Question about Dishwashers
I have Miele g665 dish washer and there is no power when you turn it on. I have checked the power point and it is on. The door is closed. The manual is saying the circuit is blown. Does anyone know how to replace one.
    Problem Solver:
  • 12 Answers
Call Miele Technical Support at 800.999.1360. They can help you resolve your problem.
Posted on Sep 15, 2013
  • 18 Answers
SOURCE: MAYTAG DISH WASHER MODEL 41-ESP4-DISH
I suggest calling Maytag and have a tech come out to look at it. Appliances come with a one year parts and labor warranty.Use it before your one year is up.
Posted on Nov 18, 2007
SOURCE: miele dish washer
I had the same problem only I couldn't get it to go at all. The problem was a bad motor/pump assembly (VERY EXPENSIVE). The bottom inside the dishwasher filled with water, so the intake interlock wouldn't allow new water to go in. I think I am going to throw my 4 year old, $1000 dishwasher out and buy a new one at Sears. Can't believe it is so poorly made.
Posted on Apr 30, 2008
  • 4 Answers
SOURCE: dish washer light is on with door open,close door all lights go o
Chris, go to Newark Electronics online. The exact URL for your switch is,
http://www.newark.com/cherry/d45l-r1aa/snap-action-basic-switch/dp/30C1638
I needed the D45X for a Cobalt Miter saw that broke. I was able to buy the D45L-R1AA for $3.12. Don't know why the D45X was not listed. After carefully reviewing the specs from Cherry Manufacturer, the D45L-R1AA was the best fit. The "L" stands for the pressure needed to activate the switch, the "R1" is the prong config, and the AA is the actuator button. While X was not available, the "L" which will actuate it with what appears to be the same pressure. Good luck.
Sincerely,
John Coffey
Posted on Dec 14, 2009
SOURCE: hi my miele dishwasher g665 no hot water or drying
new heating element
Posted on Jan 27, 2010
SOURCE: Where do I put salt into a G665 model
Salt and rinse aid are low if the indicator light is on.
Salt is placed in a compartment in the bottom of the inside of the dishwasher. It has a round approx 10cm diameter screw cap.
Rinse aid goes in under a flap in the inside of the door near the powder dispenser
Posted on Jan 29, 2010
Miele dishwasher drain blocked. f11 message. Help!!
Hey there - if you have not read any of the post on here - the pump could be serviced from inside the machine, empty trays out, revoe the steel mesh on bottom with a lock lever where the drains is, under here you will see a steel spring like clip, move & pull the housing under it, then the pump impellar is there - just clean it out carefully - assemble or close door run a drain for 2-3 secs, assemble . should be good to go.,
May 25, 2011 | Miele 24 in. G665 Built-in Dishwasher
Miele Novotronic W 832 washer won't turn on. It suddenly turned off after trying to open the door and now it won't turn back on. I tried switchinging powersources, didn't work.
Make sure the door is properly closed!!! The door opener is electric, and the electrics are turned off unless the door is properly closed, hence with the door closed but not fully "home" you will neither be able to re-open the door nor wash what is in the machine. Just give the door a firm push closed and it should spring to life.
Apr 27, 2011 | Miele Novotronic Premier 500 Front Load...
The detergent flap does not open
Check the dispenser for easy close & open. Trouble could be- latch relay not getting energized- wires might have snapped - relay driver - command not reaching from the controller etc.
If you check all the points you will get an idea. I feel micro-controller may not have any problem as other cycle is OK.
Further assistance contact the authorized service center.
May 22, 2010 | Miele 24 in. G665 Built-in Dishwasher
Miele w404 dead not lighting
firstly check the power. secondly check the door is closed properly and push hard on it as the door lock needs to be engaged for the light circuit to then light up. it could be a faulty door lock
May 14, 2010 | Miele W404 Washer
Dec 02, 2009 | Miele 24 in. G665 Built-in Dishwasher
Miele g665 dishwasher
Wow... one week is a long time. Those dishes has to be very clean or at least worn out by now.
From what you are discribing, it appears you have a timer control module that is malfunctioning. You might try that first. If that still doesn't do the trick, check the fill valve sensor/seliniod
Jun 09, 2008 | Miele 24 in. G665 Built-in Dishwasher
Miele g665
Peter,
where is the water coming out at? Are you using the proper detergent? if the machine is too full of water and a fill float valve is stuck open, water sometimes overflows.
Check to make sure the fill valve is working, then check to make sure pump is operating. (you will know when you turn the machine onto the rinse cycle.)
Mar 17, 2008 | Miele 24 in. G665 Built-in Dishwasher
Dishwasher Miele G575
It could be a motor or a pump issue. The dishwasher has a motor that attached to a pump which forces the water up into the sprayer arms and during the drain cycle, it pushes the water out of the dishwasher. The motor (and pump) located beneath the dishwasher. Regarding the screwdriver adjustment- This is the rinse aid dosage adjuster. To obtain the best drying results,use the selector on setting 5. When dishes show spots, set it to a higher setting. Turn lower if dishes are cloudy. Good luck!
Sep 13, 2007 | Miele 24 in. G665 Built-in Dishwasher
Dishwashers Logo
71 people viewed this question
Top Dishwashers Experts
