Question about Cameras
Digitel sd1000 set top box not showing any video
3 Suggested Answers
SOURCE: Use of Video/DVD player whist Set-top box plugged into SCART
Manuals
Posted on Feb 12, 2009
gopakumarg43
  • 75581 Answers
SOURCE: Will any other remote work my digitel HD 3000 set top box
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops. Visit some online sites too, which deals with electronic spare parts.
Posted on Jul 14, 2015
My canon ixus70 will not take photos,I can view past photos but it will not show image on screen or record digital image ,if I take a shot all I get is a black nothing. Janis jvdzelde@bigpond.com
Issue: How do I reset the camera to its default settings?
Solution: Procedure for resetting the camera to its default settings PowerShot SD750 and SD1000.
Resetting Settings to Their Default Values - PowerShot SD750 and SD1000. 1. Turn on the camera and press the <MENU> button to open the menu. 2. Using the arrowrightbutton.gifbutton, highlight the yellow setup_icon.gif(Set up) tab. sd750resetscreen.gif 3. Using the arrowdownbutton.gifbutton, select [Reset All..] and press funcseticon.gif. sd750resetscreen.gif 4. Select [OK] and press funcseticon.gif.
  • Settings cannot be reset when the camera is connected to a computer or to a printer.
  • The following cannot be reset:
    • Shooting mode
    • The [Date/Time], [Language] and [Video System] options in the setup_icon.gif(Set up) menu
    • White balance data recorded with the custom white balance function
    • Colors specified in the [Color Accent] or [Color Swap] modes of My Colors
    • Newly added My Camera settings
Jul 28, 2010 | Canon PowerShot SD500 / IXUS 700 Digital...
My camera will no longer show the image on the screen when I am taking a picture with my Canon PowerShot SD1000 digital camera. Can this be fixed or is it time for a new camera?
most likely you have turned the dispaly off. find the display key and turn the screen back on.
another option is to go into the menu, then go to display and set it there.
Jul 18, 2010 | Canon PowerShot SD1000 Digital Camera
Connecting my TV and DVD player to a digital set top box
There are 4 different types of cables and they have to do with the quality and resolution of what they carry.
1) Coaxial or an RCA to RCA, 'Yellow colored connectors' - Composite video - Lowest quality of video you can get. Mostly what people hook up from their VCR's. '240 to 480 lines of interlaced resolution.
2) S-VHS cable - 4 pins - Carry Chroma 'Color' over the one set of two pins and Luminance 'B&W' signal over the other 2 pins. This is a higher resolution than the Composite video cable - 480 to 512 'still interlaced resolution' or ' i ' .
3) Component cables - RCA ends but there are 3 of them. Red colored 'for the Red video signal', Green colored connector 'for the Green video signal with Vertical sync laid on top of it,' and then Blue colored 'for the 'yep you guessed it' the Blue video signal with the horizontal carrier laid on top of the signal'.
This is the higher resolution of 720 ' i ' interlaced or even when selected by your piece of output equipment up to 1080p 'Progressive' resolution if your equipment can output this highest resolution.
4) HDMI - is a cable that not only carries the component but does it digitally along with audio and an ID bit that the Transmitting equipment 'STB' in this case should communicate with your 32" LCD HD-TV so that it will put out the maximum signal 'probably 1080P' that your TV will handle.
I would try to obtain an HDMI cable and use this to connect your STB to your LCD for the best connection between your two units.
Blessings,
A/V Media Guy
Nov 22, 2009 | Televison & Video
Canon SD1000, screen blacked out and takes black pictures
try taking the batteries and memory card out let it set and put everything back in it ang cut it on
Jun 18, 2009 | Canon PowerShot SD1000 Digital Camera
How can we turn off the automatic start of Radio or CD setting?
The activating and deactivating of the 24 hour timer is via a toggle button, labeled "TIMER" on towards the right side of the top console. When the TIMER is activated, you will see a small clock symbol on the LCD display. While the unit is on, tap the TIMER button once. The clock symbol will disappear and the timer is now off.
Reactivating the timer is the same process (remember, the button is a toggle). Tap the TIMER button and you'll see the timer settings show up on the display (time on, time off, source, and volume). The little clock symbol appears again.
If you have lost your manual, you can download another one for free from this location:
http://www.retrevo.com/s/JVC+SD1000
Nov 17, 2008 | JVC FS-SD1000 CD Shelf System
Canon SD1000 blurred pictures and blurred LCD, Camera wont focus! please help ive had it for 2 weeks
The best chance to use your SD1000 is to set to picture, push ISO (on top of the func. set ring) and set to hi. This works pretty well. Do not bother sending any camera to Canon, they charge the "standard charge" plus for all their manufacturing problems on all Canon cameras. Definately the worst customer service on the market.
Jul 07, 2008 | Canon PowerShot SD1000 Digital Camera
Cameras Logo
23 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
