Question about Life Fitness Exercise & Fitness
E2 error lift error - Life Fitness Exercise & Fitness
  • Life Fitness Master
  • 914 Answers
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
You have posted this question in the Stair Climber section, but the error you are listing is a treadmill error code. The following information should help.
Probable Cause A) Incline control error.
B) Insufficient power source.
C) User exceeds weight limit.
D) Unit will not lift.
E) Unit thinks it is always at 0% incline and only lifts up.
F) 3 amp circuit breaker has tripped.
G) CPU board has stuck relay.
H) Lift motor is faulty.
Corrective Action A) Access the incline manual mode in diagnostics by pressing 9, 1, 9, ENTER and then pressing HILL program key. Incline the unit with two people on the unit. B) Ensure treadmill is connected to a dedicated 120V, 20 Amp circuit.
C) Advise user of unit's weight limit of 300lbs (137kg).
D) Perform the lift test procedure by pressing 9, 1, 9, ENTER and then pressing HILL program key.
E) Inspect the home switch for smooth operation and inspect the wiring of the home switch for damage or poor connections. Inspect the lift motor cable connections and for the presence of the suppressor board (should only be 1).
F) Test the circuit breakers and replace if necessary.
G) Replace the CPU board.
H) Replace the lift motor.
LifeFitness 9500 Treadmill Lift Control Error
Posted on Sep 30, 2015
When we star the treadmill E02 is apper
Precor Error E2, Lift Error Probable Cause Error would occur if the incline is unable to move or if the incline position potentiometer is not functioning. When this error occurs, all lift motor and drive motor motion is ceased and the display will go blank except for the error displayed.
Corrective Action Troubleshoot as errors 40 and 42.
Precor Error Code E2
Oct 15, 2015 | Exercise & Fitness
Need help. Flashing E2 and 61 codes. The paper is not jammed and it has a new carterage.
Canon PC-920 Black and White Copier E2 error - Questions ...
www.fixya.com > ... > Canon > Canon PC-920 Black and White Copier .. error code e7 & e2 Cannon pixma mp145 printer error code e7 & e2 E2: Reload the paper correctly and press [Black] or [Color]. E7: The cartridges are not ..
Jul 21, 2015 | Canon PC-920 Black and White Copier
E2 error solution
Precor Error 40, No Lift Motion Detected Probable Cause 1. Blown lift fuse in lower PCA.
2. Lift motor is physically jammed and not able to move.
3. Bad lower PCA.
4. Bad lift capacitor.
5. Bad lift motor winding.
6. Bad interconnect cable between upper and lower PCA.
7. Bad upper PCA.
Corrective Action
  1. Check the lift fuse from the lower PCA. Using an ohmmeter, the fuse should measure 1 ohm or less. If the reading is significantly high, replace the fuse. If the fuse is open, refer to steps 3 and 4 before continuing.
  2. Disconnect the lift motor from the ramp (elliptical) or lift platform (treadmill). If the lift nut or lift tube is jammed against the motor housing, turn the lift tube or lift nut away from the motor housing. If the lift was jammed, refer to step 3 before continuing. Calibrate the lift motor per the proper procedure for the unit being serviced and reattach the lift motor to the ramp (elliptical) or lift platform (treadmill). NOTICE: You must find and repair the cause for the jammed lift. Only re-calibrating the lift motor will not solve the problem.
  3. One of two modes can cause the lower PCA to fail. The lift switch could fail in an operated condition. If this happens the lift will move (either up or down) as soon as the unit powers up. The usual result is that the lift will be physically jammed as explained above, and probably also being cause for the lift fuse to blow. The lift switch could also fail in an open condition. If this happened, the lift would not operate in one direction. If either of these conditions occur the lower PCA needs replaced.
  4. Most units have the lift capacitor mounted inside the lift motor, and others use external lift capacitors. This information applies to units with the external lift capacitors. If the lift capacitor is shorted the lift fuse blows. Check the capacitor for a short using an ohm meter. Disconnect the capacitor from the lift motor and test. A good capacitor reads in the millions of ohms. Replace the capacitor if the reading is significantly low. Capacitor can also fail in the open condition which would result with the lift motor trying to run but not having normal power. Test the capacitor by measuring AC voltage across it. A good capacitor will read AC peak voltage while an open capacitor reads AC RMS voltage.
  5. When a lift motor winding is bad the lift will not operate in one or both directions depending upon the exact fault in the motor. Check the lift motor winding with an ohm meter. AC lift motors have a split winding (3 wires) and DC lift motors will have a single winding. Both windings must be checked on an AC lift motor. Normal winding readings could vary anywhere between 1 and 60 ohms, depending on the lift motor being tested. See the proper service manual for the motor being tested.
  6. Test unit with a known good interconnect cable. Replace the interconnect cable if necessary.
  7. Test unit with a known good upper PCA. Replace the lower PCA if necessary.
Precor Error Code 42 Error Code: 42 Manufacturer: Precor
Model: All Models
Error Description: Error 42, Lift Position Value Out of Range. Error 42 is displayed when the lift position reported by the lift position potentiometer is found to be outside its set limits.
