Exercise & Fitness Logo
A
Anonymous Posted on Jul 31, 2013
Sole F85 treadmill will run demo mode but will not turn on. It went from 5 mph to 12 mph on its own then quit
5 Related Answers
Anonymous
  • 218 Answers
  • Posted on Aug 12, 2010
SOURCE: my treadmill surges 4-5 mph while i'm walking,
controller is bad
Anonymous
  • Posted on Dec 04, 2010
SOURCE: Brand new Sole F85 incline shows e2 and stops
Same thing happens to me. Any solutions?
Anonymous
  • 33 Answers
  • Posted on Feb 19, 2011
SOURCE: Our Sole F63 treadmill is
pls make clear , countdown is come or not, if coming means problem with controller
ercupa190
ernesto cuadra
  • 12223 Answers
  • Posted on Sep 29, 2011
SOURCE: Sole F85 - LS1 appeared on the screen. Motor is
Dear Sir:
Thank you by your request. I will try to help you, inmediately.
LS1- Means loss of signal.
Please check this very carefully
Connect the machine at your receptacle and try again, if you note there are some red lamp on in the motor control board : is indicative that you must check the conection with motor (plugs) loose or dirty( clean with some special spray for contact, but before to due that disconnect the machine again.
If the problem persist you must exchange the display board.
If not Red lamp is on, you can check the motor if is open, or short, or in band condition, you must check with the DVOM, ( digital voltimeter) and finally if you repair the motor an try again, the faulty is motor control board.
How to measure FUSEAND CONTINUITY A digitalmultimeter is the ideal multimeter t use to check fuses. You can test afuse using either a digital volt-ohmmeter or an analog volt-ohmmeter. Thedigital multimeter uses a LCD to indicate the condition of the fuse under testwhile an analog meter uses a traditional meter movement to indicate the fusecondition. Difficulty: EasyInstructions
Things You'll Need
  • Digital multimeter or analog multimeter
1. Usinga digital multimeter
o 1 Connectthe test leads to the volt-ohmmeter. Plug the black test leads into the blackjack marked "Com" or "Common" on the front of the meter.Plug the red test lead into the red jack marked "Volts/Ohms" on thefront of the meter. o 2 Setthe meter's function switch to "Ohms" and the range switch to the"R x 1" scale. If your digital multimeter is an auto ranging meter,you will not have a range switch. Instead, you'll have just a function switchbecause the meter will automatically select the right range for the quantitythat you are measuring. o 3 Turnoff the power and remove the fuse to be tested from the circuit. Never test afuse for continuity while it is still connected to the circuit that it is usedto protect. If the circuit still has voltage, the meter will be irreparablydamaged. If the fuse is still in the circuit when tested it is possible to geta false indication that the fuse is good if the meter gets a completed circuitthrough other circuit components. To be safe, always remove the fuse from thecircuit before testing it. o 4 Touchthe black test probe to one end of the fuse and the red test probe to the otherend of the fuse. It does not matter which probe you touch to which end becausefuses are not polarized. You are checking to see if there is continuity throughthe fuse element. A reading of approximately 0.5 on a digital meter's LCDindicates a good fuse. Most digital meters read their own internal fusesresistance, hence 0.5 Ohms and not 0.00 Ohms. LCD readout of "O.L."indicates no continuity through the fuse. The fuse is bad and needs to bereplaced.
Thank you in advance, sincerely . God bless you
If you need further assistance, please contact me.
E.CUADRA
MANAGUA, NICARAGUA.C.A.
ercupa190
ernesto cuadra
  • 12223 Answers
  • Posted on Oct 29, 2011
SOURCE: my sole treadmill turns my in line light times on
Dear Sir:
Watch this video:
http://www.youtube.com/watch?v=N6Yg5S0WML8&NR=1
http://www1.fixya.com/support/r10724803-measure_voltage_in_transforme_fitness
http://www.youtube.com/watch?v=bF3OyQ3HwfU&feature=related
If I can undertand very well, the problem is intermitent.
a) Check the power cord,( some wire is broken internal)
b) Look for cool solder ( re-solder)+loose connections cause intermitent operation!
c)Inspection the breaker, for loose connection, test the breaker.
d) check the transformer as indicated above.
e)and finally check the power supply after the transformer: a) resistor b) capacitors c) diodes, all this component can be loose, bad solder or cool, or broken, or short, open, or shorcircuit.
If you need further assistance, please reach me, sincerely. God bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
The machine is making a thumping noise underneath the belt. F85 Sole Threadmill.
on some treadmills the motor is coupled with a belt to the main wide belt drive. if it is cracked it can create a rapid thump.
Fan not working
Your display pcb board needs replacement.....call sole for service
Sole F85 Hand Rail Incline Adjustment Switch is not working
The hand rail switch contacts can be worn out. The more likely problem is a broken wire by the arm. Remove the cosmetic covers by the hand rails and check for broken wire. If wires are not broken replace the switch.
Sole F85 treadmill fan and hand controls not working
There may be two problems, however, I would suggest you replace the main display pcb. That will fix the fan problem. If the handle bar switches still do not function replaces the switch and wiring.
1helpful
Sole treadmill says "INITIAL" on the screen and won't run. This occurred after I removed the magnetic emergency stop switch.
Normally you must put the key in the hole, after you press the button start and ready.
However I recommend you to follow the instr. manual for easy start. Since that every manufacturer has a little diferrent mode of start. If you do not have it download free from
www.fitness.manualsonline.com
God bless you
3answers
F85's "low speed" error
Dear Sir:
1) Lube the deck belt very well, as your instruction manual indicate for maintenance.
2) Try to Run software calibration after you fix it. For easy diagnose and troubleshooting.
3) The elevation motor can be faulty for lack of maintenance too, again Run the software calibration.
Operating manual sole e35
go to www.iconservice.com for free download
or http://fitness.manualsonline.com
Good luck,sincerely. G-d bless you
ERNESTO CUADRA
MANAGUA,NICARAGUA
Top Sole Fitness Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Are you a Sole Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
