Question about Maytag MSD2756GES Side by Side Refrigerator
Maytag model RTC17A
Fridge is kicking on but not keeping food cold also ice is gathering inside the fridge on top
  • 291 Answers
How is freeezer side doing? Do u have any frost build up in freezer back wall and is you fan in freezer blowing?
Posted on Sep 02, 2007
SOURCE:
I have a maytag fridge (freezer on bottom) the fridge is not very cold. freezer has started to get ice near the door opening in the last week.
if you see ice near the door the door muat not be closing all the way or the gasket could be ripped,ice will form where warm and cold air are mixing together,did you remove any of the shelves or baskets in the freezer or in the fridge?i've seen people clean out the fridge and the shelves weren't put back in correctly keeping the door open,check that or food packages that might be hitting the door,when the warm air gets in it usually freezes the air ducts,this is why the fridge is warm,all that happens is the evaporator coil in the freezer gets cold,the evap fan blows the cold air from the freezer into the fridge section and then it returns through other air ducts so if warm air is getting in it will freeze up the air ducts,you can try shutting down the machine or unplug it,remove the food from the freezer and with a hair dryer hit the back inside wall of the freezer,blow the air up into the vent holes in the back wall,if you see water dripping down through the slots you have ice up in there,keep blowing the hot air up into the holes until you don't see any more water dripping,if you can remove the ice maker and remove the back inside wall of the freezer would be better.first check the freezer back wall to see if there's any frost or like snow on it,if so you could have a defrost problem,bad jazz board,this is the computer board that's behind your digital controls in the fridge section,bad defrost thermostat or heater,also do you mean the floor of the freezer has ice on it,you could have a blocked drain in the freezer.write back with more info and let me know what you find and hopefully i can help you better.
Sep 05, 2012 | Refrigerators
I have a model MTB1956GE Maytag Fridge, Frezzer
Can you feel air moving or hear the fan running in the freezer section? You said the freezer section is freezing well, but is it freezing really hard?
Regards,Richard
Dec 12, 2011 | Maytag MTB2156GES Top Freezer Refrigerator
I have a Matag Refrigerator Model MTB2156DEW. The freezer is located on the top of the fresh food compartment. For approximately a week the refrigerator has been constantly running without cycling. ...
Defrost the unit. The fridge section cannot cool if the freezer is iced over since the fridge gets its cold from the freezer. If you don't have a second fridge use a hair dryer to speed the defrost.
Apr 06, 2011 | Maytag 21.7 Cu. Ft. Top-Mount Refrigerator...
My sub zero refridgerator (freezer on bottom fridge on top) is cold on the bottom of fridge and warm on the top of the fridge. Any idea what is causing this. Items are also damp in fridge. We just vacumed...
the evaporator coil inside the freezer compartment is iced over and can't transfer cold air in thes condition,remove panel inside freezer on back side of freezer compartment and thaw it out with a hair dryer,then check the defrost heating element for continuity,if its open replace it,if its good, ,check the defrost control that powers the defrost heater
Jul 15, 2010 | Sub-Zero 611 / O Bottom Freezer...
Freezer is very cold, refrigerator not cooling on Maytag side-by-
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
s
Nov 25, 2009 | Maytag MZD2766GES Side by Side...
Admiral fridge, freezer won't stay cold
Check the condenser fan, listen and see if it kicks on, if it doesn't then find someone that know how to take it apart and change them.
Jan 31, 2009 | Maytag Admiral Top-Freezer Refrigerator
The top part of my fridge is not working properly.It is not keeping food cold. The bottom freezer unit is working fine. I have cleaned the back and I have unplugged the fridge and plugged it in again. I...
The top part of my fridge is not working properly.It is not keeping food cold. The bottom freezer unit is working fine. I have cleaned the back and I have unplugged the fridge and plugged it in again. I have also turn the buttons off and on inside the fridge.
Feb 21, 2008 | Zanussi ZX97 / 5 Bottom Freezer...
Fridge problem
I don't know about the hot points for sure, but all the maytags (I used to work for maytag) have a damper valve in the air tunnel that feeds cold air to the refrigerator. If the damper went bad, it would block cold air flow into the refrigerator. (assuming this model has a damper)
Feb 16, 2008 | Hotpoint  21.8 Cu. Ft. Top-Freezer...
Maytag side by side freezer works, fridge does not
the heat is from the condensor keeping the door from frezzing shut it is normal but you need to adjust the food compartment contorl it might say for a for a coler frezzor turn up then you do and the food compartment gets warmer all it is is a air baffle to alow more cold air into the food compartment turn the cold control half way its the one that has off on it and then turn the other control to a lower number to make more cold go into the food compartment
Aug 29, 2007 | Maytag MSD2656G Side by Side Refrigerator
Maytag MSD2756GES Side by Side Refrigerator Logo
212 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
