Hi I recently got a LG Neon TE365 (North America version of KS360) and am trying to install JAR applications/games onto the phone.
I've copied the JAR files onto my memory card (microSD) and tried to run them on the phone. However, I cannot find any option on the phone that allows me to run the JAR installation files.
I tried googleing this problem but still cannot find an answer.
Any idea how I can do this?
thanks.
TC
Hey Guys,
I Emailed LG Canada about LG TE365,about installing games/applications but unfortunately they said you can not install any third party application. i think you have to buy it on mobile(using web-get games).
I feel really bad about having this phone.
I just boght this phone in mexico here its the LG GT360 and all you have to do is connect the phone via the usb cable and use it as a memory, once connected 2 drives will be displayed with the same folders, what you need to do is put the ¨jar¨file in the folder named other on either drive doesn´t matter once thats done simply eject the phone and got to the my stuff folder on the phones menu select the games file ( or app.) and simply follow the steps.
Copy thr jar file to your phone memory card in the folder call (other).....unplug the usb then go to my stuff on your phone..then into memory card folder other then run the install...it work for me
ERASE IT AND DO IT OVER THAT SHOULD DO IT BECAUSE IT HAD TO FREEZE THAT WHAT HAPPEN TO ME
You might want to try to d/l the apps directly from the internet. I have the same phone and have a few jar apps installed/running. You may need to search for apps under GT365 or KS360.
http://www.getjar.com/
http://www.mobile9.com/
http://www.google.ca/mobile/
You have to send them to your phone and dan instal them ther standing in your media-Others
Sorry I tried everything I could. The problem is I cannot find any option to actually "Run" the file. I can only delete, copy, rename, check info, etc
Please advise.. thanks.
TC
OK so i put them on my micro SD also... but where do i put them?? in documents or other??? and how do i try and run them???
I heard we have to debrand the te365 and install the ks360 firmware in the flash memory, but I couldn't find how to do this.
I had the same problem, and erase it and do it over again still doesn't work. It only have the delete option.
