Question about VeriFone Vx670 Charging Base mis-m267-s00-00
My led light is flashing red constantly. What does this mean?
Two of my smoke alarms went off (no fire/smoke in or near house), one has a green light blinking and one has a solid green light, which need a new battery/reset?
The constant green LED means the alarm has AC power.
A flashing green light every 2 seconds without an audible alert means the unit recently sounded ( was the one activated ) and is now in latching mode to let you know that it was the unit that detected the problem. To clear the latching mode hold down the test button for 5 seconds.
Red LED flashing once per minute means that the back-up battery is connected and functioning.
Red light flashing constantly during alarm means that it is the unit that initiated the alarm siren.
Sep 04, 2014 | Cars & Trucks
Why does my red light next to on off switch flashing constantly
This typically means either you need to recharge or it is recharging. Does this change depending on whether it is plugged into the power or not.
May 23, 2014 | Acer Computers & Internet
The red LED continiously lights cann't print, both LED constantly lights.
This means that your waste pads are full and the printer needs to be reset with software email me and I will send you the software
Aug 20, 2012 | Epson Stylus C46 InkJet Printer
The power button has a blinking red light, what does this mean?
4 flashing red light = av cable not connected. double check id av cable is connected properly. try using different av cable.
3 flashing red light = hardware problem . may require repair
2 flashing red light = overheating
1 flashing red light on bottom right LED with error code = hardware failure may require repair
Jul 04, 2011 | Buck Legendary: The Box for Xbox 360
Blue light flashing light, red light on
The flashing means that the toner and/or the imaging drum is empty or missing (printing halts on these errors). Lights on steady means low toner.
Jun 24, 2009 | HP LaserJet 2550n Printer
Red LED light?????
Nothing, that just means it is charging, when it goes off, it is fully charged
Jun 11, 2009 | Nintendo DS Lite
Upon power up, 3 red LEDs flashing rapidly continously, no power.
The control systems on power mobility equipment have a "prevent" circuit that immobilizes the equipment while it is plugged into a charger, so folks won't take off with it plugged into the wall outlet. When you turn it on when plugged into a charger, the display will flash constantly, or sweep constantly, depending on the manufacturer. This is normal. Your off-board charger should have a red light to indicate power to the charger, and another light for the charge status. Yellowish means it is charging, when it turns green, you are fully charged. If the status light is green all the time, that is an indication that the charger is not functioning properly, or that the batteries are below a chargeable state. Check charger output, which should be 26-28 volts dc, and each battery should show at least a 12 volt reading, but around 13.5 volts with a full charge. If one or both of the batteries drops below 12 volts after a short period of time, it's time for a fresh pair. Fully charge new ones before using the chair.
May 31, 2009 | Pride New Jazzy 600 Power Wheelchair by...
Led light constantly stays on remote rcr4358
First off, put in brand new batteries. Not just batteries that are kind of new, i mean BRAND SPANKING NEW batteries right out of the packet.
If you still have a problem:
~hold down the DVD-VCR button-> the red led will stay lit.
~holding down the DVD-VCR button press the number 2 --> the red led will turn off
~Release the DVD-VCR button--> the red led blinks 4 times and turns off.
Hope that helps!
Rate me!
Feb 11, 2009 | RCA Universal Remote Control
LG LCD TV Standby Light Flashing Red Continuously
I have had this same problem twice in the past 3 months. So far both times I've been able to get it back after a week or two. I'm not sure what works, but unplugging and detaching the antenna and cable and waiting a few days seems to be the key. In both instances, I unplugged it for a few days then plugged it in for a few days and repeated the processes until I eventually got the steady red led. Both times prior to the red led the led would flash red then green and make a clickiing noise for several hours before I was able to get it working again.
Apr 14, 2008 | LG 26LX1D 26 in. LCD HDTV
VeriFone Vx670 Charging Base mis-m267-s00-00 Logo
44 people viewed this question
Top VeriFone Computers & Internet Experts
ray gallant
Are you a VeriFone Computer and Internet Expert? Answer questions, earn points and help others
