft. Large Chest...
Refrigerators Logo
52 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
