Question about Admiral AW22 Top Load Washer
Admiral Washer Model # aav7000aww
It will only drain in the first cycle, when it hits the finally rise, you have to push the timer in 2-3 times and then it will kick sometimes. Also how do you the timer knob off to replace the timer. I have ordered a new timer , do you think that is the problem.
  • 641 Answers
Look if there are any screws on timer knod side. If not, you should just pulls it straight off once. Following your description it sound like a timer issue, but it could be a loose connection to timer or inside the timer as well. Good luck!
Posted on Aug 31, 2007
SOURCE:
Washer makes straining noise when draining water from tub while spinning?
my admiral washer machine model AAV7000AWW makes a noise only when draining/spining water, is no water spill at all. Thanks
May 21, 2010 | Washing Machines
Admiral Washing machine will not advance to the next cycle.
whirpool machine .. it was overload and now it's not draining the water. stops when in the drain cycle./
Jan 01, 2009 | Admiral AW22 Top Load Washer
AAV7000AWW washer
sounds like the thrust bearing is worn causing an imbalance on the shaft. check herehttp://www.partselect.com/AdvancedModelSearch.aspx?ModelNum=AAV7000AWW&mfgModelNum=&fkMfgID=1:- for a schematic on this machine and parts as listed.. hope this is of some help
Oct 22, 2008 | Admiral AAV7000A
Admiral washing maching model aav7000aww
Hello donerehart
You said, water and spin cycles are fine, but won't agitate... what can i do?
Sounds like the timer in the dial will not progress!
Sep 05, 2008 | Admiral AAV7000A
Admiral Top loader leaking water
water inlet vale has internal malfunction
Jul 20, 2008 | Admiral AW22 Top Load Washer
Admiral washing machine AAV7000AWW won't stop filling or agitate?
It is either the inlet velve or the cycle programmer faulty
May 24, 2008 | Admiral AAV7000A
Admiral Washer AAV7000AWW everything works -goes through cyclebut will not drain
You,ve done a good job the first time the pump fail MikieM. You can do it again. We sometimes forget to empty our pocket. Some small metal things could have gotten into the pump...could be other hard foreign object. Good luck.
Dec 21, 2007 | Admiral AW22 Top Load Washer
Admiral washing machine MOdel AAV7000AWW On any spin will not drain 1st time through
is this machine induction motor or carbon brush if it is the inductin you need to be looking at the capacitor and if it is carbon brush then change them you will find them mounted each side of the motor and the capacitor will be @ the top under the lid near the pressure switch good luck
Jul 24, 2007 | Admiral AW22 Top Load Washer
Admiral AW22 Top Load Washer Logo
456 people viewed this question
Top Admiral Washing Machines Experts
jimorris77
Gerry Harvey
Gerry Harvey
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
