Question about Microsoft Windows 2000 for PC
Booting from mirrored drive
I have generated mirror sets including the boot drive on windows 2000 adv server but now iam unable to boot the system,while booting windows hangs and displays a error massage that "unable to boot check for hard drive for corruption check for viruses run chkdsk /F remove any new hardware installed and try again" pls help
    Novelist:
  • 114 Answers
GO TO STAERT AND CKICK ON IT ... WHERE IT SAYS "RUN" TYPE IN CHKDISK. ALSO CLICK "START" AND CLICK ON "SEARCH" SEL;ECT ALL FILES FOR SEARCH AND TYPE IN CHKDISK .... THIS MAY TAKE A WHILE. IT WILL SHOW EVERY LOCATION OF CHKDISK. CLICK ON EACH ONE AND CLICK OPEN OR RUN. ALSO CHECK ADMINISTRATOR/USER TO MAKE SURE YOU ONLY HAVE ONE. ITS LOCATED UNDER CONTROL PANEL. GOOD LUCK
Posted on Sep 04, 2007
  • Joseph Reckinger
    Joseph Reckinger Sep 04, 2007
    IF YOU DO GET A BLUE CHKDISK SCREEN MAKE SURE YOU WAIT UNTIL THE TIMER RUNS TO O. HITTING ANY KEY BEFORE WILL DELETE THE CHECK.
SOURCE:
We have hp server ml370 when i restart the server its stopped on attempting boot from hard drive c and never continue
This is because either the image on the hard drive is bad (corrupted, missing boot sector, etc) or because the hard drive itself has some issue like corruption etc.
If this is a mirrored raid array (two drive mirroring each other) I would try to remove one of the drives and boot again. If that does not work reinsert and remove the other drive and try to boot.
regards,
Mike
Oct 21, 2012 | HP ProLiant ML370 G4 Server
URGENT. Dell Poweredge 2850 Mirror 1 Now it is not booting. How to make it boot from Mirrored disk Thanks for any assistance
If you know the two drive that are the OS mirrored drive, remove the failed drive and replace it with the good mirror drive and boot the system. If the drive and the OS is good the system will boot from that drive. You can now mirror this drive with a good disk.
Sep 18, 2011 | Dell PowerEdge 1800 Server
I have malfunctioning electric-driven exterior towing mirrors on a 1999 ford f-350. How to diagnose/fix? Mirrors respond only to right adjust; no response on up/down or left adjust.
there is a separate motor for up/down and another for left/right adjust. The glass is serviceable but not the motors, built into the frame of the mirror body.
SECTION 501-09: Rear View Mirrors 2000 F-Super Duty/Excursion/Motorhome Chassis Workshop Manual
REMOVAL AND INSTALLATION Exterior Mirror Glass Removal
NOTE: Left-hand dual arm mirror with heat shown, non-heated and aero mirrors similar.
  1. Position the exterior rear view mirror glass in the full down position.
  1. Grasp the top and carefully pull the mirror glass away from the mirror housing.
  1. Disconnect the electrical terminals (if equipped) and remove the exterior rear view mirror glass.
Installation
  1. Remove the jack pins from the mirror glass back.
  1. Remove the sealing boots.
  1. Install the jack pins in the sealing boots.
  1. Install the jack pins and sealing boots.
    1. Install the jack pins in the mirror housing.
    1. Install the sealing boots so the boot shoulder is under the mirror collar.
  1. Loosely install the glass.
    1. Connect the electrical wiring to the electrical terminals (if equipped).
    1. Position the friction pins in the mirror housing.
    1. Align the jack pin locating tabs to match with the mirror glass back.
  1. Using a flat hand, press on the center of the mirror glass until seated on the center pivot of the mirror housing.
    • Press the mirror glass toward one of the jack pins until snapped in place.
    • Repeat for second jack pin.
Jan 13, 2011 | Ford F-350 Cars & Trucks
I have a Dell Poweredge 1800 with 4 Cheetah 10K.7 Ultra U320 SCSI Drives which are supposed to be mirroring each other in case of failure of one hard drive the exact same thing is on the others. Drives 1...
hi!
This is a quite serious matter to be solved. The information you have provided is not enough at all.
What you have to include in here:
  1. First, Be precise. Don't assume.
  2. How did you recognized the failure. Which indicators or POST/BIOS/RAID BIOS reported you the errors? Was it from the OpenManageSA?
