Question about Frigidaire 24 in. PLD3465REC Stainless Steel Built-in Dishwasher
'Er' message on Frigidaire Model FGHD2465NW1A model will not reset.
SOURCE: Er message on panel of Frigidaire GLD3450RD
I had the same problem last spring. Unfortnuatly, the problem is within the electronic control. Steam leaks in, due to an improper seal ring. Humidity stay in the compartment and eventually, the contact on the wire ribbon corrodes. For me, it meant a new electronic module.
If the eletronic module is ok, then the only working solution require that you order and install a "fit kit" from Frigidaire.
Some models even have a recall made form Frigidaire. Better check with them.
Posted on Jan 03, 2008
SOURCE: 6 mo. old frigidaire d/w displays the "ER clean S" flashing error
Probably a control panel failure. This unit does not ventfrom the front like most do, so there needs to be some clearance above the top of the tub to avoid blocking the vent fan, otherwise moisture gets trapped in the machine and works it's way into the control panel eventually.
Posted on Apr 08, 2009
SOURCE: our 6 month old frigidaire
My unit has the same problem and it is due to a failure of the control board. The tech that came to look at it tells me that this unit vents from the top of the tub rather than from the front, and he claims that the installation instructions require a 1" gap between the top of the tub and the countertop.
Now I have found no such information in the installation manual that I downloaded, and I am skeptical that a 1" gap could be done, and if it could it wouldn't look to good.
I am going to pull my unit out and see exactly where the vent fan is and what the clearance is. The service tech says they can't replace the control panel until the installation is proper. I am thinking this is at least to some extent a design flaw with this machine. There seem to be a lot of reports of this failure.
SOURCE: Dishwasher Frigidaire Professional Series model
The dishwasher is junk...poorly designed. Masterboard for electronic buttons keeps shorting out because the dishwasher vents from the top. have this dishwasher and know first hand. had it for about a year and its been fixed several times
Posted on Nov 01, 2009
SOURCE: Dishwasher showing Er . Reads as
ER code, that indicates a keypad switch failure.
Below is a DIY self help Dishwasher repair help website.
http://www.acmehowto.com/howto/appliance/dishwasher/dishwasher.php
If you confirm the error code and it is an ER UO code then the vent fan assembly will need to be replaced.
If you can't verify the error code then I recommend a technician check this problem.
Posted on Oct 15, 2010
How do I reset my Frigidaire dishwasher? eR light is flashing
Good Afternoon Sammy, thank you for your inquiry!
Based off the information you have provided you would like to reset your Frigidaire dishwasher because it is flashing "ER". The best way to reset your dishwasher is to flip the household circuit breaker off for roughly ten minutes. If you continue to receive the "ER" code it could be a possible problem with your main control board or keypad. I hope this is helpful information. -Matt
Mar 21, 2015 | Frigidaire Dishwashers
On my fridgidaire dishwasher. The code ER comes on and it won't finish a load of dishes. Is there anyway I can reset it
You need to research the code along with the model at Frigidaire website.....if you cant find the answer you should contact the Frigidaire tech support people.
Oct 25, 2014 | Dishwashers
Er S flashing How to fix
Not sure what the "S" is, but on a Frigidaire, the Er fault code is caused by a stuck key on the console. You'll probably need to replace it:
Replacement Console asse 807545702 for FRIGIDAIRE Large Kitchen...
Oct 19, 2014 | Frigidaire Dishwashers
Have ER MESSAGE ON BURNER DISPLAY
Hi Carla Rae Caswell, thanks for your inquiry!
Typcially, "ER" stands for error on a Frigidaire range and it is usually followed by a number to distinguish what the error code means. I would suggest performing a reset on your appliance and you can do that by unplugging the power cord or flipping the household circuit breaker off for ten minutes. If that does not correct the problem you may want to consult with a professional for proper diagnosis and repair. -Matt
Oct 12, 2014 | Frigidaire Kitchen Ranges
ER code, flashing touch pad selections.
It is most likely a fault with the keypad mebrane on the dishwasher control panel. Need model number of dishwasher to make a more detailed conclusion.
Jan 04, 2013 | Frigidaire Dishwashers
I have a Frigidaire model#PLD4555RFCO the er code and the washing and drying and clean and S lights are on and blinking on the display. have any ideas what the problem is?
Hi
"Er Clean S" is a common error with Frigidaire which means shorted keypad. The issue is with the touchpad/keypad that should be replaced. However, before replacing the keypad you can unplug it and take it apart completely and use a hair dryer to blow some warm air on the keypad assembly to blow the moisture off. Hope this helps...please post back for further assistance.
Daniel
Aug 27, 2011 | Frigidaire Professional Series 24 in....
Frigidaire plef398ccc displayed 'er' now won't heat cooktop/oven
You could have a problem with the user interface board, which is #97A in the attaced breakdown, part #316225039500. Hope this helps.
Nov 16, 2009 | Frigidaire PLEF398C Kitchen Range
Error message
Hello gravyblast.
Welcome to Fixya.
You said, your Kenmore Elite Trio, model 795.7756 or 7757 has an error message simply reading ER IF. No pressing of buttons, or combination thereof changes anything. Also, the ice maker has stopped working although it is turned on.
Can anyone help?
I cannot pull the refrigerator out to unplug and reboot it, thus I don't know what to do.
Try tripping the breaker off for 5 minutes and then see if this method resets the system?
Do not turn it back on for at least tree minutes. That's why I said, Five!!!
Lets see how it resets while I look your fridge up.
Write back. Huuum
7:11 pm eastern standard time . I'm here!
Sep 17, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Nov 15, 2007 | Frigidaire 24 in. GLD3450RD Built-in...
Frigidaire 24 in. PLD3465REC Stainless Steel Built-in Dishwasher Logo
478 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