If an Error 42 has occurred, it is important to know the physical position of the lift when the error occurred. It is possible the lift is physically out of range or jammed. In this case, the Error 42 is a secondary symptom and the issue should be approached as an Error 40. Possible Reason:
  1. Bad or intermittent connection in the lift motor controller.
  2. The lift motor requires calibration.
  3. The lift motor potentiometer is bad.
  4. The lower PCA to upper PCA cable is bad.
  5. The lower PCA is bad.
  6. The upper PCA is bad.
Recommended Action:
  1. Intermittent connections can be difficult to locate. If the Error 42 condition is intermittent, a connection issue is probably the cause. This is definitely true if the Error 42 occurred while the lift was within its normal physical range. Inspect the lift potentiometer connector and repair connection if necessary. If the intermittent connection cannot be found or corrected, replace the lift motor. A lift calibration number of 0 or 255 indicates an open or shorted potentiometer connection. This means the problem could be anywhere between the lift motor and the upper PCA. Typically it can be identified and tracked using an ohmmeter.
  2. Using the appropriate service manual for the unit being tested, refer to the lift calibration procedure. If the information in the service manual doesn't match the lift position/physical lift position of the unit, recalibrate the lift motor. [Something caused the lift motor to be out of calibration. Investigate for cause and correct. Simply recalibrating the lift motor will not solve the problem.]
  3. If the lift calibration number is not 0 or 255 and does not change when the lift motor turns, replace the lift motor.
  4. Check continuity of the interconnect cable or swap with a known good interconnect cable to verify if cable is bad.
  5. Swap the lower PCA with a known good lower PCA to verify if the lower PCA is bad.
  6. Swap the upper PCA with a know good upper PCA to verify if the upper PCA is bad.
Precor Error Code 40
Lift Position Value Out of Range Precor Error 42
Apr 22, 2015 | Exercise & Fitness
HOW TO FIX AW-1170S WASHING MACHINE TOSHIBA ERROR E2
LOOK IN YOUR MANUEL ,,FOR TROUBLE-SHOOTING ERROR E2 OR CALL MANUFACTURER SUPPORT
Nov 11, 2012 | Washing Machines
Error 2 in Goldstar MTD 602 treadmill
1) Adjust the speed sensor 2) Tight very well the connection from speed sensor. 3) Faulty Sensor speed 4) Faulty Main Motor measure for 115 VAC without load. 5) Main motor board faulty , test for 115 VAC,and oupput for +5Vdc. 6) See the transformer for 115 VAC,for primary voltage and secondary voltage. 7) See if some component such: resistors, capacitor, diode, or IC burn. 8) Lubricate the deck belt. 9) Adjust the tension for deck belt for lift 2-3" max. 10)error code e1 vs e2 in some mark is equal is different from some manufacturer.
See the block diagram for your diagnostic, for strong resultant.
Sincerely. Merry Christmas.
ernesto cuadra
managua, nicaragua.
Dec 18, 2011 | Exercise & Fitness
Error e03-02 comes up with asking check printer
Welcome to Fixya
Error e2-02 means machine is having error of lifting motor assembly for tray #2. You may check the tray. Sometimes there's just a paper clogged at the rear of the paper tray. Just remove the 2nd tray to see if there is a paper clogged inside. Otherwise the cover/case of the lifting motor is damaged and you will need a service technician to fix and replace it.
Thank you for using Fixya!
Dec 06, 2010 | Panasonic Workio DP-1820E Copier
I get an error message E02-01. Any idea what that is?
yep!
e2-01 means there is a machine error of lifting motor assembly for tray #1.
For sure this time you can't use your tray #1.
you may check it sometimes there's just a paper clogged at the rear of the paper tray. just remove your 2nd tray to see if there is a paper clogged inside. Otherwise the cover/case of the lifting motor is damaged and you will need a service technician to fix and replace it.
... you can still use the bypass paper tray.
Jan 08, 2010 | Panasonic Workio DP-1820E Copier
Error code E2
Hi most of the treadmill with e2 error code are related to the motor speed sensor so check the sensor
May 12, 2009 | Exercise & Fitness
E2 Error code on Xerox XC1875 Copier
Most likely the paper feed rollers are slick and simply not feeding paper. You can google a business called "the parts drop". They have an excellent site and parts availability.
Feb 13, 2009 | Xerox Office Equipment & Supplies
E02-06 error on a panasonic fp-d605 copier
The error E2-06 indicates a problem with paper tray lift in the Large Capacity Cassette (LCC) It could be a faulty lift motor or bad sensor. In this particular case someone crammed way too much paper into the lift tray. I took out half of the paper, restarted the machine and the error cleared.
May 28, 2008 | Panasonic Office Equipment & Supplies
Exercise & Fitness Logo
232 people viewed this question
Top Life Fitness Exercise & Fitness Experts
Howard
Howard
Electro Med Services...
Matt Olenzek
Matt Olenzek
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
