Question about GE GTWP2000MWW Washer
I need to start my washer but the timer knob is broken.
  • 178 Answers
SOURCE: ge timer on washer is broken
If it no longer clicks, the timer assembly will need to be replaced. If just the knob broke off, the timer should be good.
Posted on Mar 16, 2008
  • 1214 Answers
SOURCE: kenmore washer 110.92292100..Washer Timer Control Knob is broken,
If the knob is tight on the timer stem, then the timer has failed.
If the knob is loose, then maybe just the knob has failed.
You can order either of these from a number of places. One I recommend is searspartsdirect.com. YOu just enter your model number and find the exploded view for the controls. If it does not find it, drop a number off the end of the model number that you've given and try again.
They are easy to replace.
Reply back and I can give you more advice or instruction.
Posted on Feb 03, 2009
SOURCE: The timer knob spins freely and I can't start the machine or set the timer.
"Can I replace it with a new knob or do I have to buy a new timer?"
It sounds like the knob is rounded out where it fits on the timer post, or It may just be loose. Pull the knob off and inspect it. If damaged, yes, you can buy another one.
Posted on May 04, 2009
plnolte
  • 62 Answers
SOURCE: My GE washer timer knob is broken
This tool should help. Click on the link below or copy and paste. Good luck and write back if you need further assistance...
http://www.sears.com/shc/s/p_10153_12605_00941513000P?keyword=craftsman+tool+hook
Posted on May 13, 2009
canbruce75
  • 1776 Answers
SOURCE: Kenmore Washer, Loose Timer Knob
There should be a spring clip that holds the timer knob on. It or the timer knob may need replaced. Here is a picture of the timer knob and the spring clip. Sure hope this helps and best wishes.
Posted on Jul 24, 2009
Can't start washer the knob that you pull to it won't come out.
Dear Jill.
I fix washers, and it sounds like a couple things may be the reason for your problem.
1) The timer itself may be broken, and need replacement. Or,
2) The ears on the timer body may have broken off, preventing the timer knob from working.
(Remember, there are "a hundred" different kinds of washing machines, so it is really good to identify your machine completely whenever you ask for help.)
I have had several washers recently that were broken with the symptoms yours has.
The timer body (inside the control panel) is plastic.
Because someone was rough with it, or because the plastic got old and became more breakable, the ears break off easily.
The plastic ears are what hold the timer in position so the knob will work in-and-out correctly.
God bless your efforts.
Feb 16, 2017 | Washing Machines
I have a Whirlpool washing machine LA8800XT. It seems the timer knob can no longer engage the timer shaft. Part number of the timer is 3352091. I am positive the machine and the timer are fine. I tried...
I have a Whirlpool washer #LA8800XT and want to remove the Fabric Softener dispenser so I can remove the agitator. Does it just screw off? It seems to be stuck and I didn't want to break it if it didn't screw off.
Oct 09, 2010 | Whirlpool 3362624 Washer Control Timer...
The knob on my kenmore elite won't move the timer.
The knob itself turns the switch on . The skirt move the timer position. Try turning the skirt. You probably have a broken knob. On these the knob is held in place with a plastic rod inserted into it all the way. This spreads the tip and retains the knob. To get the knob off to yank out the skirt for a look see you need to pull that rod out a tad to release the knob. 88be11a.jpgThat shaft has a rounded end on it that spreads out and locks the knob on. Clever ain't it? These timers are cheaply made, if you cannot find fault with the knob or the skirt then you is gonna need a timer.
Jun 05, 2010 | Kenmore Washing Machines
How do you access the control panel the knob that sets the wash cycles is broken and needs replaced
The topside control panel has four small torx screws that hold the control panel to the rear. The timer has a small U clip under the knob that needs to be removed with needle nose and then the knob comes off so the timer can be replaced. I have your washer's training manual HERE
Apr 20, 2010 | GE WJSR2070B Top Load Washer
GE WASHER MODEL #WBSR3140G0WW: TEETH ON CONTROL
I suspect that a mounting tab has broken off the timer. Take the four torx head screws off the back edge of the top of the washer and open up the backsplash to confirm this. I manufacture a make shift Z shaped metal part to hold the timer in place without having to replace the timer.
Mar 25, 2010 | General Electric WBSR3140GWW Top Load...
Jul 23, 2009 | GE WBSR3140DW Top Load Washer
Timer broken
usually a timer knob lock located on the back of the timer itself, youll need to pull a small post out to unluck trhe knob and then it will pull right out reverse for installing new
Oct 31, 2008 | GE WBSR3140DW Top Load Washer
Speed Queen HD comercial washer
Its sounds like you need a replacement knob, if you can turn the disc behind it to start a cycle and the machine times out find the timer is probably still good, do a Google search for Speed Queen parts, and buy the correct replacement knob.
Mar 30, 2008 | Speed Queen AWS52NW Top Load Washer
Ge timer on washer is broken
Mar 16, 2008 | GE WDSR2080D Top Load Washer
GE GTWP2000MWW Washer Logo
26 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