  3. Please specify the Hardware Controller model and manufacturer with the version (RAID controller).
  4. Which Operating System do you run (or ran)?
  5. Are these disks Hot Swappable?
  6. Have you used hardware RAID controller or software RAID? Provided by OS.
  7. Do you have Dell OpenManage Server Administrator?
  8. How do you describe the RAID configuration? Are you sure that Disk 1 and 4 are mirrored to 2 and 3? You must be precise. Because raids can be used in many ways. You can combine any two disks and mirror them to any two disks. Even though it prevents hard drive failures, if your OS had an issue Mirrors may not be an option to recover it.
  9. That message is a Warning Message. However Drive Roaming has completed. You don't need to worry about that.
  10. If your BIOS has associated firmware controllers you could rebuild the array. But you may have to add new disks to replace others. You may need to update the firmware if necessary.
  11. Then if you plan to use disk 2 and 3, you have to position them to 1 and 4. Then try to rebuild the array. But you may have to have Controller Drive installed on the disk. That varies from type to type. So I cannot say exactly. However if the mirroring of the OS is done to one disk, that disk would be enough. But you have to be certain. Reconfiguring should be done using both the disks replaced if you do not know anything about the configuration.
  12. Check BOOT ORDER. Change it if necessary. If disks fail again check one by one and repair them using a separate machine.
  13. Use Dell Software (OpenManage Server Administrator, if its the one available). Rebuild and or Resync the array.
  14. If boot record errors occur, you have to boot from CD/DVD and repair the Boot Record and/or MBR.
  15. If you need any other issue like BSOD, please write them down. Make sure the OS is not corrupted. If you backed up the System Status, restore it in such a case. Do an In-place Upgrade otherwise (will replace the OS files only, not data).
  16. Use the manuals for Dell Server and RAID Controller if you do not know how to use properly.
  17. If all the options are not working, you have to contact an engineer at Dell.
Feel free to contact again.
Thanks for using Fixya!
-Lasitha
Aug 27, 2010 | Dell PowerEdge 1800 Server
Dell XPS w/Mirrored drives. No C drive when using boot disk.
As RAID uses block for block copy, a re-sync when adding in a new mirror on RAID 1 will take some time, and system performance will be affected during that time period. There is no indication in windows if the rebuild is complete as this is being done on a hardware level by the controller. Both Raid 5 and RAID 10 have added benefits , but alos require more storage (a lot more in case of RAID 10 as you will have effectivly 3 spares for 1 data.) Raid 5 has the best space/protection pay off, but will be slightly slower than both RAID 1 and RAID 0 as parity has to be calculated for each write. As caffineshark states your best option is to use a combination of the methods we have described:
1) Use the two SATA disks as RAID 0 for performance and reliability.
2) Make backup images of the boot volume using Drive Image / Ghost and store on external USB IDE drive, and then offsite.
If you make an image in the USB drive, make sure you run a verfiy of the image after creation to make sure it's valid.
This should allow you to restore in a DR sutuation, but also give you some decent HDD crash protection.
Jan 29, 2010 | Dell My XPS M2010 Notebook
Boot from non Dell raid controller
Check the Boot Sequence again -- if there are any "SCSI" devices listed, enable them, and make your CD-ROM the "primary" boot-device (so that you can install Windows) and make this "SCSI" device the SECONDARY boot-device, and disable the internal hard-drive, so that it won't be used as a boot-device.
Dec 27, 2009 | Dell Computers & Internet
Net Framework Error
DOWNLOAD THIS BOOK FOR FREE AND SOLVE ANY PC HARDWARE, SOFTWARE OR OPERATING SYSTEM PROBLEMS.
DOWNLOAD NOW......
Download mirror 1 ( Hosted by HostingDude)
Download mirror 2 ( Hosted by Softpedia )
Download mirror 3 ( Hosted by Soft32 )
Download mirror 4 ( Hosted by fileflyer )
Download mirror 5 ( Hosted by Rapid Share
375
Jul 19, 2008 | Microsoft Windows 2000 for PC
Biostar P4M800-M7A Motherboard SATA RaiD Mirror Array As C boot Disk
hi, you need not have to upgrade the BIOS,, set the SATA HD on the IDE channel in the BIOS, or what options r avilable for SATA controller, if it is set to RAID, you will need a raid utility to format the SATA, or it wont shoe in windows, let ,e know
Dec 17, 2007 | Biostar P4M800-M7A Motherboard
Microsoft Windows 2000 for PC Logo
55 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
