Question about Polaroid Tablets & eReaders
My Polaroid PTAB8000 will no longer charge via the charger that came with the tablet. It appears the port is damaged. Is there a way to replace it? If so, where do I get the hardward?
My Charger Port is no longer there is there any other way to charge it
Jillian, Check warranty, I beleive should be one year, call manufacturer right away if under warranty. Option 2 Have charger port replaced at a computer/cell phone repair shop. Check links below and see how they fixed this issue.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Android tablet charging port fix
How to Fix the Charging Port on Tablet
Is there any way to charge my tablet without the micro USB port
http://forums.androidcentral.com/amazon-kindle-fire/283806-anything-i-can-do-if-my-charging-port-broke.html
Apr 26, 2016 | Tablets & eReaders
Lost my charger is there another way to charge it
You can charge it via a USB lead also from the computer
Just will take a lot longer to charge
Try getting a charger from fleabay ,make sure it is a reliable manufacturers product as if you get a cheap replacement damage and fire are possible to the tablet or home
Apr 09, 2016 | Tablets & eReaders
My tablet was in use, needed charging, it shut off. Now it won't charge or come on
It sounds like there's a problem with the charger. The wire on the charger is rather delicate. So is the port on your tablet where the wire plugs in. There may be a break inside the wire. If you dropped your tablet while the wire was plugged in and it hit the floor on the charger plug, the charger plug could have damaged the charging port in the tablet or the wire itself could be damaged.
Find someone else who has the same tablet and ask to switch chargers to see if either of them still work on the other tablet. If your friend's charger starts charging your tablet without a problem, then the problem is a a broken wire in your charger. If neither charger will charge your tablet but both chargers charge your friends tablet without a problem, then the problem is with the charging port on your tablet.
Mar 17, 2015 | Tablets & eReaders
I have the Trio 7" Dual core tablet. The battery is not charging completely, can this battery be replaced and if so where do I find the battery in the unit?
Battery replacement is possible. The battery is a flat component encased in a shiny silvery sheath behind the speaker area inside the back cover. It's mounted with double-sided (very) sticky-tape. A replacemnent battery should be sourced, having the same power specifications as well as physical dimensions. (see detailed close-up photo attached.) Replacement involves desoldering the 2 terminal wires (1 red and 1 black) which attach it to the main board, and replacing the battery with a new(er) unit.
The above having been said,I'd only replace the tablet battery if I was sure that it's the battery at fault. Here's what I'd suggest.
First, check that you're using a charger with the proper 5 Volt / 2Amp (2000milliamp) output. Also I'd suggest you use a charger designed to be plugged intothe G2 7" Dual-Core tablet's dedicated charging port. (See sample tablet charger in attached photo) The G2 tablets WILL typically accept charging output via the micro USB port, for example, from a typical cell phone charger. However typical phone chargers which will happily attach to the Trio or other similar tablets, via the micro-USB port do NOT often have the same output power specifications. This I think may cause difficulty with the tablet battery not reaching the fully-charged status. Also, the use of the USB port for charging may cause access problems if the battery power is low during some operations (eg data transfer in slave mode), as the charging port can not multitask as the USB port can. If power to the main boad is lost during such operations the tablet may become "bricked". Bottom line for me would be to use the dedicated appropriately rated charger whenever possible: it's the reccommended charging method.
25239131-kxzyo1nfvoux0zgzt1u5dqab-5-3.jpg 25239131-kxzyo1nfvoux0zgzt1u5dqab-5-5.jpg
Oct 18, 2014 | Trio Mach Speed Stealth G2 Tablet - Teal...
Setting on charger for a Polaroid tablet, 6V, 12V, Help
Not sure of the model number of your polaroid tablet you have. Generally the adapter should be an AC adapter for 220V or 110V depending on country. It is unlikely you will have to select 6v or 12v. If you are unsure charge the tablet through the USB cable connected to a computer. It might take a bit longer to charge and make sure the computer is connected to mains charger to avoid drain on computer (laptop, etc) battery.
If you have a 7" tablet then I am assuming it is a PMID705. See manual on this link.
http://www.southerntelecom.com/upload/polaroid/pmid705/PMID705_User_Manual_20121210.pdf
The manual says it is a 5v DC output connector for the adapter. Not sure why you are asking the question. If in doubt send email to polaroid support on the address at end of the attached manual.
Sep 19, 2014 | Polaroid 7-in. Internet Tablet - Other
Why will my Kindle Fire not charge
This could be any number of issues; are you charging this on a car charger or wall charger? Have you checked to make sure your charge port isn't damaged? Does it connect correctly via USB to a computer? Have you tried the charger on different outlets? Has the Kindle Fire been dropped or damaged in anyway?
Sep 08, 2014 | Tablets & eReaders
I have a polariod ptab8000 and it won't mount my new 8gb micro external card, whatdo i need to do
Check the microsd card in another machine first - it may be the card that is snafu.
Or if you have another card try that and if it doesnt work either you know the sdcard slot is damaged - the pins are easily broken or the small spring inside sometimes pings loose.
May 11, 2014 | Polaroid Tablets & eReaders
Port charger broken
Sorry but normally after something like that you can try to see if you can get it repaird by the maker of it or just get a new tablet.
Jan 29, 2014 | Oregon Scientific MEEP Kids Tablet
Tablets & eReaders Logo
42 people viewed this question
Top Polaroid Tablets & eReaders Experts
John mullen
nexrad_chris
WTF Chuck.....
WTF Chuck.....
Are you a Polaroid Tablet and eReader Expert? Answer questions, earn points and help others
