Question about Nu Mark AXIS 9
Parts for numark axis 9
Is there any place in the u.k. where i can buy replacement pitch slider and touchpad?
  • Anonymous Apr 22, 2008
    i need a laser and its moto,for axis 9 numark cd deck
    President:
  • 1,114 Answers
Numark address in the UK is: NUMARK UK LTD UNIT 9, THE CHRISTY ESTATE IVY ROAD ALDERSHOT GU124TX UNITED KINGDOM Tel: +44 1252 341 400 I would give them a call. Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Aug 31, 2007
Yes You can get them from Instrumentalparts.com aka www.numarkparts.com
Posted on Sep 07, 2007
CDJ 1000MK2. CDJ pitch control is out of calibration. The pitch plays at zero when the slider is at what should be the slowest setting. How do i reset zero to the middle of the slider.
There is a fine adjust on the pitch control circuit board, however if it is staying at Zero at the extremes then it's time for a new pitch control :(
Jun 25, 2011 | Pioneer CDJ-1000 CD Player
Tip
Dell Latitude Portable (2008 or newer) has jumpy cursor when typing
The Touchpad driver setup has options to keep the cursor from jumping while typing.
  1. Open the Touchpad Properties
  2. Touchpad Settings
  3. Enable the TouchCheck option, set the slider to minimum. (TouchCheck disabled the touchpad while typing. The Slider adjusts the delay. Minimum is .5 second delay, and each notch and additional .5 second delay)
Other options that may cause user problems are Draglock and Tap to Click under Touchpad Settings, and Scrolling and Zoom Settings of Touchpad Properties.
on Jul 12, 2010 | Computers & Internet
How to calibrate control on a technic 1200 by sight
Put the pitch slider to +6 and adjust the internal preset until the top set of dots on the platter are stationary.
Check again with the pitch at +3.3 if the dots are stationary then job done!, if not then the pitch slider is worn and perfect calibration won't be possible until the pitch slider is replaced.
http://stores.ebay.co.uk/methleykev
Jul 14, 2010 | Technics SL-1200 Turntable
Gemini CDJ02 - Pitch Control Slider Stuck @ 0% The Pitch Control Slider will pitch down all the way but sometimes it will randomly change pitch and most the time wont pitch-up past 0.1-0%. This happens on...
Your pitch control is faulty or dry. Try spraying wd 40 into the pitch sliding hole form top to bottom. Dont over spray it. Just a bit from top to bottom will do. If issue still persists, then there's some capacitors are weak which controls this pitch.
Jan 15, 2010 | Philips Gemini CDJ-20 Top Loading...
The pitch slider suddenly wont go bellow 0.00, for
i had a similar problem i used a can of compressed air and sprayed the dust out from pitch control and it worked. the dust builds up static and interferes with signal> hope it helps
Nov 30, 2009 | Pioneer CDJ-1000 CD Player
Gemini CDM3600 pitch slider
I am having same problem..anyone ?
Jul 01, 2009 | Audio Players & Recorders
Pitch slider
usually, when you buy the pitch fader itself, then it comes with the circuit board. Ring up panasonic or a distributor and maybe they stock them, but im not sure why you need just a circuit board...and if u bought a pitch and it came without one, then just give a ring around...at least someone will stock it
Jun 01, 2009 | Technics SL-1210 Turntable
Pitch Slider
You more than likely have to have the pitch control replaced or cleaned.
- OPTiC
Technics Repair Videos
Technics DJ Repair
DJ Equipment Sales
Technics Parts
Jan 13, 2009 | Technics SL-1200 Turntable
SL1210 MK5G PITCH REMOVAL ?
The fader for the M5G's are the same as for the MK5's. As for cleaning, you will have to do it like you did with the MK2, and go from underneath.
DJPROLAB
Jan 31, 2008 | Technics SL-1210M5G Turntable
Pitch slider not working
lol just select pitch and press plus or minus to the desired pitch range and if you want to take off key lock just press keylock till you dont see the keylock symbol.
Jan 10, 2007 | Nu Mark AXIS 9
Nu Mark AXIS 9 Logo
1,286 people viewed this question
Top Nu Mark Audio Players & Recorders Experts
Greg Cann
Greg Cann
robert landry
Are you a Nu Mark Audio Player and Recorder Expert? Answer questions, earn points and help others
