Question about Razor E90 Electric Scooter EA Orange
Have nott been ridden for months and go to charge them and charger turns green after a few minutes and dont run
Dyson dc30 charging issue
Defective replacement battery - unable to charge/recharge.
Jul 11, 2017 | Vacuums
The bike wont start after sitting for a few days. It starts to try to turn over but then it just starts clicking.
Battery not holding its charge if you rely on your bike for transport then just buy new battery as this will never get better just worse and more unreliable it will even not start after you have ridden only few minutes ago eventually
If you want cheap fix then hook up to battery charger few hours before you need to use it but this option would annoy me after first few times personally just get new battery ASAP
May 22, 2011 | Aprilia Scarabeo 250 Motorcycles
I have a 2005 with only 3000 miles on it. I could not start the bike and thought my original battery was weak. I had it on a trickle charger with a green light, but as soon as I tried to start the bike a...
As this point you can't get the bike to turn over is this correct? If the engine is turning over but won't start then yes the gas is most likely the problem. Gas after sitting for even a month can evaporate from the fuel system and it leave a fouls smelling deposit behind that clogs up everything. It stinks and it's a mess to clean out. To prevent this from happening use a product that is called "Fuel Stabilizer" in the last few tanks of gas before you put the bike away for the winter or a dormant period. If the motorcycle is in a hot climate or heated garage this foul smelling gas can happen within a few weeks.
Apr 10, 2011 | 2005 Yamaha Road Star Silverado
My Hoveround MPV5 batteries will not charge, do you think it is a battery problem or a charger problem?
If you plug the charger into the wall, turn on the power switch and the light comes on, the charger should be working properly. Here is a way to test it-
Attach the charger that came with the power chair to the power chair controller firmly and turn the power chair on, while the charger is running. What should happen:the lights on the controller will scroll back and forth. If this does NOT happen and you can confirm the charger is turned on, the charger handle is fully seated inside the controller receptacle and the wall outlet has power, then the charger may have a problem and needs to be replaced.
If the charger is OK, then there may be a problem with the batteries. Here are some sypmtoms:
1-You connect the charger but the light on the charger never goes red, it just stays green.
2-You connect the charger but the light goes from red to green VERY fast.
3-The charger light goes from red to green but when you disconnect the charger and press the power button on the controller, you only have one flashing red light, or the batteries drain within just a few minutes of use.
4-The power chair has been stored or sitting idle for several months.
5- The power chair has been connected to the charger 24-7 for several months.
Any of the above examples indicates that the batteries are oxidized or damaged and will most likely need to be replaced. The MPV5 takes two, U1 12 volt 33 amp batteries which can be purchased at any battery warehouse store like Interstate Batteries or Batteries Plus.
Nov 30, 2010 | NRS Hoveround MPV 5 - Used Power...
I have charged my camera but it will not stay on when turned on
you dont have explain exactly the problem.. if the problem turn on and off istantly this is shure a lens problem and you mst change the lens. if the camera turn on one two 3 minute and than turn off its probably that the camera dont charge the batterie. if the camera dont charge you can bypass the problem. you can buy on ebay a external charger for your batterie. if you search on ebay international seller you can find charger and batterie to a very good price. its possible to find two batterie and one charger to 10 sterl. so you have new batteries and a external charger. external charger is better as charge the battery in the camera. why i is nott so difficult that the batterie explode and ruine the camera. with a external charger this is not possible why you can ruine the charger that have a low cost but not the camera. i hope that i have help you. its possible that the camera dont charge its possible that the batterie dont mantain the charge.. its possible if the camera go on and go out directly that this is a lens error.. sorry foer my english
Aug 10, 2010 | Kodak EASYSHARE M1063 Digital Camera
Battery pack or charger
Hi!
When you insert the battery , plug the power into the charger and the light turns ON (red or green) - the charger is OK. One indication that the battery is dead is when you charge it, after just a few minutes the full charge indicator will turn ON ( with Canon chargers the light for full charge is green). If that's the case, purchasing a new battery is the only option.
Have a nice day!
Oct 02, 2008 | Canon PowerShot SD600 Digital Camera
Sidekcik Lx will not charge.
Try a new battery for it.
Sep 09, 2008 | T-Mobile Sidekick
Razor E90 Electric Scooter EA Orange Logo
18 people viewed this question
Top Razor Sport & Outdoor - Others Experts
Charles T Nevin
Charles T Nevin
David Burbee
David Burbee
Tom Chichester
Are you a Razor Sport and Outdoor - Other Expert? Answer questions, earn points and help others
