Frigidaire Optional Icemaker Kit
Problem for Frigidaire Optional Icemaker Kit
Ice maker will not work
By sfoster515 on Apr 01, 2009
recently moved. Got around to hooking up the ice maker and it will not work. Replaced all of the hoses and the electric switch. Still have no ice. Optional Ice maker Kit Model AD-18
Best Solution
posted on Apr 01, 2009
Helpful)
ssolved
Rank: Wiz
Rating: 77%, 108 votes
There's no ice If your ice maker has stopped producing ice completely, check these, in this order:
  • It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these:
    • If your ice maker has a small red plastic lever, lower it to lower the wire.
    • If there's no plastic lever, simply lower the wire.
    In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
  • The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary.
  • The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Small or too few ice cubes If the ice maker is producing ice poorly--making small cubes or too few cubes--you probably have a clogged water line, a defective water-inlet valve, or a defective ice maker mold thermostat that isn't cycling properly. Check these:
  • The water line that's attached to the back of the refrigerator. Make sure you have good water flow. If the flow is poor, repair, clean, or replace the tubing or the shut-off valve that supplies the water.
  • The water-inlet valve. Replace it if it has failed.
  • Check the freezer temperature. If should be 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
  • The ice maker mold thermostat. Make sure that it's cycling properly.
Specks in the cubes If you find black or gray specks in your ice cubes, have a look at the ice cube tray. If the protective coating is peeling away, the most economical solution is to completely replace the ice maker.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Frigidaire Optional Icemaker
Questions and Unsolved Problems for Frigidaire Optional Icemaker
Do you recommend Frigidaire Optional Icemaker Kit?
Answer
Answer
Model AD-18 (in a Kenmore) Two problems I believe may be related, FIRST: The fridge has had (for a... (More)
Answer
How do I install my ice maker needle valve to a pex water supply line?
Answer
hook up water lines but no water is getting inside. is there a safety feature on the fridgerator... (More)
Answer
I ordered and received an icemaker for my 8 year old Frigidaire frig, using identifying numbers etc... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Specialty... Experts
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
