CX1-G2- Critical Power Supply how do I check the speed and duty I know you can press a button combo to do so just don't know that combo, any help would be stellar thanks
3 Suggested Answers
leethedeuce
  • 4472 Answers
SOURCE: no power?
How long have you owned the printer. Please do not pass or ask for more assistance til I have all the information and can assist you properly. Your best bet is to locate the nearest authorized service center at this link
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&category=Products&infoType=Contact&oid=47541
though you may have to contact their tech support. Your only other option is replacement in the future you may want to consider an extended warranty. If you have a moment to accept and rate this solution it would be greatly appreciated.
Thanks,
Lee
Posted on Sep 16, 2008
Inky
  • 691 Answers
SOURCE: Epson stylus photo r320
You may have a problem with the switch panel board. If you disassemble it, you may be able to test the panel by shorting the two connectors to the power button. On the other hand it could be the power supply that is dead on the output side. Both are problems that do occur with R3** series but not that common.
Posted on Sep 19, 2008
Can you do a screenshot on the Trio Stealth G2 9.7 Tablet?
This should work on any Android 4.0 and newer tablet.
To take a screenshot on your device, press the Volume Down and Power keys at the same time.
The screen will flash, you'll hear a sound, and you'll see a framed image appear and fade into the notification bar. The "Saving screenshot" notification will appear.
May 10, 2015 | Mach Speed Trio Stealth G2 Tablet -...
Why won't my trio stealth g2 tablet won't hard reset?
Does the device have a password lock on it.
If it does try removing this first, then attempt a hard reset.
You can access the engineers menu by holding the volume - button and then pressing the power button whilst turning it on.
Other than that the only other option is to reload the ROM with a flash utility.
But this is not for the faint hearted :-)
Aug 05, 2014 | Mach Speed Trio Stealth G2 Tablet -...
I have a Trio-Stealth G2-8 and turn on but the screen said @9 Dual Core and don't do anything else can somebody tell me how to fixed?
Its a common problem with tablets and not easy to fix.
Your tablet has a corrupt os and is caught in a boot loop.
There are fixes but not easy for a beginner.
Boot into recovery mode by pressing the power button and holding the down volume button in then select restore tablet from the recovery menu.
Jun 12, 2014 | Mach Speed Trio Stealth G2 8 inch Tablet...
Lg g2 will not turn on
  1. Take your phone and turn it off - just press power button and select "power off".
  2. Wait while your device is shutting down.
  3. Then, press volume down button and power button together until the LG logo appears on the screen.
  4. When the LG logo is displayed, let go of the power button, keep pressing the volume down key and then press once more the power button.
  5. Once you do that, on your LG G2 the factory reset menu will be displayed.
  6. Press power button in order to agree and wait while the hard reset is being completed.
Jun 09, 2014 | LG G2 White for Verizon Wireless CePhone
Trio Stealth G2
This is the most common problem with tablets - there are literally hundreds of people asking the same question and i have had the same problem myself - its usually corrupt bootloader or OS and can be a nightmare to repair.
Sounds like its borked.
Have you pressed the reset button on the back - pinhole - press it with a pin its a long shot.
The real fix is to go into recovery mode using the power button volume up combo. Then select the restore tablet option.
if none of that works you will have to sideload or reinstall using an sdcard a replacement OS - Try cyanogenmod - your tablet will have to be rooted and have the cm bootloader installed however - tablets are not easy things to repair when the software goes belly up. Its actually a disgrace and I have been repairing computers and latterly tablets for the last 30 years and it is by far the most common issue with any tablet except Apple - there is a reason they are so expensive - lol
May 08, 2014 | Mach Speed Trio Stealth G2 8 inch Tablet...
My trio stealth g2 hype 4gb tablet will not go pass the trio stealth g2 logo it just freezes up what can i do
Have you tried my old trick of pressing the on/off button and at the same time, press the volume+ button. Sounds like you have a screen freeze. hope it helps.
LindaSView
Apr 24, 2014 | Mach Speed Trio Stealth G2 8 inch Tablet...
Techwood tv 42" model 42832 was working nipped to shops so pressed power button on side came back ten mins later switched it on and came on and changes diff colours as seen in video how can I fix this
you have a power supply partial failure if you know how to safely check your power supply check the voltages, swolen capacitors etc. leaking capicators are usually the problem. if you know nothing about power supplies do not look at the tv without the tv unplugged! better yet; have the supply repaired by a professional. a power supply can kill you!
Feb 05, 2013 | Televison & Video
The screen has narrow white lines across the top 3 inches, on cable and with a VCR Tape in.
hello,
Where all colors are involved - the lines are essentially white or gray (or with a slight tint due to slight unequal settings of the color adjustments), look for something common like an incorrectly adjusted screen (G2) or master brightness/background/bias control or a problem in one of these circuits, a defective power supply or a problem in the blanking circuitry:
Screen (G2) or master brightness/background/bias control - mark setting and then see if a slight adjustment removes the retrace lines. See the chapter: "TV Adjustments". Of course, if this happened suddenly, the problem is not due to a misadjusted control though a dirty pot is possible - turn it back and forth - this might clean it and restore normal operation.
Power supply or connection to CRT neck board - insufficient voltage will result in the CRT never totally blanking. Check (usually scan derived) power supply components (from flyback).
General power supply - check B+ for correct value and ripple. A main power supply fault might result in these symptoms (and usually many others).
Blanking circuit - this may be a part of the video/chroma chip or separate. Check waveforms to determine if the blanking pulses are making it to the video output.
May 28, 2010 | Toshiba MV13L2 13 in. TV/VCR Combo
Standby light on pioneer vsx-d308 receiver
I have the same problem. my sandby light is on but my receiver will not turn on! I checked my power going into the power supply board that was good. But i do not have power going to the transformer or the receptacle. And both of my fuses r good. check ur fuses and go from there . If u know how to get a power supply. please let me know.
Jun 14, 2008 | Pioneer VSX-D308 Receiver
18 people viewed this question
jasbo
jasbo
